E28 (1982 - 1988)
Old 12-28-2011, 05:42 PM
itskatys itskatys is offline
Mein Auto: 535is
535si radio code
I have a radio code but it doesn't work maybe I am putting it in wrong can anyone tell me how to enter the radio code. thanks
Old 12-29-2011, 08:57 PM
catso's Avatar
catso catso is offline
catso
Turn the ignition to "on", turn the radio to "on" then enter the code using the appropriately numbered radio push button selectors. If the wrong code is entered, the radio may lock up; even when the correct code is then entered. Make sure the battery is fully charged. Low battery voltage can also cause the radio to not recognize the code. Once the code has been entered three times unsuccessfully, the key will have to be left in the "on" position for one hour. This will reset the radio so that the correct code can be entered again.
![/I][/FONT]
Old 12-30-2011, 12:48 AM
Mein Auto: 535is
Thanks I will try this tomorrow and let you know how it turns out.
