E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
335i Engine Hesitation between 2500 and 3000 rpm
I have a 335i (8/2007) production 6sp MT. I noticed a hesitation and roughness between 2500 and 3000 rpm under acceleration. There are no SES lights or any other symptoms. The car would accelerate through that range well enough but it was very annoying. It is particularly noticable in 4th through 6th gear. In 1st through 3rd gear the car accelerated too rapily through the rpm range to notice the roughness unless you are looking for it. My car has had the HPFP and all injectors replaced under recall and I paid for new spark plugs about a year ago and it currently has 67K miles on it. Otherwise the car is great.
I had the car scanned and there is a single code stored, (2AAF, Fuel Pump Plausibility). I took it to the dealer and they confirmed my symptoms (I did not tell them that I knew about the 2AAF and the TSB) and said I need a new low pressure fuel pump, the one in tank. I asked my service advisor if they were sure. "Why is it only in that rpm range?" He said the low pressure fuel pump is variable delivery and at that rpm delivery, that is the issue. I said OK but "fuel delivery at 2500-3000 rpm is different at each gear and varies with load on the engine." He said "we are sure that is the problem. I said "OK, do the repair." By the way, the BMW service bulletin says "do not replace low pressure components for 2AAF without testing a lot of other components first." I picked up the car after paying my $700 and started driving it home. After warm up, I started accelerating and the car was still doing the exact same thing. I immediately brought the car back. The dealer has had the car seven days now and just told me today that they have opened a PUMA case with BMWNA. I am reserving my opinion of this dealer until I have the problem resolved. Everyone can make a mistake. I will update the post as soon as I have resolution. Has anyone experienced the same thing? |
Your problem sounds to me like a problem I had with ignition coils. It was a misfire and most evident under heavy load in 3rd or 4th gear around 3k rpm. No codes until later, when the ignition coil went completely south.
I am also having the same problem with my car (2008 335xi 6MT). It happens only at lower RPMs as you stated. It feels like the boost is breaking up under moderate to hard acceleration. I too have had the HPFP and injectors replaced under the recall. Also, no check engine light and otherwise the car runs great. I haven't had a chance to bring it to bring it to the dealer yet and won't be able to for another week or so because I'm leaving for vacation Tuesday. Please keep us posted, I'd love to know the resolution to this issue.
You should be aware that LPFP problems will cause HPFP self destruct over time. Very interested in final resolution! Could be as simple as a dirty filter....
Yes, The LPFP was replaced.
I just had an injector replaced last week. Now mine is also hesitating between 2500 and 3500 rpm under highway load acceleration. It won't do it in 1st or second gear when I'm pulling out.
'09 335i xDrive Coupe - Space Grey / Black Leather / Alum. Trim / Sport / Premium / 18'' wheels / Cold Weather / CA / Nav / iPod / Logic 7 / PPK1 |
1) Fill up with Shell 93 octane or Chevron 93 octane 2) Buy 4 bottles of BMW fuel system cleaner plus (just wait and let me finish) 3) At the first fill up do this: a) put a bottle of fuel system cleaner plus in before filling up the car b) warm up the engine at low RPM and speeds for 20 minutes c) take car onto the interstate and do 70 mph in 3rd gear making sure you are turning at least 4k RPM. d) Do the drive for 30 minutes and then shift to 6th and let the car cool down. 4) Two times a week for the next two-four weeks repeat number three making sure that you are running Shell or Chevron and using a bottle of fuel system cleaner in each tankful until all 4 bottles are gone. I can almost guarantee your hesitation problems will be gone before or by the time all of the fuel system cleaner plus is used up. Once you have corrected the problem maintain the engine by doing my suggestion once a month. This is how I kept my N54's running good.....
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) Last edited by Alpine300ZHP; 01-03-2012 at 12:47 PM. |
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) |
I think I haven't used fuel cleaner enough in this car.
Blubaron. It may be doing it in 1st and second but the engine pulls through that rpm range in less than 1 second making it hard it notice. It is much more noticeable in 4, 5 and 6 because it spends more time in that range.
Alpine, my car idles smooth as silk and runs great at all rpm. The only problem is the one I described on my post. The car even runs smooth at 2500-3000 rpm when cruising. It is only under load that I get the roughness.
I visited my dealer today and talked with the service manager. The car has been there 2 weeks. He told me that the regional engineer from BMW NA was there and they aren't sure what it is yet but are leaning toward the wastegate. I never had the rattling issue but wastegate sounds right to me based on the symptoms. Feels like the boost is dumping in that rpm range. I hope they do a goodwill repair. Even with the class action (wastegate warranty extended 1 year or 12,000 miles) I am screwed. I have 67k on mine. Hopefully they will take into account the fact that they replaced my low pressure fuel pump for $700 and that didn't fix it.
I stopped in last night to grab some fuel system cleaner. The SA said it was carbon build up if I only felt it under light engine load on the highway. She said to run 1 to 2 bottles of cleaner through it, and all should be good. The Westgate would be throwing a SES light, plus 2009 is when BMW started putting the upgraded Westgates on to get rid of any Westgate problems.
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) Last edited by Alpine300ZHP; 01-04-2012 at 01:31 PM. |
Thanks. I'll be pushing the hard a little harder the next few tank fulls.
There is doubt same will clean intake valves where PCV carryover gunks & clunks 'em. $600 dealer walnut shell blast there unless you DIY for dramatically less - a little solvent and a lot o'DIY PITA labor. But...should be no carbon buildup in a stock motor! . Last edited by CALWATERBOY; 01-04-2012 at 06:35 PM. |
I met with my dealer today. I spoke with the service manager and shop foreman. Now they believe it is seals in the "turbo bypass." I can't find that in the parts list unless "turbo bypass" is the wastegate. The jury is still out on the dealer. We'll see. Both the foreman and service manager were courteous. Thats something. Three weeks and counting.
BMW CCA Member |
I haven't ran a full bottle of fuel cleaner through yet, but I'll let you know what happens. I'm only a 1/4 tank through.
Did you do the 4k RPM run yet? If so, any difference?
Actually, yes. Haven't been able to get on the highway as much as I wanted, but it's been doing it a lot less; and with less severity.
You should have opted for a 328 and you wouldn't be posting problems
BMW CCA Member |
Squidget, you are sooooo on the mark. My loaner is a 328. I could have opted for a Toyota Camry too. ;-)
#25
How can you compare a Toyota Camry. Are you guys with 335's on some kind of 335 drug? Both cars drive exactly the same with the same options other than the 335 is a little faster on take off. Big deal. Unless your racing everyday I don't see your point. And if you got it to race, most sports cars will smoke you.
