Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Old 12-28-2011, 06:54 AM
chip4's Avatar
chip4 chip4 is offline
Mein Auto: 2011 X5 35d
Sooty buildup in engine bay
Anyone see something similar to this soot buildup? appears to be coming from in between the EGR cooler and the elbow to the intake, the connection to the EGR cooler appears to be a metal mesh screen, also seems to be leaking from the clamp. I have brought this issue to the SA during my last service -said this was normal, but now I am smelling uncatalized diesel exhaust inside the car at lower speeds. I haved wiped this area with a dry rag about 5k miles ago so it would probably have more buildup. No CEl, just a scheduled Vehicle check reminder. 2011 X5d 25k+ miles mostlly freeway driving in southwest US.
Old 01-01-2012, 04:45 PM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
My engine bay with just shy of 21k miles is remarkably rather clean.
--Aaron
Old 01-01-2012, 05:34 PM
chip4's Avatar
Vehicle is at the dealership, they said it was not clogged they just could not get a good seal in that area, they are replacing the EGR cooler, elbow, clamp and something else they are waiting on.
Old 01-02-2012, 07:42 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Definitely NOT normal. Your SA should be spanked, then spanked again
Old 01-02-2012, 07:46 PM
Spanking them would result in a lot less jail time than shooting them.
--Aaron
Old 01-02-2012, 07:50 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Noted and edited.
Old 01-02-2012, 09:22 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
They may even enjoy it.
Old 01-05-2012, 06:06 PM
chip4's Avatar
Dam did this thread get hijacked?
Anyway the dealer replaced:
EGR cooler
Clamp
Torx bolt
Charge air line
They noted that the pipe between the cooler and the throttle was cracked. During the test drive the charge air line between the intercooler and the throttle blew off damaging the charge air pipe.
Apparently there was also a recall done -they replaced the Charge air temp sensor per SIB. They installed Temperature Sensor 13 62 8 519 444.
