Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 03-30-2011, 11:44 AM
M3GTtt M3GTtt is offline
Mein Auto: 1995 E36 M3 GT (EURO)
1995 E36 M3 GT Twin Turbo
Hi guys, this is the follow-up from the introducton thread
Its one of the 350 Euro GT cars, mine is number 111.
Engine is the S50B30 ITB Single vanos, with S50B32 upgraded intake manifold and lubrication system.
Here is part nr 1 http://www.bimmerfest.com/forums/sho...d.php?t=530785
By this stage the suspention was sorted, the ceramic brakes and various other stuff.. but I wanted more power..
Early 2008 I started with the install of the Twin Turbo system on stock internals. As I said the system was not a perfect design, but it was designed to run at 8psi, i ran it at 11psi. The exhaust manifolds were terrible, and made a strange engine sound, but they did the job for the time beeing.
I was using 440cc injectors and I flew in a expert tuner to tune the original BOSCH DME. The car drove reliable but soon I started to see pressure in the coolant so I upgraded to a MLS 0.140 plus ARP's.
0-200 run on this setup
There was still room for improvement.. and actually the engine (piston rings) were starting to show some wear.. so... why not do a fully built bottom end. Engine went out..
I
bought a set of CP Pistons (8.5:1), some custom made Forged connecting rods, the Walbro 255 and NGK-R 2525-9 plugs. I also got a set of VAC main and rod bearings (coated) and ARP's for the rods.
I also got in contact with a tuner in Sweden where I bought the rods and he had his friend make me a set of Tubular exhaust manifolds.
Somewhere in between I had also bought a SuperSprint De-cat midsection and the OEM X-Brace for the frunt suspention from the Cabrio
The rebuild..
Block with pistons, rods and bearings installed, mirror surface on the block ready for the stock thickness MLS.
Head re-mashined, some porting and plolishing along with new copper valve guides.
The JBRacing lightweight flywheel installed. I did not have the block painted or any of the parts specially cleaned. My car is for driving so it does not really bother me.
Engine almost done. Canio (my Italian mechanic) and my Tuner (also a pretty good engineer/mechanic) working on the engine.
Almost done.. This airbox would later explode on the welds..
Exploded intake manifold... gread build quality.:hihi
So I did like the guys in Sweden do. I modified the OEM intake for Turbo. Much better quality.
The car was tuned with the old airbox. It made 470hp/560nm at Mantehy Racing in Nurburgring. Manthey is one of the best Porsche racing specialists around. The dyno was made using the old airbox.
The car was running 12psi, there were some problems with boost leakage after I installed the OEM airbox, forgot to put the O-rings on the runners... Still, I went to SPA Francorchamps in May 2009 where the car performed well, lapping a 2:50 which is respectable for a road car. I also had installed a S2.65 differential from a 325TDS and that made the gears very tall. Potential top speed of 340km/h doing 280 in 4th. Surely not optimal for track driving... Still, I had some CSL for Lunch. (min 2:40)
http://www.youtube.com/user/farturinn#p/u/3/LMVKM0OUnP0
In the lates rebuild I had installed a Gizzmo electronic boostcontroler... that made me a bit greedy so I started pushing up the boost. Going up to 22psi. The AFR's looked ok, and so did the EGT, but something went wrong. The coolant started to pressurise in summer of 2010 so the only option was to rebuild the engine again. This time around I decided to do all the work myself. Keep in mind that I have no mechanical training or experience. I work in Private Banking..
When the engine came apart it was quite obvious that the headgasket was blown... quite badly actually for an MLS. I along with some of my friends started speculating what had gone wrong. Most likely it was due to detonation, which resulted in me beeing to agressive on the boost and the car probably running out fo fuel at the top end since the injectors were only 440cc. Still I was running almost 4.5Bar of fuel pressure.
HG badness...
This time around I decided to go with a STOCK HeadGasket from BMW and I also upgraded to ARP2000 bolts.
Head off and pistons cleaned
It was a strugle to get the head on since I was doing the job alone, I bought an engine crane and that helped.
Head on.
I also put some thermal insulation on the engine bay.
I also thermal wrapped the downpipes.
Since I had no previous experience the timing of the cams and valve adjustments were a pain in the neck. But I managed.
Almost done.. again
The RC750 injectors went in along with the Moristech Piggyback (installed it myself) and the Knock link Knock detector.
The car started up ! I was pretty happy. Drove it for 3 days and then no boost, and a terrible sound coming from the turbo area. I inspected the engine, found a busted hose from the airbox to the ICV and also I had made a small mistake when installing the Airbox. I had actually managed to clamp the oil feed line to one of the turbos which resulted in oil starvation to it and it was gone....
http://www.youtube.com/user/farturinn#p/u/0/H612rlMcn0c
Pretty depressing, since its not that easy to access a bottom mount twin turbo system. Still, I bought two new GT2252's and re-designed the oil feed system. Intstalled and I had power again.
I re-designed the oil-feed lines and installed two new Garrett's
The car ran great, power was plenty at 14psi (minimum PSI)
I also installed a new water pump, fan-clutch, oil catch can, Denso Iridium plugs, painted the RC's white, and am currently installing a 2.93 Differential which will get the LSD unit from the S2.65.
Other mods I have done/am doing include the seats which I changed to Recaro Pole Position with some custom stiching and painted the BBS RC wheels white.
Seats:
Sticker:
White RC's
Engine bay, looking OEM as I want it to look. No fancy stuff showing.
Its been a labour of love and some hate, frustration and enjoyment but it has cost me alot of money. At this stage I was happy with the car. I have something a bit special, its fast and reliable and I have rebuilt the engine (top end) myself so that gives me more pleasure when I drive it. But while beeing tuned in the UK the engine blew (on or after the dyno session) and now I need to rebuild the engine.
As I said if you have the time, plese go on my Facebook link http://www.facebook.com/pages/BMW-E3...20153618061202
and hit the like button. You will be doing me a big favor.
Photo Albums
http://myndasafn.bmwkraftur.is/v/med...fart/Rebuild2/
http://myndasafn.bmwkraftur.is/v/med...fart/overhaul/
http://myndasafn.bmwkraftur.is/v/medlimir/fart/GTnew/
http://myndasafn.bmwkraftur.is/v/medlimir/fart/GT_2/
http://myndasafn.bmwkraftur.is/v/medlimir/fart/GT+new/
http://myndasafn.bmwkraftur.is/v/medlimir/fart/GT/
Old 03-30-2011, 06:57 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Oh my goodness, you are my HERO!
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-30-2011, 07:12 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
Cool story bro! And I'm not being sarcastic! That's awesome stuff.
-CJ
Old 03-30-2011, 07:21 PM
drive by72's Avatar
drive by72 drive by72 is online now
I feed trolls
Mein Auto: 3 series
I needs new panties
RIP Ben "Jever" Doebele, we wont forget you
Hi, I'm Chad. Talk to me or GFY
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things!
1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Old 03-31-2011, 12:02 AM
Thanks for the comments guys
I hope to have something more to report soon, as the engine should come out this weekend and then we will see the extent of the damage.
Old 03-31-2011, 12:09 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Wowzers. Quite an ambitious and awesome build.
1998 BMW 328is
1966 Pontiac GTO
Old 03-31-2011, 01:42 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
Wow... I think we should hang out sometime
Old 05-12-2011, 06:11 AM
A small update. A replacement engine block has been bought and also a replacement cylinder head.
We decided to buy a combination of S50B32 engine block and head.
The B32 head has bigger exhaust valves and slimmer valve stems than the B30
The B32 block has a standard bore of 86.4mm compared to the B30's 86mm
The result will be a hybrid of a B30 and B32 Euro motors.
S50B32 cylinder head with the B30GT cams and single vanos from the B30
S50B32 engine blcok with forged 86.5mm B30 pistons, forged JAWS B30 rods and B30 crankshaft creating 3.0L displacement
So a 3.0L S50B32 single vanos..
Old 05-19-2011, 04:01 PM
godora102192 godora102192 is offline
Mein Auto: 1995 Avus Blue M3
****ING DROOOOOOOOOOOOOOOL !!!! That is amazingggg !
Old 06-27-2011, 12:48 AM
Pistons have arrived. It's always fun to have new shiny stuff. Big thatnks to Erics Performance Parts on Ebay for their quick and effective service.
CP packaging always impressing
I will forward them to H T Howard and Co in the UK where the replacement block (B32 from B30) will be rebored to 86.5mm (0.1mm overbore). Then its off to Motorworx Marlow for the final assembly
Old 06-27-2011, 07:27 AM
crisscross's Avatar
Amazing
-Alan
Old 09-06-2011, 12:41 AM
Engine build has started!
Comparison of the 2008 Forged CP 8.5:1 pistons and the 2011 version of the same producst
Oil squirters marked from 1-6
Crankshaft is in
Rings gaped and pistons ready for install, just waiting for some new rod bearings
Old 09-06-2011, 09:16 AM
A white m3 A white m3 is offline
Mein Auto: 98 ///M3
Oh yes, this car... is amazing.
TRM
Old 11-24-2011, 04:04 AM
Its running again,
Hopefully on the streets next weekend
Old 11-29-2011, 02:26 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
oh my god
great work and what a beautiful car
keep it up I know my e36 wishes I loved it as much as you love yours
Turbo lag is actually a headstart to make it fair
Old 12-12-2011, 04:31 AM
So the Dyno session is done and I am pretty happy with the results. There were no expectations on massive top end numbers but rather that we had power almost anywhere in the rev-range.
Low boost setup is around 0.75Bar through the revs.
Max HP is 442 and the car is basically at 440hp at 6000rpm
Max Torque is 431ftlbs (580nm) but at below 4000rpm.
Dyno sheet:
High boost setting is climbing to 1.2Bar at max torque, then dropping to about 1.0Bar at the high rpm's. Reason for this is the buildup of backpressure and the turbos run out of breath. Also, the torque had to be limited to below 500ftlbs because the clutch started slipping, even with a clutch that is supposed to be rated 700nm.
Max HP is 488.1hp (or 490) at 6300rpm (rev limiter set at 7200rpm)
Max Torque is limited to 489.4ftlbs but delivered at c.a. 3.700rpm!
At 3000rpm the car is making more power now that it did at the redline when it came out of the factory
Dyno sheet:
Old 12-12-2011, 05:04 AM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
yummy!!
and if i read correctly, this latest incarnation is a twin turbo single vanos motor
woo hoo!!
btw, what did you do with the old 'log style' manifolds...
df
Old 12-12-2011, 05:08 AM
Originally Posted by drivinfaster View Post
yummy!!
woo hoo!!
df
The Log style manifolds are somewhere in Sweden.
The car was a twin turbo Single vanos beofre but this time around I have full adjustability of the VANOS through the VEMS ECU.
Old 12-21-2011, 10:55 AM
MikoPr MikoPr is offline
Miko
Mein Auto: 325IS
Here is what I would like to know. How can I get those exhaust and intake manifolds. That would make my current project so much easier?
If I have to get them shipped from Germany I dont care just dont even know where to start looking.
Miko
1995 325iS <--- Problem Child
1979 Pontiac Trams Am TT
Bruce Fulper Powered Fuel Injected 455
1967 GTO
2004 GTO 6.0
Old 01-05-2012, 07:20 AM
Intake manifold is the Original one, just modified for Turbo
Exhaust manifolds are a custom build, made by JAWS Motorsport in Sweden.
Old 01-06-2012, 07:10 AM
JAM3S JAM3S is offline
Mein Auto: E36 M3 Evolution
big fan of your car, do you have more close up pics of the turbo manifolds and dump pipe to your exhaust?
Old 01-12-2012, 02:59 AM
here are some
Old 01-12-2012, 04:08 AM
How to spend Christmas and the new year
Got my car back on the 16th of December from itīs 11 month stay in the UK. Unfortunatly upon arrival it was not compleate or at least good enough by my standards, so I deceded to pull the engine out. There were two gaskets missing from the rear turbo which could not be accessed with the engine in.
Also the Crankcase went was not routed the right way and had blown out the valvecover gasket and spilled oil everywhere.
Since the engine came out I decided to paint the engine bay. I started off by fixing some of the damage, sanding down and so on, but did not want to use filler and I don't know how to weld. After the first layer of piant (with a professional gun) I saw that the glossy effect would not really bring out the best of the damages on some of the panels, so I shot 2 coats of flat clear coat.
However, I did not like the flat finish on the struts so I went back to glossy for the struts, which ended of being a semi glossy finish. I kinda like the result, specially after the install of the motor.
Let the fun begin.. December 17th.. My first ever "engine out" operation. Remember that I am not a mechanic Extensive use of Ziplock bags and painters tape to mark everything..
Engine comes out on December 18th. Got some help from a local friend! My 9year old daughter on the camera
Me:
Ready for some treatment...
Since I had access.. why not paint!
Old 01-12-2012, 04:09 AM
This is where the valvecover gasket had blown out of its place due to crankcase pressure.
The reason why the engine came out, missing gasket on the downpipe, also missing a gasket on the exhaust hausing....
Looking forward to the install
Biggest Xmas packet in my house! December 22nd.
Primed:
Painted:
The gun.
3 coats of paint.. looks good but the pictures donīt really catch the imperfections on the fenders.. Custom stickers also in place
Flat finish.. too flat in my opinion..
Finished article, semi glossy struts, with Flat/matte finish on the rest. I raelly like it.
Old 01-12-2012, 04:10 AM
Motor back in place on the 26th
Face back on the car, waiting for a new front windshield.
VEMS in place and the MAP sensor hose going through the lid, so I can now close it properly
Catch can fastined, and the vent now routed into the air intake pipe, before the front turbo and after the KN cone.
I also used the opertunity since painting to cut a bit from the inside fender to be able to fit 3" intercooler piping.
Also installed a Z3 shifter which is a great addition! Amazing feel.
Flushed the brake system and put a new batch of ATE super blue racing fluid, also change the oil to the Castrol M-approved 10W-60
I also had a broken front windshield so I had that replaced on the 29th.
My assistants in the garage.
Supersprint exhaust installed, this is a new upgrade.
