Old 01-06-2012, 05:34 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
Just got the ABS sensor repaired.
Also did O2 sensors. Both at 120k.
Next up, fuel filter!
Old 01-06-2012, 06:16 PM
GEinfeldt GEinfeldt is offline
Mein Auto: 528i
1 new radiator
2 new abs module
3 got hit behind drivers side rear door
4 snow tires on my old rims
5 removed all cup holders
6 installed led lights underneath the outside door handle
7 oil change
8 replaced 99% of all lights with led
soonish....
1 sway bars front and rear
2 m5 style mirrors
3 exhaust
4 suspension
5 possibly get CAI
6 sports ecu
Old 01-06-2012, 06:18 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
VCG's + Plugs = Royal PITA (VCGS, not plugs)
Old 01-06-2012, 07:51 PM
hqstu hqstu is offline
Mein Auto: 03 530i MS
Since aquiring my 530 a few months ago @122k km:
Thermostat, waterpump, oil filter housing gasket, VCG, power steer hose clamps, general service - NZ$1300.
Fixed right rear door vapour barrier - $0.
Replaced right front underskirt thingy (with temp sensor in it) - $330.
Replaced cabin filters - $110. Solved "gym sock pong" with mould killer $15.
Experimented with LED AE's - looked stupid... $70. Reverted to stock halo's.
Adjusted park brake - as good as it will get... $0.
Euro shaped plates - a huge rip off...
The ABS module had just been replaced by previous owner, as had the tyres and spark plugs.
To do:
Transmission fluid replace. (no issues though)
Repaint of front end, polish headlights.
Check out suspension components (no issues though)
Cheers
Stuart NZ
Old 01-06-2012, 08:13 PM
aspensilver540 aspensilver540 is offline
Mein Auto: 1997 540i
Depo smoked sidemarkers.
Old 01-06-2012, 08:24 PM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
I put gas in my bimmer a few days ago.
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 01-06-2012, 09:32 PM
ztitans1 ztitans1 is offline
Mein Auto: 1997 528
In the past few months:
1) Replaced CCV and hoses.
2) Replaced plugs.
3) A/C Final Stage Resistor (twice)
4) Replaced blower motor (discovered initial FSR was defective - motor still good).
5) Replaced flex disc.
6) Replaced Front brake pads and rotors.
7) Replaced ignition coil & new plugs.
8) Replaced Cam Shaft Position Sensor.
9) Oil & Filter Change.
10) Transmission Filter & Fluid w/ pan gasket.
11) Replaced broken drivers side outside door handle.
12) Replaced driver door window regulator - broke again.
13) Repaired trunk lid latch.
14) Repaired frayed wires at trunk lid.
15) Repaired leaky power steering hoses & cleaned PS reservoir.
16) Replaced leaky air pump hose.
17) Replaced serpentine belt & broken tensioner.
Need to do:
1) Repair sunroof.
2) Get new tires.
3) Air pump replacement (whines in the AM)
4) Fix broken switch to driver's side seat.
5) Fix both driver's side window regulators (need to replace gear in motor this time).
6) Would like to fix dent in hood and rear passenger door.
7) Go through suspension and repair as necessary.
8) Find source of leak near rear gear box and repair.
I just love this logo...
Old 01-06-2012, 09:37 PM
Mein Auto: 1997 528
Oh yeah. I also replaced the fuel filter and the front cup holder.
Add to needs list:
9) decent floor mats.
10) replace rear A/C vent & cup holder.
11) fix windshield wipers (come to rest in middle of windshield).
12) replace front windshield rubber trim (looks like crap).
13) get a replacement center cap that is missing. If you took mine, please return it no questions asked...:-)
Old 01-06-2012, 10:14 PM
POof540i's Avatar
POof540i POof540i is offline
^^^Worst Username Ever!
Mein Auto: '01 540iA
Since August 2010 I've had the tranny rebuilt, installed new shocks and replaced the windshield wiper cowl. I still have a plethora of items to tend to.
"The more you know, the more you don't know," Dave Chappelle
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant
WTT: Black Comfort Seats for Black Sport Seats. PM for info.
Old 01-06-2012, 11:38 PM
cclcal cclcal is offline
Mein Auto: 525iT
'03 525iT 130K miles
Installed 6 NGK 3199 spark plugs. Easy to do thanks to all the info here.
Replaced one high beam bulb (H7)
Added a quart of Mobil 1.
Still need to do:
Change ignition coil(s) if misfires continue.
Check fuel filter...
Change thermostat
Diagnosis why DSC light is always on.
Constantly check on radiator. So far so good.
Change out cracked windshield
Repair tailgate struts, 2x4 is working fine though.
Old 01-07-2012, 04:22 PM
E39 touring E39 touring is offline
Mein Auto: BMW e39
More done
Repaired rh side rear window drive,easy but a bit of time involved.
Adjusted lh side door handle,new cable on order.
To do;
Fuel tank level sensor (this will be third time)
Get A/C tested @ friends company
Old 01-07-2012, 04:42 PM
freethrowdunk freethrowdunk is offline
Banned
Mein Auto: '03 525i
Just today: valve cover gasket:
Old 01-07-2012, 04:50 PM
Today:
Replaced MAF sensor ($150)
Replaced Hood Emblem ($30)
Replaced Wipers ($35)
Replaced Power Steering Reservoir O-ring ($1.50)
Put on snow tires! ($400 used OEM wheels, $200 used snow tires, $42 mounting)
Old 11-08-2012, 03:14 PM
xxthr4sh3rxx xxthr4sh3rxx is offline
Mein Auto: 2000 BMW 528i
I would die without my car for 9 weeks -_-
Stuff I've done
-New waterpump
-0w30 Oilchange w/oem filter
-New NGK Platinum x6
-New Bremi Sparkplug connector boots x6
-New Upper / Lower Intake boots
-Cleaned MAF
Stuff I need to do...
-VANOS via Dr. Vanos
-Bilstien shocks / struts
-Change Fuel Filter (any suggestions as to good brands??? was thinking Mahle but dont know if it's any good...)
-Dremel surface rust away, repaint with code 354 titanium silver
-Oil spray (the snow's a comin gents)
-Swap to winter tires
-New hingless wiper blades....
Old 11-08-2012, 05:22 PM
Mein Auto: BMW e39
Spent a bit lately ,some work done by myself but most done by a local Hungarian guy (good man) and he has a hoist;
Middle control arms rear suspension,
Front disk pads and sensor,
New front engine belt (the long one) and idler,
Front swaybar links,
Front cup holder,
interior door handle,
2 x rear tyres 235/45/17
Relacement intank pump and level sensor.
To do:
Oil filter change
Fix lh side front seat surround plastic trim (again)
This is the first real expediture on the car @ around 246,000kms so I'am pretty happy with it .
Old 11-08-2012, 07:52 PM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
Mein Auto: 2003 530i
in the past couple of weeks...
MID pixels repaired
new windshield and weather trim
rear hd bilsteins
fabric glue on interior pillars that were sagging
canceled transmission drain at 170k hopefully i can just rebuild it correctly one day
considering removing tints and installing ddm HID fog lights. Wheel bearings, ccv and front meyle hd sway bar links on deck.
Old 11-08-2012, 09:09 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Bosch plat 4 plugs
OS11 sensor
Hood Bowden cable
Center brake light
Old 11-08-2012, 09:23 PM
salesman salesman is offline
Mein Auto: Acura CL-S
yellow fog light housings installed and took off HID kit. i had yellow lamin-x on my old housings but didn't like the look since you could still see some of the clear on the edges. as for the removal of HID...i could never get 3000k bulbs to look quite right (morimoto 3000k bulbs looked too green even with yellow film), it was interfering with my ambient temperature sensor somehow, and i keep reading about how HID fog lights actually make visibility in heavy fog WORSE. plus i don't like blinding other drivers. the new fogs look AWESOME and i'm just using the regular bulbs that came with them. no need to put in my yellow nokyas
edit: forgot to mention i have a leaking heater hose on the passenger side near the firewall, luckily it only leaks when the heater is on since my control valve is fine. and the day after that happened, my hood release cable broke. excellent timing. today i took the handle off and took apart my lower dash, but the cable was so messed up i couldn't pull it with pliers. then i tried the method through the kidney grill and the junction box is so dried up i couldn't get it to budge. i don't have a new cable yet so i'll wait for that to come in and then replace it. then i'll lube everything up so nothing else brakes. so guys...KEEP YOUR HOOD RELEASE CABLE LUBED PROPERLY
1999 BMW 540i/6 - Eibach ProKit - E60 SSK - ZHP knob - DJ Autos/FX-Rs/Orion V2s - HID Fogs - M5 front bumper - muffler delete - 19" LM reps
Old 11-08-2012, 09:46 PM
blingin96's Avatar
blingin96 blingin96 is offline
Mein Auto: e39 540i , E36 328i
I did the Mtech front and rear bumper upgrade. With AC SHCNITZER rear roof wing, M5 rear spoiler, AC Schnitzer front spoilers, Sink drain front air scoops, AE's (and had to make my own wiring) . Even managed to paint the roof top gloss black. Next up is to start cutting up my trunk.
ID:	348825   Click image for larger version
ID:	348826   Click image for larger version
ID:	348827   Click image for larger version
ID:	348828   Click image for larger version
Old 11-08-2012, 09:47 PM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
Installed CCFL angel eyes on my touring today.
Old 11-08-2012, 10:24 PM
Sumotide17 Sumotide17 is offline
Mein Auto: 2001 540I/6 Sport
2001 540I/6 M-Sport
95K Miles
10/2012:
Valley Pan Job
Rear Intake Manifold
Front Intake Gasket
Replaced Air Filter
This Weekend:
Replace Spark Plugs; It already had NGK 3199 but they were all burnt. Replacing with NGK 3199.
Valve Cover Cover Gasket (probably just do Bank 2);
Diagnose cause of idle fluctuation (build smoke machine).
Old 11-09-2012, 06:01 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
I got my touring last month and I've done a lot so far, but still have a lot to do.
Done:
radiator
water pump
expansion tank, cap, and brass bleeder screw from OEMbimmerparts
upper & lower rad hoses with temp sensor
valve cover gasket
fuel filter
BMW all-weather mats
replaced broken cupholder, will not use it, but I hate broken things
differential oil
engine oil & filter
air filter
cabin air filters
attempted alignment (one front tie rod seized)
replaced cargo are battery hatch (originally one had broken latch)
removed 17" Style 5 wheels, replaced with 16" Style 82
replaced passenger seatbelt tensioner (airbag light)
secondary air pump valve and vacuum line replaced (CEL)
both front door seals
reprogrammed car-key memory for DRLs and drive-away locking
Still to do:
front suspension rebuild (control arms, thrust arms, tie rods, end links - fine for now, but grease boots are split open)
rear subframe bushings
crankcase vent valve and hoses
VANOS rebuild (although I think it's OK for now)
DISA rebuild
angel eye LED bulbs (just the bulbs, not the whole ring)
tires
retrofit heated steering wheel (maybe for next winter - more pressing issues right now)
lower engine shield and front fender liners (cracked, but functional for now)
Old 11-09-2012, 01:46 PM
senser senser is offline
Mein Auto: 540i/6 E39
Done:
Oil change - 0W40 Mobil 1
New intake filter - AFE oiled
Cleaned MAF - CRC MAF Spray
Added rear decklid spoiler
Brake fluid change
NEW KEY - YAY!
Dusted it off today since I won't be taking it out of the garage. DAMN YOU SNOW!
Ordered new AE LED bulbs
Future jobs:
Cut scuba tanks, replace with downturn.
Front thrust arm bushings
valve cover gaskets and seal washers
camshaft solenoid gasket
M62TU VANOS seal rebuild from Beisan Systems
Timing chain guide replacement.
Valley pan gasket replacement.
M-Tech bumper conversions
Old 11-09-2012, 04:51 PM
Banned
Mein Auto: '03 525i
I "Glossified" the kidney grills. They were already flat black, but in order to utilize Plast-Dip's Glossifier, you need to have a base consisting of something Plasti-Dip'd. After five or six coats of the Glossfier though, I wasn't getting the glossy look I wanted so I let it dry overnight and this morning added a couple of coats of Duplicolor clear coat on top of the Glossifier layers. The end result is pleasing:
Old 11-10-2012, 05:34 AM
BeavesBimmer BeavesBimmer is offline
Mein Auto: 2000 540i/6
2000 540/6 with 130,000 on the clock.
Past Month
1. New Radiator with fresh fluid
2. Both belts replaced (removed belts in trunk for backup)
3. New gas cap
4. 3M Headlight Restoration Kit
5. Clean Oil
Past 4 Month
1. New tire (90 mph blowout!)
2. Sway bars
3. Control arms
4. Really just the entire front end, had my indie do it
5. New shift knob
Need to Do ASAP!
1. VCG/VANOS (smell oil burn daily!)
2. 4 new tires all around (235/255)
3. Fix interior trim pieces
4. Rear bumper re-paint
5. Alignment
6. Rear window regulators
7. Spark Plugs
8. Tranny fluid flush
9. I am sure there is more!
