Old 08-04-2009, 11:08 AM
LMSenus LMSenus is offline
Mein Auto: 2003 BMW 530i
Checked my oil last night, it's down just a hair (now at the bottom of the upper notch in the dipstick).
Old 08-04-2009, 12:43 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Let's keep monitoring. You know the mileage when you filled up to the base line, right?
How many miles so far from the fill up?
mw
MatWiz
"Seeing is not believing. Believing is seeing." -Judy the Elf
Old 01-09-2012, 09:38 PM
ericwgreen ericwgreen is offline
Mein Auto: 2003 E39 530i
low oil level
I got the "low oil level" warning today, and checked it. Sure enough it was on the lower section of the dipstick. It has been about 3,500 miles since the last oil change. I added about half a quart of oil and now it is showing closer to the top of the dipstick indicator.
Should I be concerned with burning around 1/3 of a quart after 3,500 miles?
Old 01-10-2012, 07:31 AM
rdl rdl is online now
Mein Auto: 530i 2003
So you're getting 10,500 miles / quart. Based on threads here and other forums that I've read for M52/M54 oil consumption your result is well within the normal/good range for the M54B30 engine in your car.
You may be interested to hear that BMW's TIS specifies "For BMW spark-ignition and diesel engines the maximum permissible oil consumption is 0.7 litres / 1000 km" which converts to 936 miles / quart. For M engines the standard is 1.5 litres / 1000 km, (437 miles / quart) due to their "increased power output and torque" which I take to be the M3, M5, etc. vehicles rather than the M52/M54 series engines.
Not a very difficult standard to meet, is it?
Regards
RDL
Old 01-10-2012, 07:39 AM
AnotherGeezer's Avatar
Hofmeister Kink
Mein Auto: 2003 530i/5
Mine runs around 6k per quart, well within normal limits.
BMWCCA # 430911
Old 01-10-2012, 12:27 PM
I was surprised that a search for "oil consumption" in the bestlinks only found this one other thread:
- Oil consumption - mitigation of the PROBLEM (i6)
So, I'm adding this thread so that others will find this information in the future more easily.
Old 11-14-2012, 08:21 PM
LalaRay's Avatar
LalaRay LalaRay is online now
Boosted
Mein Auto: 03 ///M5
Originally Posted by Darkflame808 View Post
Gotta give it to BMW to put sensors in many forgettable areas.
I think it would be funny to have a *DING* and your High OBC says
"You forgot to check your oil. Engine seized. You fail!"
Originally Posted by M///Chook View Post
It'd be funnier if the OBC goes *DING* and simply says "You fail" at random, inopportune moments
2003 ///M5. ~ Jet Black/ Le Mans Blue
Supersprint Headers, AFE intake, Evolve Alpha N Tune, ST coilovers, Eibach Rear Sway bar, Beast Power Brackets, Drilled slotted Rotors, Akebono Euro pads, Brake Duct's Grill, Magnaflow 14816 Mufflers
_____________________________
Old 11-15-2012, 08:41 AM
abanjableu's Avatar
abanjableu abanjableu is online now
Mein Auto: 02 540/74 911/01 Z3(hers)
Originally Posted by 99Bimmer528i View Post
one thing is dont treat it like a 78 dodge... Do the oil change and then get the oil light reset done. I havent done mine for 2 years and it still says i need a oil change. But i know i just did it. The Oil change light are stupid they just cost you money to reset them...
Reset it yourself...it takes all of 30 seconds.
