Old 05-04-2011, 01:39 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Wow. Feedback from the man himself! Many thanks Bob !
p.s. The only one I'm aware of is the Zionsville. Are there other versions of the alum housing?
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 05-04-2011, 01:52 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
The man? Hahaa, just to be clear, Mack, I'm not the guy in the video. I found it on You Tube, thought it was great, and posted here.
Old 05-04-2011, 05:06 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
my cooling system was replaced by the first owner just a few years after it was brand new... in 05... ive got the tank in my hand for this weekend... but ill be doing the rad also in the next few months..
then ill be eye'n that aluminum setup i can easily justify a grand for a rad and tank that will outlast us all...
15486372<-----
Old 07-04-2011, 10:53 AM
mifesto mifesto is offline
Mein Auto: m3
so what is the purpose of that plastic pin in the radiator fins????
few days ago i was shocked that some foreign plastic is stuck in the fins. to my horror it wouldnt come out so i got off the top (tiny bit of the plastic end still in there) and it stressed me out a ton because i spend a ton to refresh my suspension and cant spend another grand to redo all the coolant components....
this piece freaks me out considering the "fragility" of the oem radiator....
Old 07-04-2011, 12:08 PM
Dunno. There 'was' a thread specifically on that pin somewhere. Somebody came up with the suggestion it's some sort of factory inventory code.
It's not on the replacement radiators; so, for us, it only serves as a reminder of an original radiator (something very dangerous at this point in time of the E39 build cycle).
Why? It's not functional.
In fact, the aluminum part of the admittedly fragile Behr/Nissens radiator is actually quite robust. See details here:
- Behr radiator and Behr/Heat expansion tank autopsy (1) (2)
Old 01-11-2012, 06:30 PM
Here's another date-stamp clue from this thread today:
- E39 (1997 - 2003) > Genuine BMW Expansion Tank
Originally Posted by uncmozo View Post
Notice z168's BMW expansion tank has the date code and the aftermarket one doesn't. The date code is the round circle with the '10' inside -'2010'. The dots around the edge of the circle represent months - 8 dots = August. The machine operator adds a punch mark in the mold at the start of each new month. So, this tank was manufactured in August of 2010. The tank from gibo58 was manufactured in November 0f 2009. This allows for trace-ability of defective parts.
ID:	307945   Click image for larger version
ID:	307946   Click image for larger version
Old 01-11-2012, 06:35 PM
Old 01-15-2012, 10:40 AM
By way of cross reference, a wonderful set of pictures was taken today of cooling system parts removed from an E39 that are relevant to determining the dates of all your cooling system parts:
- E39 (1997 - 2003) > manufacture dates on components'
From these date codes, the OP determined:
  • Expansion tank (was original)
  • Thermostat (had been replaced)
  • Water pump (was original)
  • Water pump pulley (had been replaced)
ID:	308312   Click image for larger version
ID:	308313   Click image for larger version
ID:	308314   Click image for larger version
Last edited by bluebee; 01-15-2012 at 10:48 AM. Reason: Added the pictures, rotated, & resized to 640x480 pixels, for posterity (since picture sites die).
Old 01-15-2012, 11:07 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Awesome as always B.
Old 01-16-2012, 08:37 AM
jcbmw jcbmw is offline
Mein Auto: 97 bmw 528i
Am I just lucky?
I have a 97 528i looks like still have the original cooling system working at 124K mile. I got the car 3 and half years ago at 99K without knowing much about it. The car had three POs and no service record. It has been problem free for more than 3 years and recently the starter failed and also some oil leak from valve cover. I started to read in this forum and was able to replace the starter and the valve cover gasket myself thanks to the information here. Now the cooling system is making me awake at night. The more I read this forum, the more I worried. The car does not overheat but all components of the cooling system appears to be original. The radiator label does not have a date on it, but I appears still to be original based the information I read here. The upper radiator hose has a 97 marker on it. I have no idea on the thermostat and water pump but the coolant in the expansion tank is very very dirty. It is cloudy and looks like brown or rusty. I plan to do a complete system overhaul when the weather getting a little bit warmer.
Old 01-16-2012, 12:29 PM
Turbo_525 Turbo_525 is offline
Mein Auto: 2002 525i 5-spd
Just shot a photo of my date coded OEM radiator label. Here it is: "29/04/02" So with 135,000 miles and just under 10 years, I may be in the running for longest-lived OEM Behr cooling system.
Now - I need to start procuring new parts, as by all accounts I am living on Way-borrowed time!!
Old 01-16-2012, 02:15 PM
I agree, man. Order that new radiator STAT! Other parts are probably just as old.
Old 01-16-2012, 02:26 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
How can I tell how old my cooling system is?
When driving, if you start seeing hot, dirty antifreeze shooting over your left shoulder, it's too old.
Old 01-16-2012, 03:15 PM
jbarrow22 jbarrow22 is offline
Mein Auto: 1997 E39
I too have what I think is an original first year radiator and expansion tank (if the green canister in the attached photos is the expansion tank). The radiator sticker has no date. The green canister has "96" in a raised plastic circle. Also, as bluebee pointed out using a photo, my radiator has a white plastic plug on the engine side of the radiator about six inches up from the bottom.
The car is at 137,000 miles and 15 years. I need to get these vintage pieces replaced!
ID:	308447   Click image for larger version
ID:	308448   Click image for larger version
Old 01-16-2012, 04:40 PM
Ninety-8 E3nine Ninety-8 E3nine is offline
Mein Auto: 98 528I
I may have all of you beat on this one. I've had the car (98 528I) for about a month and a half now and my mechanic told me the radiator was still fine. That is until I saw this thread and wondered so I had to check, the radiator I have is still the original. Look at the picture, on the yellow tag I believe it states 10 12 97. I will certailny replace this radiator in Feb (once the funds come in) with the hoses and expansion tank (I believe its all original)
The car came with aluminum thermostat so I'm assuming the previous owner replaced it and I just replaced the water pump.
After the radiator gets changed, I should be able to sleep well at night.
Thank you all for the info on this one.
Old 01-17-2012, 10:24 PM
Trebbia's Avatar
Trebbia Trebbia is offline
Mein Auto: BMW E39 I6
I don't see that in the picgture.
Is it in the punched holes?
Old 01-18-2012, 10:05 AM
Mein Auto: 98 528I
Its the yellow sticker on the bottom. The date is perforated.
Old 01-18-2012, 10:29 AM
jbarrow22 - I think if you snap a close up of your yellow sticker - as Ninety-8 E3nine did you may be able to see through the perforations your actual build date.
Yes, I agree, you two both have me beat! But I'm starting to search through rockauto and other sites to collect the needed parts. Would rather not wait for a failure!
Old 01-18-2012, 10:40 AM
Mein Auto: 1997 E39
I strained to read the green tag and could not. I'll have to get a smaller camera to snap a closeup.
I called my mechanic, Vladimir, and told him the age of the system and asked about a replacement. His quote was about $600 using Behr/BWM/OEM. All other front-of-engine parts (pulley, tensioners, belts) have been replaced in the past year.
Old 01-18-2012, 10:49 AM
Mein Auto: 98 528I
Turbo 585 - What kind of radiator are you going to get? I'm debating between Behr and Nissens. I found a Nissens for only $136 (I cant remember the website but I'll search it again) but I'm kinda skeptical as to why its so cheap. Maybe too many defects that they want to phase it out?
Do you have any other brands in mind? (Except Zionsville, a little too much for my budget unless theres a cheaper same quality version)
Old 01-18-2012, 11:00 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
They perforate the sticker while it's on the radiator to fully ensure that it will eventually leak on you.
Old 01-18-2012, 01:57 PM
So far have only found Nissens, however I prefer OEM and will keep looking until I find such. I agree Zionsville is the best, but I have to insure I will commit to keeping the car long-term if I go that route. Seems solid enough, it may just be worth the $1200 or so!
Old 01-18-2012, 02:09 PM
OEM radiator
Partsgeek has OEM radiator listed at 171.94 if that is what you are looking for.
Old 02-27-2013, 09:21 PM
This thread discusses the sanded down BMW markings:
Originally Posted by BM109R View Post
I don't know. Did I get played? My expansion tank has a sticker that says 'Made in Germany' and there seems to be an area below sanded down.
Old 02-27-2013, 09:45 PM
H2oallyear H2oallyear is offline
Mein Auto: 1997 528i 5speed
Only 3 items have date stamped on them:
- Radiator: date stamp is usually on passenger's side
- Hoses should have date of mfg on them.
- Fan Clutch date is kind of hard to read in situ because it is behind the fan clutch. Much easier if you remove the Fan Clutch and look at the date.
If you have courage and energy then look up cooling overhaul for V8 by "BlackBMWs" on bimmerforums.
Then Best is to ground the car for a week, remove all the parts in the cooling system for examination. Anything old, order online and replace them.
This way you can sleep well for another 70K or so.
The thermostat has a date code as well. I just had the rad expansion tank and fan clutch changed. I had documentation fron the original owner that the tstat and pump were changed. The mechanic said he checked the tstat and it had a date code of 09/09. Document said it was changed in 2010. Which makes sense Not sure where on the stat to look but it's a very reputable indie BMW shop
