Old 01-20-2012, 10:50 AM
e39munoz e39munoz is offline
Mein Auto: 2003 BMW e39
What is this hose for on the ccv is it important?
what is hose number 6 used for?
i changed the ccv a week ago and i dont remember connecting that hose
Old 01-20-2012, 10:58 AM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i 2005 X3
Hose #6 is not used on the M54 engines. There is a small rubber cap that covers the stem on the CCV. I assume if it is not plugged you would have a small vacuum leak.
Old 01-20-2012, 11:15 AM
Okay I have the m54 i bought the kit to go with it it didn't include the hose I still have high oil consumption
Old 01-20-2012, 11:19 AM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
I don't understand why the CCV does not come with a cap on that port, but I hope you capped it.
Sent from my DROID2 GLOBAL using Bimmer
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-20-2012, 11:37 AM
So I should give it a check and see if it's alright
Old 01-20-2012, 12:59 PM
TA
You may have already done this, but while replacing the CVV, it is important to remove the dipstick tube & thoroughly flush it out. If you do this, buy 2 new orings to go on the dipstick tube because you will almost certainly cut the first oring while trying to reinstall the dipstick. I strongly recommend using oring lube on it. Without it, I found it pretty much impossible to get the dipstick back in.
Old 01-20-2012, 02:30 PM
See also the tons of pictures & discussion about this hose/endcap at:
- Clarification on how the M54 / M52 CCV vacuum port works (1)
