Old 01-22-2012, 10:28 AM
kckc1016 kckc1016 is offline
Mein Auto: 2012 550 xDrive
What type of gas do you fill up with?
Just curious to know if any of you guys put below 93 grade in your 5's. I got a 535 and ive put nothing but 93 in them but seems like some have put 87. Any drawbacks to putting regular in?
2012 550 xDrive
Old 01-22-2012, 10:30 AM
DerStig DerStig is offline
Mein Auto: 2015 F10 M5
Never, 91 at a minimum.
Old 01-22-2012, 10:34 AM
jimefam jimefam is offline
Mein Auto: 2011 550i on order
Always 93 but occasionally when its running super low I'll throw some VP100 or MS109 in there and drive the hell out of it for a while.
Old 01-22-2012, 10:36 AM
scuzzlebutt's Avatar
scuzzlebutt scuzzlebutt is offline
is customizing his 550i
Mein Auto: 2012 550i xDrive DGII
93 at a minimum
Current: 2012 550i xDrive | Dinan Stage II | DGMetallic II | Black Nappa | Anthracite | Convenience | Cold Weather | Driver Assistance | Luxury Seating | M Sport | Premium Sound | ARS | Paddles | Active Cruise | Ceramic | BMW Apps
Current: 2012 X3 2.8 | Space Gray
Retired: 2009 535i xDrive | Jet Black
Retired: 2009 X3 Jet Black
Retired: 2007 530xi | Monaco Blue
Retired: 2003 530i | Sterling Gray
BMWCCA:458650
Old 01-22-2012, 10:53 AM
dunderhi's Avatar
dunderhi dunderhi is offline
Next: '18 AMG GT Roadster
Mein Auto: 15 M6 vert, 15 328dxt
Always 93.
BMWs
2015 M6 Drophead Coupé
2015 328xd Estate
2013 X5M Sport Utility Vehicle
2013 650xi 2 Door Fastback Saloon
2011 Dinan 5 Saloon
2011 335d Saloon
Old 01-22-2012, 10:59 AM
ihumphrey ihumphrey is offline
Mein Auto: 2011 535ix and 2011 X5
Always 93 unless I am somewhere where it is not available...then 91 or 92
Old 01-22-2012, 11:07 AM
PeterC4 PeterC4 is offline
Mein Auto: 535xi,328xiC
If you put in less than the minimum octane level consistently, the check engine light may go on, indicating a fault code has been thrown up....could be P1384 - I've had this happen on my 328 and diagnosed it with by OBD II reader. You will only know this (and what it means) if you have a OBD II reader that can tell you the fault code and re-set it, otherwise the light may just stay on. And it may cost you a trip to the dealer to get it checked out and turned off - and that won't be cheap. Less than minimum octane will ultimately cause engine knock but could affect performance too. Not worth it.
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats, BMS Tune
Old 01-22-2012, 11:25 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
I would never put less than 91 in a turbo engine. Fortunately, we have 93 here.
2011 535i
Sophisto Grau / Oyster - Black Nappa, Anthracite Wood Gone but not forgotten.
Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss.
Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians
Old 01-22-2012, 11:28 AM
Needsdecaf's Avatar
Mein Auto: 2007 MDX
Does the ECU respond well to increased octane? I know that not all engines will advance timing and spark beyond what 93 will allow.
My Volvo R responded VERY well to increased octane levels. Guys would run Torco additive, which worked well but left a reddish film on the tailpipes...which means who knows where else it was leaving a film.
Guys running race gas used to call it "cracktane", lol. The added pull was noticeable.
2011 535i
Old 01-22-2012, 11:31 AM
salamigs salamigs is offline
Can't get 93 here, so 91 it is. Would not put anything less...
Old 01-22-2012, 11:34 AM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
Wow... Our premium is 91, I thought this was good enough... Now, I'm confused hearing so many put 93 in. We only have 93 at very few stations, not to mention the cost...
Old 01-22-2012, 11:35 AM
It does seem to enjoy the race fuel, when the local track opens up I'd like to test and see if it really does add power or if it's a placebo effect but subjectively I'd say it makes a difference.
Old 01-22-2012, 11:44 AM
I am so nice that even when I get a 328 loaner, I put 93 octane.
Old 01-22-2012, 11:47 AM
Needsdecaf's Avatar
Mein Auto: 2007 MDX
Many areas in the US (Western mostly) have 3 grades. 87, 89, 91. Other areas, Eastern mostly, have 87, 89, 93.
2011 535i
Old 01-22-2012, 11:58 AM
Kmdcolo Kmdcolo is offline
Mein Auto: Nissan Armada, e46 330xi
Colorado only offers 85, 87, and 91. Ralph Schomp BMW said 87 works fine because of our elevation, but I only run 91.
Old 01-22-2012, 12:21 PM
If I didn't have 93 octane here, I'd just move.
And no, 87 octane is not okay in these engines!!!!!
Old 01-22-2012, 12:58 PM
Quacker Quacker is offline
Mein Auto: 2012 535i xDrive
Low octane works in a normally aspirated motor at higher altitudes, but not in a turbocharged motor. I'm sure that the car can and will compensate for low octane in that it will not knock, but your performance will suffer.
2012 535ix Space Gray, Cinnamon, SAT, Premium, Prem sound, Cold W., Sunshades, Gloss Black Grille, Gloss Black Side Markers, RE970AS 245/45/19 non-run flats that run very smooth + quiet and also correct the otherwise optimistic speedo
Old 01-22-2012, 01:05 PM
BobRBob's Avatar
BobRBob BobRBob is offline
Mein Auto: 2011 528i
I use 91 consistently. Higher octane is very rare around here. I always use Shell V-Power as it is the only gasoline available that does not contain ethanol.
Current BMW
2011 BMW 528i
Cashmere Silver/Black Dakota
Ash wood trim
Sport Package
Premium Package
Nav
Premium Sound/Sirius
Comfort Seats
Prior BMWs
2001 530i Sport (deceased)
Cosmos Black
Other
2005 Subaru Outback 2.5XT
1977 Corvette 383 Stroker
Old 01-22-2012, 01:27 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
From many previous posts here it seems the car will adjust to lower octane but you won't get the performance you paid for with the BMW.
Maybe more important is to stay with a top tier brand .... http://www.toptiergas.com
From what I've been told by my dealer the worst thing you could do is use a gas with excessive ethanol content.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 01-22-2012, 02:34 PM
Our vpower is 93 here...I thought it had ethanol though, I will have to pay attention at the next fill-up.
Old 01-22-2012, 04:05 PM
miked miked is offline
Mein Auto: 550ix Dark Graphite
Same for me, Shell V-Power 91.
Old 01-22-2012, 04:08 PM
jason60050 jason60050 is offline
Mein Auto: 2011 BMW 535i
Shell vpower 93 or mobil 93
2011 535i, 06/11 Build, Black Sapphire, Black Dakota, Dark Wood, 6mt, PP 1 & 2, Premium Sound, Soft Close Doors, Convenience, Driver Assist, Cold Weather, Nav, SAT, 35% Suntek Tint, BMWPedals, Coded, Xpel Paint Prot.
Old 01-22-2012, 04:46 PM
mrich1353 mrich1353 is offline
Mein Auto: 2013 335I x-drive m-sport
I have one local station with NO ETHANOL 91; if I can't there. by 2nd choice is Shell 93 Octane (has ethanol in my area). Noticed a huge difference in performance with the non-ethanol on my 2010 535I, not quite as much on on the 2011 535I.
2013 335I X-Drive - Alpine White / Coral Dakota / M-Sport / PPK / DHP / Sport Auto / Premium / Cold Weather / Tech / Harmon Kardon / Rear-view Camera / Park Assist
Gone 2011 535I X-Drive - Space Grey / Black Dakota / M-Sport / Sport Automatic with Paddles / Premium I / Premium II/ Cold Weather
Gone 2010 535I - Alpine Wht / Blck Dakota - Sprt, Premium, Cold Weather, Sport auto, Anthracite Liner, Nav, Satellite, HD & I-Pod
Gone - 2006 530XI -
Old 01-22-2012, 05:25 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2014 M5
I use mostly Shell 93 or BP 93.
I prefer to buy pure gasoline as opposed to the 10% ethanol version, but the only places to buy pure gas are Marinas and they aren't really convenient for filling up.
http://pure-gas.org/
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 01-22-2012, 05:37 PM
nhs156 nhs156 is offline
Mein Auto: '10 M5
Your manual should be specific about whether 93 is "recommended" or "required" - there's a crucial difference. For the vast majority of cars these days, onboard electronics are programmed to compensate for lower octane fuel, technically making 93 octane obsolete for all but the highest end of sports cars. Various tests by car mags and consumer organizations have confirmed that lower octane fuel has no/neglible adverse effects (performance, wear, emissions or mpg) on the vast majority of new cars.
That said, I could've sworn I felt a slight performance difference when using 89 and 91 fuel in my wife's Audi (a 3L supercharged engine with 333hp). It was ever so slight, but I could've sworn I felt a tiny difference. That combined with unfounded doubt in my mind, made me switch back to 93. I figured the marginal incremental cost annually of 89 vs 91 vs 93 didn't warrant the lower grade fuel. I only use 93 in the M5, but would be comfortable with lower octane fuel in a non-M BMW if BMW only "recommends" 93.
