Old 01-16-2012, 11:08 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
My cornering lights work when in Auto mode.
So I guess I come back full circle to the taillight bulbs and/or panels, but have learned something cool about my car in the meanwhile.
I was mulling over whether to order the right panel, or both panels, listed in the SIB given by Verts, but I now pause because I think I'll try contacting BMW about a goodwill chance, since the two are $40 before shipping. The SIB states that the replacement panels have bulbs included, but I'm thinking this might have been only for the SIB itself, and not necessarily for the part numbers in the realoem link, also supplied by Verts (even though these part numbers do match the "secondary" numbers in the SIB). Thanks again, man.
If they did offer the parts for free, which I'm not counting on, I do wonder if I could still have them without BMW doing the labor. I'm just curious about that.
Old 01-17-2012, 02:40 PM
wooohooo
Ok, I made what was probably my first call ever to BMW NA, and thanks to this thread, I was armed with a lot of information! Even though I got bumped up one level, it's a no go as far as I am concerned. I think* they were implying I could get the parts, but I'd have to pay for a BMW dealership to diagnose it for themselves, and I suspect that I would have to pay them for the install too. Shucks!!
So I was looking for realoem contact info, which I failed to find, to ask if the panels come with bulbs included. (There is probably a better resource to ask that I'm not thinking of.) The SIB states that they do, and so does the Bentley manual, but then the parts list/diagram makes me suspicious.
Perhaps the best thing to do is order both panels, and just cross my fingers. If there are no bulbs (and that the warning code remains), just go to local resources as the people in this thread have done.
Yeah, I'll probably order the parts later this evening. Thanks again to all.
Old 01-17-2012, 02:45 PM
Verts4Ever's Avatar
Verts4Ever Verts4Ever is offline
Random Helpbot
Mein Auto: 2011 E93 335i
Good luck, Ilmc. Let us all know how it turns out.
Old 01-17-2012, 06:19 PM
wooohooo
Thank you, I'm sure I will. I just ordered the two at Tischer, $16.74 each, add $14.95 shipping, for $53.38 total. These are the descriptions on my order (funny how they appear differently as they do):
1 OEM Catalog Socket panel Socket panel Left $16.74
1 Collision Catalog - 2008 - BMW - 335I electrical, rear lamps, tail lamps, socket panel COUPE, CONVERTIBLE, 2007-10, ON QUARTER PANEL, coupe Right $16.74
^ Maybe Bcube was correct about being only the right side? ^ . . . since only the right side has the boldfaced "tail lamps" included in the description. Well, the order is in, so enough of the speculating . . .
Old 01-24-2012, 09:28 PM
wooohooo
The two sockets arrived today. I installed just the right one first, and I think Bcube's far fetched memory > my research. The code disappeared. I went ahead and put the other one in too, why not. For anyone in the future who finds this by search, have no fear, this is the easiest thing ever, much much much easier than you would imagine. I think the entire swap could be done in 10 seconds with a little practice. Yes, THAT easy.
The replacement right (outer) socket is on the left. I think the build date said something around late 2010 on it.
To install, all you do is remove the cover/liner over the battery, and it's all exposed. That plug's tab really can be a bit of a pain to successfully depress enough for removal. The white tab in the middle right of the panel is what secures it all, and all you do is depress to release. The only word of warning is to check that it's snug after installing, by simply pulling. The last time I fiddled with it, I failed to so, and well, with about 100 miles driven, everything was fine (the socket didn't fall down). It was only tonight when pulling out the old one that I realized it, after it just came out with no effort. After reinstalling the left side, I confirmed that this is something to double check because there is no "click"; the only real confirmation I could get for myself is to simply tug on it.
Ok the below has nothing to do with the known issue above, for the outer sockets made before 1/21/08. But, I figure I might as well share a couple pics I took when trying to clean every contact in sight for all taillights.
This is what it looks like when you remove the 10 clips for the trunk lid liner. You'll see 8 immediately, but if you're like me, you may get confused on where the other 2 are. They are recessed a bit, directly to the right and left of the emergency trunk pull. These 2 clips also happen to be more difficult to get out. So these inner socket panels are simply removed by the single nut you see there. That's it. Oh, perhaps the biggest PITA with getting it all back together is fitting/holding the liner snug to the lid, while simultaneously trying to fish that little emergency pull wire back through (not a terrible amount of slack to work with), and then fitting it back to the handle.
Anything I do for the first time on my BMW is pretty much the first time I do anything of this nature on any car. So don't look down too much on me for appreciating the design of these clips. You have it extended, push the tip through, then push the little tube in and it will secure. To remove, it's the opposite, pull the tube out, then the clip can be removed rather easily (except for those two I talked about earlier, at least with me doing it, at least on the first time).
Old 01-25-2012, 06:09 AM
Verts4Ever's Avatar
Random Helpbot
Glad to hear it worked out for you, Ilmc!
Old 09-02-2014, 07:01 PM
treestone27 treestone27 is offline
Mein Auto: 335i - 2011
My factory warranty recently expired, and forgive me if this is a dumb question, but am I still covered for free? Also, how did you find this SIB if I may ask (just googling, or do you have a go-to resource for these things)? Thanks a lot, V4E.
Ah, not so bad in price at all! My manual doesn't say anything about which side it is though. Thanks Bcube.
Question - which regular brake light would it be? I have a 2011 335i and the manual labels a "brake light" on the quarter panel, and a "brake light" on the trunk? So, I want to order a right panel replacement to try to fix the code 124 external lamp issue, but I don't know if I should order the quarter panel or trunk first. Please help! Thanks!
Woops - I may have answered my question by re-reading above - it looks like ilovemycar replaced the outer/quarter panel section first, which made the code disappear. I'll give it a try.
Old 09-07-2014, 03:03 PM
Success! Code 134 has disappeared. I replaced the panel on the quarter panel (not the trunk). The part came with bulbs.
I ordered from getbmwparts.com the following:
Part No. 63217211214 electrical, rear lamps, tail lamps, socket panel 2009-12, ON QUARTER PANEL, SEDAN Right
$25 USD
I noticed one bulb in the old panel was lose in the socket. So, maybe that's the defect - a lose socket.
Anyway, I didn't have to go to the dealer and I really appreciate this thread and site!
Thank you!
