Old 01-23-2012, 07:47 PM
ilian007 ilian007 is offline
Mein Auto: BMW 530i 2002
Wiper Blade Guide?
1. Do I need to to buy separately the wiper blade guide part number #61618162982 or it comes with the Wiper Blades ? please, dont suggest refil i prefer whole blades.
2. Are there better wiper blades than the OEM ones ? Sun in California is too strong and it burns my wiper blades each year. I've heard there are some teflon wiper blade that could resistt the sun burn.
Any suggestion? Please take attention mostly to #1 which is my primary questions.
Thank you guys
Old 01-24-2012, 06:51 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
If you're talking about the two steel guides that come with the wiper inserts, the simple answer is that the steel guides come with some wiper inserts and don't come with others. You have to ask what you're getting.
Most people will tell you the best place to get the wiper inserts with the two steel guides are at the dealer but others will tell you to go online depending on how bad their stealer is.
Old 01-24-2012, 08:58 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Thank you guys
No...you don't "have" to get the part nbr you mentioned (it's #5 in the diagram below)...unless you happen to want a new one for some reason.
The wiper blade is #1 in the diagram...and the refill (which you don't want) is #2 in the diagram. You can look for a replacement #1...good luck...I believe I've read that some have found an aftermarket replacement blade...but whatever you find (BMW or aftermarket)...it should clip on to #5 with #4 (the clip):
Q {BMW CCA Member #191509}
(SOLD)
Old 01-24-2012, 09:20 AM
cn90 cn90 is offline
- Whole wiper assembly ---> Autohausaz.com sells a set of 2 for $34.
Bosch OEM.
- Refill ---> $10 for a set of 2 at BMW dealer.
I am not sure why you don't want refill. Believe it or not, the wiper assembly in my car is from 1998, only the refills have been changed every 2 years or so.
You are in Sacramento with lots of sun, just change the refill every 2 years or so.
Old 01-24-2012, 09:33 AM
z28forlife z28forlife is offline
Mein Auto: 2000 e39 540i
Can we not get the new rain x blades that only connect on the center blade and don't have 5 different points of contact.
http://www.rainx.com/mobile/
Old 01-24-2012, 10:25 AM
Solo12 Solo12 is offline
Mein Auto: e39 530i e28 535is(Sold)
Nope. See Q's diagram for references. The e39 uses a proprietary method (part #4 ) for connecting the blade (part 1) to the arm (part 5). It does not use the universal hooks so you can't run beam ty(pe replacements bosch icons or those rain x blades) as no company offers those blades with an e39 specific connection.
Bosch does make a replacement blade (still has all those points of contact not beam type) specific to the e39, but I don't really recommend it as it lacks the ability to use the inexpensive inserts. I don't think the e39 bosch replacements really perform any different than the oem ones. I know as I have run them both, due to the stupid indy put bosch replacements on my car instead of replacing the inserts on my oem blades.
I know it may seem crazy as one of the first things I wanted to do when I got my e39 was install bosch icons as I had had them for 5yrs (2sets) on my e28. Its kinda bizzare that I can run a newer blade design on my 1987 e38 versus my 2003 e39.
In truth the oem e39 blades work extremely well and the insert are extremely cheap. It is a much cheaper repalcement than any other blade system. Having run the bosch icons on my e28 for years and having had the e39 for 2yrs I would say the icons last longer and stay quieter longer. Issue of lifting at speed is about equal as the e39 set up has spoilers. I think the icons might have the edge in preventing building of ice and snow as there is no exposed mechanism on the blade. But I could be wrong as the e39 blades do sit below the hood and I don't run my e39 in the snow. The cost of replacement for the e39 set up is going to be cheaper.
If you really want the beam type wipers you can retrofit e60 wiper arms (not the blade the arms part 5). It is not cost effective and for the passenger arm it requires cutting and welding 1/2 of the e60 arm to the e39 arm. The driver side requires you to bend the arm. It is on my to do list as I like that setup, but it is not cost effective.
Also just make sure rain x makes blades for the e60.
I am not sure as I am interested in icons or oem bmw beam wipers not rain x.
See this thread for info on the over the top kinda unnecessary e60 swap.
http://www.bimmerfest.com/forums/sho...358&highlight=
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 01-24-2012, 06:14 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
Any suggestions on weatherizing the e39 blades? Since im from Central NY we get snow and ice ive noticed that the open design of the blades makes the wipers prone to freezing and not doing their job very well unless you do the old flop em on the windsheild trick a few times, wich can crack wind screens so im not a fan lol.
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 01-24-2012, 10:09 PM
gibo58's Avatar
gibo58 gibo58 is offline
Mein Auto: 530i MSport
wiper blades
Hey Ilian, I bought the Bosch wiper blades from Amazon, $35.. free delivery for you. Takes less than a minute to change each blade. I have the same car as you. It's a no brainer mate, the refills might be cheaper but from past experience and reading threads on them a bit of a PITA to change.
Here's a link:
http://www.amazon.com/gp/product/B00...rev_prod_title
Old 01-25-2012, 12:28 AM
More than you probably want to know is below ...
- How to replace E39 wiper blade refills (1) & how to buy E39 25" driver side & 22" passenger side windshield wiper blade refills (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) & how to replace the wiper arm (1) (2) & troubleshooting or replacing the wiper motor (1) (2) (3) (4) (5) (6) (7) or wiper switch (1) or wiper relay (1) & how to replace the rain sensor (1) (2) & retrofitting a rain sensor (1) (2) (3) & how to remove Rain-X water wiper streaks & spots on windshield glass (1) (2) (3) (4) (5) (6) (7).
Old 01-25-2012, 07:48 AM
Originally Posted by gibo58 View Post
...It's a no brainer mate, the refills might be cheaper but from past experience and reading threads on them a bit of a PITA to change.
What?
Changing the refill is very very easy:
- Simply remove the wiper from the car, remove old refill.
- Cut new refill to length, then insert it.
About 2-3 min per side.
Old 01-25-2012, 10:03 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
New refills are exceptionally cheap and easy to install (if you know how to transfer the metal spines) but on worn-out wiper arms they're a waste of $ no matter how inexpensive.
Old 01-25-2012, 01:56 PM
QSilver7's Avatar
What?
DITTO. It took all of 5 minuted to uninstall, reinstall, and throw away the refuse.
Once you move the wipers into position (ignition on, turn on wipers, turn ignition off when wipers are at highest point)...this allows you to pull the arm back (#5) and unhook the blade...where you can remove the old and slide the new refill in to place (once you've cut the refill to size). Then you just hook the blade back on to the arm and move over to the other side.
I don't see how anything to do with changing the rubber refills is a PITA...unless you don't know the procedure for moving the blades into place, and that the arm can be pulled away from the windshield.
(SOLD)
Old 01-28-2012, 09:01 PM
gibo58's Avatar
not a PITA
Ok, I stand corrected. After reading the posts by CN90 and Quicksilver I thought I would get my old arms which I kept and see how easy it was to change the rubbers.
It took me a few minutes to see I needed to pull the rubber out of one end first as it is locked in by the last 2 wiper arm 'claws'. Once you do that the rubber and splines slide out. Then you need to put the splines back in the new rubber the slide it back in the claws of the arm. It was a bit fiddly getting the rubber to seat back in the last claw to lock it in but with a little jewellers screwdriver quite easy.
So next time I will probably go this way and save a few dollars,
Also there is no need to have the arms vertical to remove, I found it easy to lift and remove the arms in their normal position
The claw locked in the rubber refill
Old 01-28-2012, 11:08 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I believe BMW recommends replacing rubber every 6 months. I got 2 years out of mine in Ontario and PNW. I don't mind replacing the rubber.
You can get one-piece blades. There was a DIY posted here a while ago. Basically you cut the end of the E39 arm off and weld in the end from an e60. But you can't buy just inserts for the e60 afaik.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 02-01-2012, 09:06 AM
Guys thank you for all the answers, but no one actually took attention to what I specifically asked ....
My question is: DO I NEED TO BUY SEPARATELY THE: wiper blade guide part number #61618162982 (Which I miss on one of my blades)
Thank you
Old 02-01-2012, 09:08 AM
@Gibo thank you for the link I will save it if i decide to go with whole blades. I believe I will get refils, but only if they come with the Blade Guide
Old 02-01-2012, 09:19 AM
Thank you
Head down to your local BMW dealer and buy whatever you need.
PN 61618162982 is about $2 at dealer.
With the time it takes to post and reply to this issue, drive down the BMW dealer and you will get this solved in no time at all.
Plus, these parts are very cheap, even at dealer (surprise, surprise).
Old 02-01-2012, 09:32 AM
@CN90, I called BMW of Roseville (916-790-1990),
They have the refills for $6.77 for each side and the Wiper Blade Guide for $2.70.
It was little hard for the guy to find the Wiper guide part, but at the end he found it They offered shiping of those for $12. My bimmer will probably spend $12 gas to there :P
Old 02-01-2012, 10:11 AM
No BMW dealer in Sac?
Old 02-01-2012, 11:38 AM
I am closer to roseville 15 miles each way. Live in Folsom. My profile say sacramento because it is better known city close by. There are two dealers one at fulton: "Niello" and one at Roseville "BMW of Roseville"
Old 02-01-2012, 12:28 PM
QSilver7's Avatar
Thank you
Ummm...I thought I did address that question in my reply in post #3. You didn't mention in the orig post that yours was missing...but it was still addressed in my reply with "unless you happen to want a new one for some reason..."
Originally Posted by QSilver7 View Post
No...you don't "have" to get the part nbr you mentioned (it's #5 in the diagram below)...unless you happen to want a new one for some reason....
@GIBO58:
Thanks for posting back...and now I stand corrected about positioning the wiper blades for changing them...I was confusing the e38 & e39...it is the e38 that you have to move the wipers up into position because they are parked below the edge of the hood when in the "rest" position. Sorry about mixing the two car's procedure.
And here in the states...when you buy the refills with the metal reinforcements already running thru them...there are also a couple of "bands" around the refill blades that holds them together & facilitates sliding the whole refill (rubber blade & metal strips) thru the "claws"...and the bands just slide down and eventually off by the time you've gotten down to the last "claw" on the wiper blade.
(SOLD)
Old 02-01-2012, 12:44 PM
Qsilver7 i lost one of my wiper blade guides and thats why i asked if someone know if it comes with new wiper blade or is part of the wiper blade contol arm. I watched that diagram on realorm but it wasnt clear enough if it is from the wiper blade set or separate part to purchase.
Old 02-01-2012, 12:45 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
I just hired a dwarf to sit on my hood and squeegie the windshield.
Old 02-01-2012, 01:48 PM
QSilver7's Avatar
...no problem. If you see a number in the diagram listed alone...and it also appears in the part nbr index below the diagram...then that part can be purchased by itself.
When you see a number in the diagram that has lines that connect it to other numbers in the diagram...then it means that item can be purchased as part of a larger set (the other parts that are connected by the lines).
In this case below...item #3 consists of all the things the lines connect it to ( #4, #5, & #6)....but #4 , #5, #6 can also be purchased separately. Same for #1... it is a set that comes with #1 & #2...but you can just purchase #2 if nothing is wrong with your #1.
(SOLD)
Old 02-01-2012, 02:22 PM
@Qsilver7: Ive got it now i didnt know how to say if a part is part of a set.
