Old 11-19-2011, 11:56 AM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Originally Posted by red1KRR View Post
So if dash blinks fast on the left it's actually a bulb out on the right? Going to check that out. I hope you're right 1bad540
Not on my 02, right side links fast, right side light not working.
Sent from my PC36100 using Bimmer
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 11-19-2011, 01:13 PM
nikirox nikirox is offline
Mein Auto: Alpina B7 (2007)
Left front headlight replacement, fixes left turn signal malfunction when all the signals are fine. Expensive part, cheapest I've found was $750 on eBay, dealer retail is $1300. Real joke, BMW doesn't put out a TSB.
Old 11-20-2011, 11:39 AM
red1KRR red1KRR is offline
Mein Auto: 2006 750i
Is there nothing that could have been done to the old housing to get it to work?
Old 01-16-2012, 12:17 AM
My AE on the left side burnt out and so I decided to order from e92 lighting some Mtec V3's. I thought that while I had to remove the bumper cover that I may as well change the high beams and fogs as well. After changing the three on both sides, my signals work like normal. Go figure It's been exactly five days since I've changed them and no signal problems what so ever.
Old 01-30-2012, 07:36 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i; 750Li; Yukon Denali
Finally found the fix for mine! It was the Light Module under the drivers kick panel. What a relief that was of troubleshooting.
Old 01-30-2012, 07:47 PM
syrius750Li syrius750Li is offline
Mein Auto: 2007 750Li
Light Module..what's it look like and did you buy a new one?..Price?..Thanks
Sent from my SGH-T959V using Bimmer App
Old 01-30-2012, 08:02 PM
collins912's Avatar
Small black box held in by one screw. Have to remove the air duct to actually see it. Got one from this guy parting his car out. Its like 3-400 bucks from dealer!
Old 10-07-2014, 08:06 AM
BobbR BobbR is offline
Mein Auto: 2007 750 Li
Smile My Solution to the Left Turn Signal Malfunction
I have a 2007 750 Li and had been getting the "Left turn signal malfunction" error on and off for the past 6-9 months. At first, it was very intermittent. But towards the end of that period it became too annoying to ignore. I took it to the dealer for the first time and they replaced a bulb, $50. On the drive home from the dealership, the error appeared again. They picked up the car the next morning at my office. Later in the day, they returned the car after having replaced the Lighting Module, $950. The next morning on the drive into the office, the error appeared again!. Again, they sent a driver to the office to pick up the vehicle and spent the rest of the day to determine the problem. Turns out the wires leading into the housing were chafed from rubbing up against the wheel well and other components mounted nearby. This was causing the short circuit that caused the error. All the technician did to remedy the problem was to re-wrap the wires in electrical tape. The problem has not reappeared in 2 weeks, so I'm sure this is the fix. Additionally, my dealer refunded the charges for the new Lightning Module and I agreed that the $50 charge for the bulb was more than fair for work completed.
Old 11-11-2016, 01:24 PM
rellik rellik is offline
Mein Auto: Bimmers
sorry to revive an old thread but.... I have this malfunction and I've been chasing it down for about a year in my 2008 750i. I'm still at a loss. replaced every bulb in the front left, side marker and bulb for the angle eyes. No wires are visibly damaged. no codes other than what is displayed on dash
things I'd rather not try due to cost...
  • lighting control unit (maybe this since the front right adaptive headlight no longer 'adapts'?)
  • new steering angle sensor (feels a little like the problem may have something to do with where the wheel is at when the error message comes up)
cheap options:
thinking about replacing ALL the bulbs. front, rear both sides
take apart wheel and clean the contact the sensor rides on.
pull the front of the car off AGAIN and check wires AGAIN
Looking for some help here. I'm at my wits end!
Old 11-12-2016, 06:53 AM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
cheap options:
Replace Light Module
Old 11-12-2016, 08:35 AM
Mein Auto: Bimmers
Can you tell me why you think that's the way to go? Did you have the same issue or know that this fixed it for others? Thank you for the reply BTW!
Old 11-13-2016, 07:30 AM
I would go back and triple-check that every wire is not frayed, cracked, or split. Or, just put electrical tape around every wire that might be rub up against a wheel well, for example. If the problem is intermittent, this is the most likely cause. The intermittent failure is indicating a short, say, between the lighting wire and the wheel well, or other metal body part.
