E36 (1991 - 1999)
Old 01-27-2012, 03:56 PM
getlit getlit is offline
Mein Auto: 1997 bmw 328is
Need car inspection/possible work done (Lake Berryessa/Napa, CA)
So it's looking like I bought a lemon...
Just moved to California and purchased a 97 328is BMW.
After taking the car up to higher speeds it was made very apparently something was wrong on the front in. Initially thinking it might be bushings, I went ahead to get it checked out... Les Schwab's mechanics were seriously concerned with me even driving the car out of the lot. They said that there was "excessive movement on the LF lower ball joint as well as RF. On top of that the control arm bushing is torn." I could physically shake the RF tire sideways (perpendicular to the axle rotation.)
While waiting for these parts to come in (apparently now not until next Tuesday *le sigh*) the car decides that starting is overrated. It made two clicking noises when turning the ignition, although the radio lights and cluster lights came on. I tried jumping the car to no avail then after charging it for awhile, the car finally started. The odd thing is the battery tested in the green on the battery charger, even when first connecting it.
Since I just moved here I have no tools and have never worked on a BMW before. I am hoping somebody local could either come here or meet up (if the car decides to start again) and inspect my car as well as do/assist in repairs and bring tools. I could definitely negotiate some sort of payment
You can reach me at ryansbacon@gmail.com
Any help would be greatly appreciated!
Old 01-27-2012, 04:01 PM
E36 Phantom's Avatar
I Am The Machine
Welcome to the Fest and the best state!
Sounds more like a starter problem than a battery problem.
While you're in a very pretty area, I don't think we have many members up there.
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 01-27-2012, 05:10 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
hmmm could be a starter like the old fart has mentioned... or could just be a dead batt.
and did you just order the bushings for the control arm or did you buy the whole control arm assembly? one is pretty simple, the other not so much (bushings)..
are you in berryessa or napa? i go to school out in napa, but berryessa is a long ways from where i am (vallejo). if you were closer i wouldn't mind lending you some basic tools to get the job done.. id offer help but school just started a few weeks ago and barely have enough time to work on my own piece of crap
btw if those are your only problems with the car, its certainly not a lemon.. just needs some maintenance taken care of. its nothing to get rid of the car for..
oh and welcome to the fest
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 01-30-2012, 11:47 AM
Yeah I was worried about a starter but it finally started up and hasn't had any issues with that since then...Now I have run into a bigger problem. The guy I purchased the car from bought a control arm assembly and bushings to ship here and now shops are refusing to work on the car unless we buy their parts.
Happen to know any good mechanics in the Napa area?
Old 01-30-2012, 11:49 AM
I believe the entire control arm assembly although one of the bushings on the other side may need to be swapped. I'm 20-30 minutes from Napa up in berryessa. Do you happen to know any good affordable mechanics down there? I have to drive to Napa one way or another to get the car repaired.
Old 01-30-2012, 11:56 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
i dont really know of many shops in napa.. but i know of a few shops out in vallejo that do good work and are fairly affordable. idk if you want to get the car towed out here from napa or something. wish i had the time to help you out because i have done this job before, but i can't find time at all
-Usama
Old 01-30-2012, 12:13 PM
Yeah unfortunately I just don't have the tools or I'd probably just follow a DIY. A sturdy jack or a lift would be nice heheh. Good luck with your studies bud and thanks again for the help.
Old 01-30-2012, 11:59 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
With owning a BMW, this would be a good time to invest in some tools. Just a nice set to cover some maintenance. With the labor fees you'll pay for the front end rebuild you couldt have all the tools you'd need to do the job yourself.
Then you're set for the next problem that comes up. Good luck
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 01-31-2012, 11:49 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Drive down to the South Bay and take it to MotorSpeed West. /thread
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-31-2012, 12:19 PM
I Am The Machine
From Lake Berryessa?
// Chad //
You're a derbanana
328is, bmw, help advice, inspection, repair
