Old 02-02-2012, 04:10 AM
SAMLAMBO SAMLAMBO is offline
Mein Auto: BMW, Mercedes, Ford
Originally Posted by bruno787 View Post
Interesting.....so it still does the usual hid startup bluish to white glow?
That would be interesting but either way it sure does look good and beats the stock setup hands down. Cant wait to receive mine.
2012 BMW 740i
2011 Mercedes E250
2007 Lamborghini LP670-4 SV
Old 02-02-2012, 04:22 PM
FalconFlyer FalconFlyer is offline
Mein Auto: Tampa
Actually when you start the car, because HID lights are not instant on/off... the start off a little dim.. then get real bright. Really nice when you are walking out to your car. They do not do any flickering or anything like that...
2015 BMW M6 Grand Coupe
2016 BMW 750i M Sport
2015 BMW M4 Convertible
2015 BMW X5M
2015 BMW 750Li M Sport (Sold)
2014 BMW X6 3.5 M Sport (Sold)
2014 Viper GTS (Sold)
2015 Jaguar F Type R (Sold)
2015 Ranger Rover Evoque Dynamic (Sold)
2015 BMW X5 5.0 M Sport (Sold)
2014 BMW M6 (Sold)
2013 BMW 750Li M Sport (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-02-2012, 05:30 PM
kismet67 kismet67 is offline
Mein Auto: 2011 bmw 750li x drive
hid
i just received mine today will install tomorrow,Alex is very friendly prompt.
Old 02-02-2012, 06:17 PM
Mein Auto: Tampa
Yes... Alex is very helpful ..... it will be interesting to see your opinion of the lights...
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-03-2012, 01:57 AM
gassy gassy is offline
BMW 7 Series Obsessed
Mein Auto: 2016 M4 Champagne Quartz
Forgive me if this sounds obvious, but aren't there 2 bulbs on each side, and does the Alpine kit then come with 4 bulbs?
Old 02-03-2012, 05:02 AM
Mein Auto: Tampa
No.... There are only one bulb on each side...
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-03-2012, 12:00 PM
Not having switched out the bulbs yet, why are there two round bulb covers, one front and one rear, on each side? The front one on my car has a white wire and the rear one a red wire. Which one is the bulb that gets changed? I assume the other bulb is the zenon headlight, not the angel eye bulb, correct? Thanks for indulging the uninititated!
Old 02-03-2012, 01:31 PM
ae
look at your cover one says h8 the other h3 you want to change h8 larger one with larger cover
Old 02-03-2012, 01:34 PM
eyes
Just finished install on 2011 750li xdrive
it looks amazing i highly recommend it .it was easy 30 mins my son has the 2011 3 and its identical.next is my wifes x5 . alex was extremely helpful
Old 02-03-2012, 04:18 PM
Thanks Kismet- so one replacement bulb illuminates both angel eyes, eh?
Old 02-03-2012, 04:37 PM
ae
yes and bright
Old 02-03-2012, 08:52 PM
whiteonredM6 whiteonredM6 is offline
Mein Auto: 2013 M6 Coupe
I just bought this kit for my 7, I need someone to install them for me. I need help please!' I'm in Miami.
Old 02-03-2012, 08:54 PM
More pictures would be great
2012 BMW 740i
2011 Mercedes E250
Old 02-04-2012, 08:33 AM
Mein Auto: Tampa
Ok....
Here is a step by step instructions... again very easy...
First you need to attach the wire that has a hook on it and not a square thing (you will see that in other pictures) to the battery hot lead. This is streamy simple, simply take a socket wrench and loosen the nut and put the ring over it and put the nut back on....
Ok.. next I removed the plastic side piece on the left side of the car (left side if you are looking at the engine.) The is really easy to do, basically the small plastic pin needs to be pulled out (needle nose pliers work very well). Once the pin is removed you have to remove the plastic housing too. There is about 8 of these and the plastic cover comes off.
Next you have to find a good ground, the one I choose in the picture below required me to make the ring a little bigger. This ring is connected to the small black box as seen in the pictures... that is how you can tell positive from the negative
next run the wires into the left light (actually the right light if you are in the drivers seat). You need to install the bulb at this point and drill a 1/2 inch hole in the plastic cover. I used a 1/2 flat wood drill bit.. took about 5 seconds. Ok.. it is important to know that the two bulbs are different... one bulb has a single wire coming out with the flat butt wire connector... and the other has two of these. One one that goes into the left light (right light if you are sitting in the car) is the one with the two wires...... and this will match up correctly with the wiring harness. I also mounted the ballast in there as well.. fits really nice
Run the wire in the void above the radiator... see picture below...
And again... do the same thing for the right light (actually the left lights if sitting in the drivers seat).
If you guys have any questions... feel free to PM me with your phone number.. .and I will give you a call...
Hope this helps...
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-05-2012, 07:16 AM
Quicksilver1010 Quicksilver1010 is offline
Mein Auto: M6 Vert
The cover for the light doesn't have to be modified? It's a perfect plug and play to the housing? I've seen other kits that you have to drill to make the hole a tad bigger.
Old 02-05-2012, 07:19 AM
Mein Auto: Tampa
Yes....... You have to drill a 1/2 inch hole in the plastic cap.... Takes about 5 sec. I am not aware of any other hid kit that you don't have to modify something...
Here is a picture of my Z4... as you can see a small 1/2 inch circular hole is cut in the plastic cap... when you pull through the wires in the Alpine kit... they have a really nice seal that pops into place.....
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-06-2012, 07:32 AM
Mein Auto: M6 Vert
Falcon, youre a beast. thanks for the great write up. Im going to order mine becasue these hazy yellow are driving me nuts!
Old 02-06-2012, 07:39 AM
Mein Auto: Tampa
Happy to help....
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-08-2012, 03:15 AM
mouivann mouivann is offline
Mein Auto: 2008 X5 3.0si/2011 535i
Anything with the X5 yet? Picture if you have them. Thanks.
Old 02-08-2012, 07:03 AM
Mein Auto: Tampa
No.... sorry guys... my wife has been in the hospital.... I should have something by mid next week....
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-11-2012, 07:16 AM
Mein Auto: M6 Vert
HYper55, what did you do for your fog lights becasue alex from Alpinemss told me they do not sell a kit for the fogg light and i see your match perfect w the AE upgrade.
Old 02-15-2012, 03:07 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
Great Angle Eyes!!!
Thanks for the great info FalconFlyer. Quite an impressive display of brand loyalty in your garage! I just took delivery of my F02 M-Sport and was also very disappointed in the anemic amber AE's. I tried the Weisslicht LED kit but had error codes galore, and they weren't very bright as is common with LED's. After talking to Alex, I ordered the Alpine Motorsports HID AE kit in 6K (close to OE headlights). The install was a mere 30 mins and can be accomplished with minimal effort if you are the least bit mechanically inclined. There is only one power hook up in the engine compartment (passenger side on US 7's) and everything tucks in neatly under the plastic fender trim and through the radiator brace across to the drivers headlight. The ballasts fit nicely directly behind the headlights. You do have to cut 1 inch holes in the headlight caps that access the bulbs to accommodate the extra wires.
This is similar to the X5/6 install;
A very clean installation that works fantastic. Very visible in day light as you can see from pics. And NO ERROR CODES!!!!
Old 02-15-2012, 03:44 PM
RocknDoc
Update on install
Oh, BTW, the new kits from Alpine MS do not require a separate ground and this works through the existing wire harness.
Old 02-15-2012, 05:30 PM
It looks wow! Cant wait to receive my kit.
2012 BMW 740i
2011 Mercedes E250
Old 02-17-2012, 07:10 AM
Mein Auto: Tampa
Looks great... yea... regarding my brand loyalty... about 2 years ago I never had a BMW... my wife kept nagging me about how great they were/are... we purchased our first one... and needless to say I replaced everything in the garage with one :-). As my wife says, it is cheaper than marriage counseling (she is on the sofa right now picking out her colors for her M6 she wants this summer..... )
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
