Old 01-26-2010, 06:58 AM
b525i b525i is offline
Mein Auto: BMW E39
E39 - airbag light on
Can anyone help w/ an airbag light ?
A week ago, after the driver side power window jammed, and a new window regulator was installed (yes, the window works again), the red airbag light came on - it's still on
A scan showed code "05" but could not be removed
What's the next step to resolve?
Thanks all
Old 01-26-2010, 02:40 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Taking the car to either a BMW dealership or indy that has the proper tool to reset the SRS (supplemental restraint system). Or if you have the correct (I believe Peake) tool to reset the SRS. The airbag light reset isn't a simple one do to the safety importance of the airbag system. If a fault is detected...unless you have or someone you know that has the correct tool...it will need to be done by the dealer.
More than likely, the door's BRIGHT ORANGE airbag electrical connector was either plugged in or unplugged while the car's battery was still connected. That' a big and will always trip the airbag light.
Q {BMW CCA Member #191509}
(SOLD)
Old 01-27-2010, 07:09 AM
Philboski's Avatar
Philboski Philboski is offline
Mein Auto: 97 540I6
Couldn't one also simply unplug the battery for 20 minutes?
Old 01-27-2010, 09:45 AM
QSilver7's Avatar
Not for the (SRS) airbag system...too much of a safety issue to allow such a simple bypass for when something has triggered a fault. Passengers can be seriously or fatally injured by bags deploying...especially if the bag wasn't intended to deploy but does so because there's a fault in the system which causes all the bags to deploy because there IS a fault in the system.
The text highlighted in yellow infers this...for example, the normal response range is for the airbags to deploy when they detect a passenger in the seat...when the airbag light is on...all the bags can or may (based on impact conditions) deploy since the system can't recognize if the seats are occupied or not.
(SOLD)
Old 01-27-2010, 10:53 AM
jieg jieg is offline
Ivan
Mein Auto: 525i 2003
My air bag sign plays with me like this
When driving alone, it turns on when starting the car, then turns off after a few seconds. This seems like normal.
When a passenger is on board, it comes on and off with no pattern while driving. What is the meaning of this? (and the way to solve it?)
sorry , no intention to jack the thread
---------------Ivan
Old 01-27-2010, 12:39 PM
Philboski's Avatar
Mein Auto: 97 540I6
My understanding is that if the airbag light is on, the system defaults out to not allowing the airbags to trigger for safety reasons.
The way it was explained to me, unplugging the system for 20 minutes drains all of the reserve battery that would fire off the airbags. Then, when it is repowered, it effectively works as a reboot. It won't tell you what is wrong, however, and that's why I sprung for a Peake SRS code reader myself.
Old 01-29-2010, 11:12 AM
QSilver7's Avatar
That is a rather common misconception....the DEFAULT mode for the airbag system is to error on the side of safety. For instance, if the front seat passenger occupancy sensor has registered a fault and can no longer detect if a passenger is in the seat or not...in the event of an accident...the system errs on the side of safety and assumes that there IS a passenger in the front passenger seat...thus the airbag is deployed. Not the other way around.
Even if you look at it from a litigation stand point...the car mfg comes out ahead with the airbag system defaulting to INFLATING the bags instead of not inflating them. Again, in the scenario presented above...BMW would be at risk for losing a court case in having an airbag NOT deploy in the event of an accident and someone was fatally or critically injured or maimed. If the airbag DOES deploy in the accident (when it normally should not)...and the SRS warning was illuminated on the instrument cluster...BMW or any car mfg would have the defense that the owner was NEGLIGENT in not taking care of the system which obviously had an SRS warning that the system was malfunctioning. And they would be able to pull data from the ECU as to when the SRS warning first registered the fault.
(SOLD)
Old 01-29-2010, 12:31 PM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Very interesting information.
HOw does this scenario work out?
Let's assume the seat belt switch is defective, thus this faulty switch invokes the air bag light to stay lit up on the dash. IN this situation, would the airbag still get deployed in an accident?
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-29-2010, 02:19 PM
QSilver7's Avatar
Yes...but not because the seat belt sensor is defective...but because the seat occupancy sensor detects someone is in the passenger seat.
There's more than one sensor detecting occupancy...the seat belt (pretensioner) is in the seat belt receptacle and uses a pyrotechnic (explosive) to tighten the seat belt in a collision. When an accident occurs, the pretensioners pull back the seatbelt to take away excess slack. When using a pretensioner the seatbelt still needs to be worn securely because the pretensioner is not strong enough to restrain you in your seat in case of a collision. This technology lets the seatbelt to discharge enough slack to thwart the shoulder belt from exerting too much force across the chest.
So if this component has a fault...the pretensioner may not explode...but the airbag will still deploy supplying at least some protection. Remember, the seat belt is the first line of defense in a collision...not the airbag.
(SOLD)
Old 01-29-2010, 03:01 PM
xpcgamer's Avatar
xpcgamer xpcgamer is offline
5 Door'ing it!
Mein Auto: 99 528IT/10 Maxima
I can tell you that the Airbag light WILL remain on even after having the battery disconnected. My battery was off for a week while I did my CCV,Oil houseing gasket,and hoses. My buddy was right back when I finished up the job.
1999 528it Sport 5Sp
Old 07-31-2010, 10:00 AM
IanFG IanFG is offline
Send a message via Yahoo to IanFG
Mein Auto: 1996 328 Cabriolet
Related question: I had the drivers seat out for some work and when I replaced it - and plugged all the connections in the seat belt light came on. is this normal? ( I also replaced the battery over the same period but honestly cant remember which came first! so would changing the battery trigger the seat belt warning light/ or do I have a bad seat connection perhaps?
Old 07-31-2010, 11:59 AM
QSilver7's Avatar
If you unplugged any SRS connector (they have something bright orange on the connector) and removed/replaced your car's battery...IF at any point a SRS connector was disconnected and power was being supplied to the car...it would have set off a fault code.
The SRS system requires communication at all times with its components...any time there is an interruption in communications when there is power to the car...a fault will be recorded. So this means that as long as the battery is connected...ALL of the SRS electrical components must be plugged in. ONLY when the battery is disconnected should SRS connectors be undone...and DO NOT reapply power to the car's battery UNTIL ALL SRS connections are back together.
(SOLD)
Old 08-04-2010, 08:39 AM
Thanks Loud and clear!
Old 08-05-2010, 05:18 PM
bmwlady bmwlady is offline
Mein Auto: 1998 540i
Thanks for the info OSilver7! I, too, replaced my driver's side window regulator a couple of weeks ago and ever since then the airbag light has been on. Now I know that I've got to make a trip to the dealership's service dept. Oh well, now I know for the next time
Old 02-04-2012, 06:43 AM
Vadar540I Vadar540I is offline
Mein Auto: 540I
question for yoy,,,,
If my seatbelt doesnt really roll up by itself will that trigger the airbag light too?
Old 02-04-2012, 06:44 AM
Mein Auto: 540I
If my seatbelt doesnt roll up by itself could that be the reason why the airbag light is on?
Old 02-08-2012, 04:10 PM
I doubt it ... but ... to help you answer that question yourself, I just ran a quick two-second /airbag F3 in the bestlinks to find these.
- What can cause an SRS airbag light (1) (2) (3) (4) (5) (6) & what tools reset the fault (1) (2) (3) (4) (5) & what happens when mechanics disconnect the airbag before the battery or they connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) & where to buy an airbag occupancy sensor bypass unit (1) (2).
I didn't read them (today) ... but if they help you answer that question, let us know.
EDIT:
PS: Next time, use more garlic!
Old 02-08-2012, 09:28 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
Ya dude its a mat on the bottom of the passenger seat, it needs to be replaced. thats why when someone is with u the airbag light comes on.
Old 02-08-2012, 10:11 PM
DinanBimmer's Avatar
DinanBimmer DinanBimmer is offline
Mein Auto: 1998 540i 6-speed/2003 M5
My airbag light's been on for a while now. I'm just getting to finding solutions for this and other issues and was about to start a thread about the airbag light. Thanks QSilver7 for the helpful info., I likely triggered my warning light while messing with the door panels. Any one have an idea of how much it would cost to have this light switched off assuming there are no issues with the system?
Supersprint X-pipe attached to Dinan Free Flow Exhaust, m tri-color black kidney grills, 20% tinting on back windows, LED Angel Eyes, HID Fogs, and much more to come.
Old 02-09-2012, 04:04 AM
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
I just bought a B800 airbag scan and reset toll for BMW from Amazon - $39.99. It should be here by the weekend and I'll let you know how it turns out.
I've currently got the SRS light on in the dash, and I figured compared to the cost of 'diagnostics' at a repair shop, the cost of the B800 is a good deal. And in the end, I own the tool. My car is due for inspection and I'm not sure it will pass with the light on. Besides, it's driving me crazy.
Jerry
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 02-09-2012, 10:02 AM
Did you put the right amount of garlic at BOTH the airbag itself and the battery compartment?
In one of the threads I listed above, we asked people to report how much it cost to have reset. IIRC, the lowest price was around $85 (throwing out the ones where the mechanic had messed up and therefore reset it for free on the second visit).
Given that, if I hadn't used enough garlic myself when I opened up my drivers door, I would have bought the reset tool if it wasn't much more than what it costs for one reset.
Originally Posted by uncmozo View Post
I just bought a B800 airbag scan and reset tool for BMW from Amazon - $39.99.
Please do let us know how that B800 tool works out!
To help others, I'll start a thread asking for the cheapest usable BMW E39 airbag SRS fault reset tool available.
EDIT: Please post your observations to this new thread just opened today:
- What's the cheapest usable BMW E39 SRS airbag scan/reset tool we can find on the net?
Last edited by bluebee; 02-09-2012 at 10:18 AM. Reason: Added links to the new thread.
Old 02-09-2012, 11:29 AM
Thanks for the info bluebee!
Old 02-09-2012, 02:31 PM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
if i removed the airbags Would the light come on?
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
Old 02-10-2012, 08:08 PM
Did you read any of the references?
I can't tell if you are asking if you opened up the doors, removed the airbags, and LEFT THEM OUT, or if you're saying if you just removed them and put them back.
If you simply removed the airbag and put it back when you were done (which is what everyone does when they work on the window regulator), no, the airbag light would not go on (if you followed instructions with respect to the battery connections).
However, if you put it all back together sans the airbag, the moment you connected the battery with the airbag not in the vehicle, you'd get the light.
This is so obvious that I'm not sure what you're actually asking - but I made an attempt at assuming what you were asking to give you the answers above.
Old 02-10-2012, 08:38 PM
LalaRay's Avatar
Boosted
Mein Auto: 03 ///M5
ha NO, i Mean if i Removed them From My Car Permanently
ST coilovers,
