Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 01-17-2012, 10:32 AM
adamfoster2011 adamfoster2011 is offline
Mein Auto: bmw 645ci 2004
bmw 645ci only blowing cold air from drivers side
my bmw 645ci 2004 is only blowing cold air from the drivers side when on full heat, the passenger side blows hot air (but not very hot) would this just be a problem with the temperature control switch or could it be something else. please help
Old 01-17-2012, 11:13 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Check out this thread.
Here is the page from the manual explaining how the system works.
I though my cars heat was broken too until I read the manual, and even then it was still not clear how the system works.
Let us know if this works for you.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-18-2012, 09:23 AM
hi and thanks for the reply, i have tried this and the mans torso is red but still no heat, there is no heat on my body, feet or windscreen, do you think it could be a faulty temperature switch? thanks
Old 01-20-2012, 07:26 AM
do you have any other ideas?
Old 01-20-2012, 05:41 PM
Yorgi's Avatar
It's really hard to say. It could be something to do with a sensor or the temp control unit but I would guess it is more likely a problem with the hot water valve, heater radiator or aux water pump - number 8 and number 6 in this diagram.
'04 M3 - track
Old 01-23-2012, 11:51 AM
but if it was one of these wouldnt it affect both sides?
Old 01-23-2012, 05:47 PM
Yorgi's Avatar
Both sides are affected right? Cold on driver and only slightly warm on passenger which is not normal. My guess is the aux pump is not working and only a small amount of hot engine water is making it to the heat exchanger. It could be the controls or something going on in the distribution housing too.
'04 M3 - track
Old 01-30-2012, 10:19 AM
Hi i have just noticed that the air con only works on drivers side and not on passengers side, so to sum up i have heat on passenger side and only cold and air con on drivers??? Thanks
Old 02-11-2012, 07:41 AM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2012 528i + 2007 650 Vert
It's simple, just change seats to adjust your temperature.
Old 02-11-2012, 09:48 AM
Yorgi's Avatar
See post #2 in this thread and follow the links. Did you try those adjustments in iDrive already?
'04 M3 - track
climate control, cold air, heater, temperature
