5 Series DIY
Old 02-13-2004, 05:37 AM
stew_mclean stew_mclean is offline
Mein Auto: E39 528i SE
Question Door Speakers in E39
The passenger door speaker on my E39 528i SE has packed in - it just makes a mufflwed noise now. Anyone any idea how much effort is involved in changing it yourself, given the door airbag, etc.
Also, anyone know where to get new ones from? And how much they are? Or if you can fit any better ones straight in with no modification?.
The tweeters seem ok, its the bigger speaker that is faulty.
Ta,
Stewart
Old 02-13-2004, 10:19 AM
BorisKV BorisKV is offline
Mein Auto: 98 528i 5spd, 99 528iT
Take a look at this page http://www.bmwtips.com/tipsntricks/t...%20Project.htm it describes what is involved into speaker R&R also it mentiones that MB Quart RSB 215 were used for replacement. Since you will be changing one side you might want to change other side as well in order to match speakers.
I've seen brand new MB Quart RSD213 on ebay for ~90 + S&H they seem to be same dimension as RSB215 (5.25 woofer and 1" tweeter). Here is an example (I have no relation to seller - just found auction through search) http://cgi.ebay.com/ws/eBayISAPI.dll...category=32818
Some say that MB Quarts sound too harsh some say they sound nice - so you will have to decide what brand to go with.
Old 02-13-2004, 01:13 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Ta,
Stewart
Do u have the 10-speaker US spec sound system in your car? I ask because this system has an amplifier in the trunk that has 10 separate output channels that are frequency limited specifically for the speaker they drive. If you have this system, you have 3 speakers in your front doors: a mid-bass, midrange, and tweeter. Replacing one, or all, with aftermarket drivers will not be a 100% sonic match to what is in the rest of the car.
If I were you, and you're happy with the factory setup, I'd look around for a used replacement from someone who may have upgraded their system. I can't imagine a new mid-bass driver from a dealer would be terribly expensive either, that is also an option.
Replacing it is very easy. The instructions (and most of the pictures) on the website referenced were actually put together by me a number of years ago. If you have any questions, I am more than happy to provide more information. I've since done the upgrade on my 2002 E39, the wiring was slightly different on this car than the 1999. The site that outlines my 1999 upgrade can be found here.
Good luck!
Jeff R.
