Rims for 2011 Z4 3.0i - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 02-14-2012, 05:27 PM
Volenmere Volenmere is offline
Mein Auto: 2009 X3
I was hoping someone could answer a question for me, as I'm pretty un-technical when it comes to cars (ie, braindead).. I have a buddy who has an extra set of OEM rims from his 2008 3 Series he's trying to sell. The front rims are 19 inch diameter and 8.5 width, and the rear rims are 19 inch and 10 inch width. I've been looking to get an extra set for my Z4, and was wondering if these would fit my car? I've been googling for a couple hours and can't seem to find a definitive answer, as most of it just seems greek to me. Any help would be appreciated!
Old 02-14-2012, 07:29 PM
HerrK's Avatar
HerrK HerrK is offline
Mein Auto: 2011 Z4 35i
What BMW wheel style are they? The 8.5" wide frt and 10" rear is not a normal stagger for BMW. Are they a mixed set. From the wheel style you can find the Offset or ET. Normal E89 19" wheels are Frt 8" & ET 29 & Rear 9" & ET 40. Without knowing either the stle or ET of the "desired" wheels it is not possible to determine fitment.
http://felgenkatalog.auto-treff.com/
HerrK - Keine Eifelfahrt ohne eine Runde über den Nürburgring
May 2010 ED l 2011 35i l Crimson over Ext'd Coral Red w/brushed Alum l 6sp MT l Prem Sound l Sport Pack l 296's l Comfort Access l Alarm l Power Heated Seats l & Nav.
FrauK - 2014 Q5 TDI - May 2014 ED | Cuvée Silver over Pistachio beige | Premim Plus | MMI | Nav | B&O
Old 02-15-2012, 09:41 AM
Mein Auto: 2009 X3
These are the rims - Styling 359
http://felgenkatalog.auto-treff.com/?felge=3590
Old 02-15-2012, 07:02 PM
HerrK's Avatar
OK for your training as the ET gets smaller the outside edge of the rim is moving outboard. So the F&R rims are 1" wider than stock. That equals to 1/2" on each side. For the rears you have to add another + 15mm because the ET is going from 40 to 25. The bottom line is the outboard edge of the rear rim is going to move outboard a little over 1" and your rear tire will likely rub badly. The frt rims would probably be OK.
Old 02-15-2012, 07:16 PM
Mein Auto: 2009 X3
Thanks Herrk, sounds like I should just pass on the rims. Appreciate the help, if you have any computer problems let me return the favor
HTML code is Off
