Old 02-11-2012, 07:41 PM
AceFX AceFX is offline
Banned
Mein Auto: BMW 760Li BMW X5 4.8iS
Cool How to Retrofit a OEM Bluetooth TCU to your car
cleaning topic & only leaving required info
Old 02-11-2012, 08:08 PM
JimmyW's Avatar
JimmyW JimmyW is offline
Mein Auto: 2007 BMW X5;2002 BMW 745i
Nice work! However, I wonder what the benefits of this system are versus CPT8000 or CPT9000?
Old 02-11-2012, 08:12 PM
crombo97 crombo97 is offline
Mein Auto: 7er
Hey Ace this is great work.
I am on the hunt now for a TCU
Do you have a PN for the update TCU??
E65 Sport
Old 02-11-2012, 08:13 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Old 02-12-2012, 04:45 AM
PAPER's Avatar
CRISP & CLEAN
Originally Posted by AceFX View Post
I sent the file , you should have mail
Old 02-12-2012, 04:59 AM
Banned
Got it....many thanks
Old 02-13-2012, 06:02 PM
PAPER's Avatar
CRISP & CLEAN
Old 02-13-2012, 07:57 PM
PAPER's Avatar
CRISP & CLEAN
Sent from my GT-I9100 using Bimmer App
Old 02-13-2012, 08:03 PM
PAPER's Avatar
CRISP & CLEAN
Old 02-14-2012, 08:10 AM
PAPER's Avatar
CRISP & CLEAN
Yes my car does have them .
Old 02-14-2012, 08:12 AM
PAPER's Avatar
CRISP & CLEAN
Old 02-16-2012, 03:32 PM
politby's Avatar
politby politby is offline
Mein Auto: 2005 750i
Originally Posted by stuartjohn24 View Post
can the same coding be done with NCS expert?
Thanks again!
Yes. Read the module (MMI in this case) with NCS expert and you get the NETTODAT.TRC file which contain the command lines Ace is referring to.
You can modify the hex value on line 3002 as per Ace's guide and save the file as NETTODAT.MAN then code the MMI using the basic functions/coapiCodeSgByNettoDATA Type "NETTODAT.MAN".
Old 02-16-2012, 04:08 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Hi politby,
Thanks for that, I will read the MMI this weekend and have a look. Im using INPA and DIS on my macbook using a virtual machine inside a virtual machine which is pretty slow! So im setting up a old computer in the garage at the moment purely for diagnostics etc...
I will take a picture of the unit this weekend, The wiring sounds simple just need to find the diagrams for my unit and the new one i will be fitting and match the connections up.
Thanks again
Stuart
Old 02-16-2012, 05:47 PM
PAPER's Avatar
CRISP & CLEAN
ID:	312546   Click image for larger version
ID:	312547   Click image for larger version
ID:	312548   Click image for larger version
ID:	312549   Click image for larger version
Old 02-16-2012, 06:27 PM
PAPER's Avatar
CRISP & CLEAN
for some reason the pic's showed upside down ???
& my phone is tripping GRRRRRRRRRRR
Old 02-16-2012, 06:43 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
Wow Good luck!
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 02-16-2012, 11:47 PM
PAPER's Avatar
CRISP & CLEAN
Old 02-17-2012, 08:49 AM
politby's Avatar
Originally Posted by Rostman View Post
I hope i've got facelift TCU)
Now wouldn't it be swell if someone could tell us the definition of a "facelift TCU".
There are so many TCU part numbers in the BMW listings that it makes my brain hurt...
Old 02-17-2012, 09:34 AM
politby's Avatar
Okay, while working on creating a 32-bit Win7 partition so I can run NCS Expert natively, I made a little dry run.
I used Revtor's NCSdummy tool to compare the NETTODAT.TRC files before and after the change on command line 3002. That's a handy function to find out what a hex code change in the nettodat file will result in the human "readable" parameter file:
Code:
Generated with NCS Dummy version 0.5.0.5 - copyright İ 2011 revtor software
Output       : Trace Differences
Chassis      : E65 (E65,E66,E67,E68)
Module       : MMI_E65.C03
Trace file 1 : "C:\NCSEXPER\WORK\NETTODAT.TRC" (Nettodata)
Trace file 2 : "C:\NCSEXPER\WORK\NETTODAT2.TRC" (Nettodata)
Differences  : Yes
1   2   FUNCTION KEYWORD        FUNCTION KEYWORD TRANSLATION
            PARAMETER KEYWORD       PARAMETER KEYWORD TRANSLATION
        ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
        BLUETOOTH_HANDY
*           nicht_aktiv             not active
    *       aktiv                   active
As you can see the parameter affected by the "3D" to "3F" change in the 7th hex pair is the BLUETOOTH_HANDY value which gets set to active. "Handy", of course, being the German word for cellphone.
Now, it's anybody´s guess why something this obvious has not been successfully attempted by anyone on the German 7-forum, but my hunch is that this simple coding change may not work on every pre-sep-06 facelift car because the TCU versions may not necessarily be timed with the facelift date (s).
And for those using NCS Expert this means that coding this can be done via the standard method so coding by way of NETTODAT is not necessary.
Old 02-17-2012, 03:30 PM
Mr_Burger's Avatar
Mr_Burger Mr_Burger is offline
2007 760Li User
Mein Auto: 2007 760Li
Hi Ace, are you guessing the hex values or do you have some reference info re you're settings?
My 760Li - Fully Loaded
Old 02-17-2012, 04:47 PM
Mr_Burger's Avatar
2007 760Li User
Shame we can't get a source code dump from BMW
BTW, we s/w engineers don't call them hex pairs, each pair = 1 byte (or 8 bits)
Old 02-17-2012, 06:45 PM
Mr_Burger's Avatar
2007 760Li User
lol, I hear ya...Just don't mention upper/lower nibbles and you'll be fine
Old 02-18-2012, 01:37 AM
politby's Avatar
Hi politby,
A VM inside a VM? So you're what, running a Windows VM in VMware Fusion on the Mac and then running VMware Workstation or VirtualPC in that VM? Cool, but why?
I've been working in virtualization for 6 years and only just now found the occasion to use it personally... to be able to run old 16-bit BMW software on a modern O/S...
Rather incredible that no one at BMW has leaked these specs, in all these years. Makes me wonder what they are threatened with if they did...
Old 02-18-2012, 01:40 AM
politby's Avatar
Good morning Politby.........it's got cold here now....now snow....bit it's down to 16.7 C.
Well at least we are mosquito free
Old 02-18-2012, 03:30 AM
Mein Auto: BMW F01
Yeah pretty much! I gave up on windows as a main OS many years ago! I have virtual box running on the mac which has a copy of windows running on it, this runs the INPA and the diagnostic head emulator, I then have VMware running inside the windows virtual machine to run the dis software. It does actually work but just very slowly!
I don't have any windows capable machines at home, I'm looking to get something setup purely for diagnostics and coding.
