7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code! |
#51
You mentioned 6k? Alex told me it is 8k that we use.
2012 BMW 640i (AC Schnitzer Package) 2011 Mercedes E250 2007 Ford Mondeo "Age is but a statistic that has no relevance to enjoyment of horsepower" |
#52
I also have 8k from alpinemss they don't match with The headlights.
#53
6K vs 8K Lights
I've had 8K lights on other cars and they look too blue. 10K is deep blue and 12K is purple. 3K is yellow. The 6K is an almost exact match to the OE HID's! Alex would probably exchange if you ask. My original wire harness was defective and gave me "lamp out" codes when trying to turn on the daytime driving lights, but he was quick to replace it and that completely fixed problem.
#54
FalconFlyer,
You have the 6k or 8k?
#55
I have 8k.... They are the same color as the new OEM LED AE lights...
2013 BMW M5 2011 BMW X5 5.0 M Sport 2011 BMW 335I Convertible 2011 BMW 750Li M Sport (Sold) 2012 BMW Z4 35is (Sold) |
#56
#57
Don't feel too bad, Samlambo- I ordered mine from Alex on 2/06 and they were finally shipped on 2/16, and that's domestic here in the US. My guess is that he's having inventory issues after an uptick in popularity of these lights. His e-mail communication etiquette could be better- it wasn't until I e-mailed 3 times and called once that he sent me tracking info. Not a biggie, but he needs to step up to the plate when it comes to customer service.
#59
HID Lights
I can probably get you guys this same kit for $165 shipped. Let me know.
#60
how can I get in contact with Alex?
#61
Alex at Alpine Motorsports; alex@alpinemss.com
________________________________________ 2012 BMW F02 750LiX M-Sport Dinan Stage III, Dinan Exhaust, H&R Sport Springs 2012 BMW F12 650iC Dinan Stage III, Dinan Exhaust, Dinan Shockware |
#62
8K vs 6K
Here are some more examples of the difference between 8K vs 6K HID's. I personally prefer the whiter look of 6K. Stock is around 4.2K (yellowish). My personal car (under signature) has the 6K's which I specified when ordering otherwise you will get 8K.
#63
Thanks for showing the difference, I prefer the 8k, still find the 6k a little yellowish.
#64
Hey Samlambo... I did too... plus the AE are so bright at night.. you hardly notice the headlights anymore :-)
#65
I just installed my 8000K Angel Eyes from Alpine MSS. A couple of observations:
1. On the 7 series bulb set that Alex sends, there is no negative/ground contact to hook up, only a positive which connects to the positive battery terminal. 2. The round light housing cap must have a ONE INCH hole drilled right through the center, not the 1/2" hole as indicated elsewhere on this board. The bulb assembly has a double flange soft silicon-rubber seal that must sandwich this hole you drill, so one lip is inside and one outside. It takes a little bit of effort to pull the exterior flange out, but it makes an obvious water-tight seal when you do it correctly. I used a 1 inch spade bit and braced the cap on a piece of wood. Easy to drill; took about 10 seconds. 3. The whole deal took me about 45 minutes, but only because I obsessed about how and where to run the wires so they were hidden best. 4. I would like to retract any criticisms I made earlier about Alex- he was most helpul and very responsive to my installation-related phone call, and he wants to see a satisfied customer!
#66
Looks great! Well done.
My car's a lease and I was thinking of installing these until I noticed the part about drilling into the cap. Are these caps something that can be easily replaced prior to lease turn in so they don't charge me for it?
2011 750i Jet Black / Ebony Interior / Black Ash Wood Trim Factory Options: Luxury Seating Package / Premium Sound Package / 19" Alloy Radial-Spoke Wheels / Rear View Camera Aftermarket Options: 30% Ceramic Tint / PIAA Xtreme White Angel Eyes / DVD In Motion |
#68
When you go to turn in your car your dealer can replace the cap for about $13 a piece. Not a big deal. The installation is really easy if you're even marginally mechanically inclined, and either Alex or members of this board are happy to provide assistance.
How does it work without a ground? That's unusual to have something powered w a fuse and no ground.
#70
The new HID set up grounds through the cars existing wire harness. It works!!
#71
what do we do for fog hid?
#72
Falcon.,
does the ballast get hot? cuz in your Z4., you fitted one of the ballast between the wheel frame and plastic. I wonder if it get hot..did it melt the plastic at all? And you got PM,
[SIZE=2]a.k.a. Tommy T |
#73
Ok.. so after more reading.. I when ahead and order Alex F01/f02 and E70 kit.. Hope to get them soon.. -Gassy.. on your#2.. do you find it easier to install the bulb assembly thru the light cover, then install the bulb into the socket. Or install the HID bulb into the socket, then run the bulb assembly thru the cover?. -Falcon - how was the install on the E70? how was access the H8 bulbs compare to the F01? any tips. and yes.. Alex was very helpful and very quick to reply emails
#74
Tdrag- I think you will find it easier to insert the replacement bulb in the light housing first, then pull the outer rubber flange through the hole you drill in the light cover afterwards. There is plenty of room inside the light housing to wrap and tuck the wires between the bulb and the light housing cover.
TDrag 97... nope.. I have not noticed the ballasts that hot.. no issues at all.... but I will keep a eye one it.... also the installation was a breeze... the only issue I had with my Z4 was the fact that you are supposed to remove the plastic spacer ring around the bulb... it took me 30 minutes to realize there was a issue... so I called Alex.. .and found out what I did wrong....
