Angel Eyes for 03 745i - Bimmerfest - BMW Forums
Old 02-14-2012, 08:46 AM
Sircas Sircas is offline
It's the Machine in Me!
Mein Auto: 06 M6, 94 840CI & 88 M3
I am getting ready to replace my Angel Eyes. I am looking at the White Ebay ones.
Are you replacing the
Bulbs
1.) EFX 5W XENON LED ANGEL EYE KIT BMW 745i 745Li 745 02-05 = $44.99
or
Whole Ring
2.) E39/E65 525/530/540/745 7000K CCFL Angel Eye Halo Ring = $38.99
Who has purchase their replacement from Ebay, which one & how has it been working?
Old 02-14-2012, 09:09 AM
angermanagement angermanagement is offline
Mein Auto: 754i
i forget the name brand i bought, but all you need is the bulbs. you do not need to chacnge out the rings. very easy.. but you will have to take the bumper cover off to get to them, especially the passenger side. there is a DIY picture slides that someone has added in doing so. i used it, and it was very helpful. had to take my bumper cover off twice now, and i can do it less than 15 minutes.. 5W white is a good choice, i went blue, and wish i had went white.. youll need, nut driver, hex set, and a flat and phillips head screw driver. and thats about it..
Old 02-14-2012, 10:22 AM
I read that 745i 2002 - 2004 did not require the bumper removal. I may have read wrong!
I just ordered the White 2 x 5w = 6000w. I ordered from BMW Led. He states this one has the larger diameter casing & is metal for better heat dispersment! $38 + free delivery here Fri/Sat. Will install on Sat (hopefully)
I am also cleaning the inside Lense cover!
Old 02-14-2012, 11:26 AM
Mein Auto: 754i
good idea cleaning lens covers. i didnt even think about doing that. hope it works out for you. and as far as the removing the bumper cover, i have an 02 745i, and you can possibly get to the driver side, but as far as the passenger side, there is a big metal braket in your way, so the headlight has to be loosened and brought forward to get them out. good luck. you shouldnt have any problems. just take your time.. show pics when youre all done.
Old 02-14-2012, 11:34 AM
cjennjr cjennjr is offline
Mein Auto: 2002 BMW 745i
I cleaned the insides of my lens and what a difference!!! I have MTEC V2's and am thinking about upgrading. If the ones on Ebay are just as good as MTEC for hundreds less, I may go for it!!
Black Beauty
Old 02-17-2012, 09:33 AM
Did you have to remove the Bumber cover to get the bulbs? Or just remove light assembly screws & slide the assembly forward to access?
I am doing tomorrow morning. I plan on replacing the Angel Eye bulbs w/White, cleaning the interior Lense (passenger side has lots of oxidation inside) & resealing the lenses with Clear Permatex sealants.
Should look nice when I am finished!
Old 02-21-2012, 07:17 AM
djdelite djdelite is offline
Mein Auto: 745Li 2005
i need to do the same..ughhh...im just not crafty like that..I gotta find someone to do this job..
Old 02-21-2012, 08:51 AM
On 02-05, you DO NOT have to remove the bumper. Just remove 4 screws that hold the headlight assembly in place, slide the headlights forward to get to the bulb, and you should be good to go. However, you will have to remove the air filter housing on the passenger side to maneuver better since it is a tight fit. Very easy job...
Black Beauty
Old 02-21-2012, 08:54 AM
djdelite,
I did not & you do not have to remove the bumper to install the new Angel eyes. It's simple took 20 minutes. The passenger requires you to remove the air intake box or just remove the 2 screws that hold it in place. I went to youtube. I guy had posted there!
1.) Get the Angel eye bulbs from ebay BMW led 1 yr warranty (ebayer)
2.) Youtube for the installation or I can provide the link!
Very Easy.
I however, need to clean the Oxidation from the inside of my passenger side Lense! I cannot remove the Lense cover without removing the bumber! But, I have already replaced Angel Eye bulbs = 20/30 minutes depending on hand side! I am 6'1" with big hands. Go for it!
Old 02-21-2012, 10:41 AM
Originally Posted by Sircas View Post
djdelite,
Very Easy.
lol im' 6'2 big hands... I know it can be done....I need to just do it... i think its the right side that scares me... but if u could pass me the youtube link I may go for it...I say may with caution.... Can you also send me an ebay link..sorry for being so needy but thanks for the confidence...
Old 02-21-2012, 10:57 AM
SKT174 SKT174 is offline
Officially Welcomed to the 'Fest!
Mein Auto: BMW F01 745i
I think I have to replace the entire unit soon, my both sides rings gives different color
Old 02-21-2012, 11:42 AM
Angel Eye Bulbs - BMW Led - $37.85 (White)
Ebay.com
LED Angel Eye Halo Light No Error BMW 04-07 E60 525i 530i xi M5 E61 06-07 E83 X3
Installation
youtube.com/ANGEL EYES INSTALLATION BMW E65 E66 745 750 760 SUPER WHITE BLUE RED LIGHTS 2000 TO 2010
Old 02-21-2012, 11:52 AM
quarterto8's Avatar
quarterto8 quarterto8 is offline
Send a message via MSN to quarterto8 Send a message via Yahoo to quarterto8
Mein Auto: 2004 bmw 745i
how are you guys planning to clean or have cleaned the inside of your lens?
2004 BMW 745I (SOLD)
2014 BMW 750LI
2008 BMW ALPINA B7
2016 JEEP GRAND CHEROKEE
Old 02-21-2012, 01:34 PM
Removing the Lense Cover. I am using 3M wet/dry Emperior 2000 grit sandpaper w/ water and Turtle Wax. Windex & Dry. Then use clear permatex to seal the Lense cover.
However, you have to remove the bumper to remove the Lense cover. I am still looking for the main bolts that hold the bumper on. I believe the bolts are behind the 4 circles (2 on each side). Unless these are the front sensor! Not for sure! I will look again tomorrow afternoon or this weekend! If you know or find out please post!
Old 02-21-2012, 02:17 PM
Bendare2 Bendare2 is offline
Mein Auto: '02 745LI
Hope you are really good with a dremel. The lense covers do not come off easily.
Old 02-21-2012, 03:40 PM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
Mein Auto: 335i
+1. its much easier for install on 02-05
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
Old 01-30-2013, 11:19 AM
Cip Cip is offline
Mein Auto: 750li
Hello
How do you replace the angel lite bulbs in a bmw 745i without removing the front bumper
Old 01-30-2013, 11:31 AM
First_745Li's Avatar
Mein Auto: 2007 Audi A8
Cjennjr explained it in a previous post.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 01-30-2013, 11:36 AM
Originally Posted by Cip View Post
Hello
http://www.bimmerfest.com/forums/sho...d.php?t=287035
and / or
Youtube video: Key this into search!
"ANGEL EYES INSTALLATION BMW E65 E66 745 750 760 SUPER WHITE BLUE RED LIGHTS 2000 TO 2010"
YOU DO NOT HAVE TO REMOVE THE BUMBER JUST TO REPLACE BULBS!!!
Good Luck!!
Old 01-30-2013, 01:45 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
MTEC 3 are the most commonly used on this forum. Here are how mine look:
(Pics taken in broad daylight)
ID:	359885   Click image for larger version
Fun Doesnt Come Cheap!
Old 01-30-2013, 02:20 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
I have Mtec V2.1's that I removed from my car last night. They are 1 year old and in original box. Selling for $70 + $5 shipping. Mtecs are the best in my opinion. PM we with interest . Thanks.
Old 01-30-2013, 04:15 PM
Bulbs
or
Whole Ring
You dont need the ring... Just get #1.. oh and I know those guys.. tell them Delight Marketing sent you.. He'll take care of you.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 01-30-2013, 04:16 PM
When we gunna see that F01 wjjklj??
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 01-30-2013, 05:31 PM
Cip Cip is offline
Mein Auto: 750li
thank you -- done --- crazy car!
Old 01-30-2013, 05:37 PM
wjjklj's Avatar
I am hoping by Friday. I am waiting for some funds to clear. The suspense is killing me.
