E34 (1989 - 1995)
Old 02-21-2012, 02:19 PM
macster123 macster123 is offline
Mein Auto: 1993 525i saloon
Question patchy acceleration
Hi Friends,another issue with my 1993 e34 525i.My car has not been touched since my last post as my mechanic is ill.Another problem I`ve had though,is that if I accelerate to over 4000rpm to overtake,my car responds though not as well as it should.But if I try to accelerate again I get no response and it seems to cruise and splutter for a while before it recovers.I dont get this problem at lower revs. thanks again.
Old 02-21-2012, 03:55 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is online now
Manualaholic
Mein Auto: 01 330Ci/94 530i
There is another thread about similar problems here: http://www.bimmerfest.com/forums/sho...d.php?t=601970
My first thought on that thread was a fuel filter. Higher RPMs = higher demand for fuel at the fuel rail, therefore a restricted fuel flow would cause your symptoms. Do you have a CEL? Have you performed the stomp test? How are the spark plugs? Any other issues with the car currently?
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
Old 02-21-2012, 08:05 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Good list...Add a major vacuum leak as another cause.
Have a smoke test run if possible, or learn to smoke.
Old 02-21-2012, 10:00 PM
Smile
Hi paperplane94,thanks for your reply.my car ran fast and sharp for a year after I bought it,then problems started.I was getting sudden power loss at 5000rpm and self reving on idle.fitted new maf and lambda and had a full service.Things improved but it runs about 70% of what it used to.I only do about 4k miles per year at present because of these problems.some days its nearly back to normal then it runs rough again.No CEL and vacuum been checked.thanks
Old 02-21-2012, 10:05 PM
If you have confirmed 0 vacuum leaks with a smoke test the I would start checking things listed by Goosefoot33 above^.
Good luck!
