Old 02-20-2012, 03:49 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Originally Posted by adjmcloon View Post
So what are the common items that stayed throughout all of the changes, that could be the culprit? Brake booster, air box (?), etc.?
Bad mechanics.
Old 02-20-2012, 04:01 PM
bimmerteck bimmerteck is offline
BMW Magician
Mein Auto: e30 M50ish
Originally Posted by anothergeezer View Post
bad mechanics.
Old 02-20-2012, 04:07 PM
Misfit_408 Misfit_408 is offline
Mein Auto: 1998 540i
From what I understand- everything. I was just looking at it all while cleaning the ICV and even found an ATF leak. I'm trying to track where from. This car feels like a lost cause.
the only thing they did different on the last engine that kept it around for half a year was switch some kind of harness. I'll try and find out what kind.
Old 02-20-2012, 04:08 PM
Originally Posted by bimmerteck View Post
Absolutely, but hey, I wasn't paying
Old 02-20-2012, 04:09 PM
Entwicklung 39
There truly is a benefit to using a dedicated Bimmer indie. People may scoff at how much I pay for labor, but my shop gets a Christmas card from me every year.
3D is probably the best shop I have ever done business with.
Old 02-20-2012, 04:27 PM
OK HOLY ****! There's a ton of water in my brakes. I really wanna try and mess with this my self. Dont know if I should. I read a few thing about syphoning water out of the break booster. Kinda wanna try that to see if that seems to be the problem then replace it after, given it works out.
Old 02-20-2012, 04:29 PM
Entwicklung 39
There are a few topics on this issue. It's not an easy fix but it can be done.
Old 02-22-2012, 12:12 PM
Thanks quick99si! I found that in that well under the driver side cabin filter, the brake booster was half submerged in water. Dont think I'll have to take her in just yet. After a lot of trick vacum work and checking a lot of hoses things seem to be good. After I got the water out of that area surrounding the booster it stopped making any water type noises when pressing the pedal. I never actaully got even a drop of water out of the booster it self but there was a little in the vacum hosing between there and the ICV. At this point it's running great and the brakes feel great. Think I'll just take it in to get a general service. I'm at at 132k on the odometer and have no idea what on this 6th engine.
Old 02-22-2012, 04:16 PM
Quick99Si Quick99Si is offline
Mein Auto: 2004 M3 6MT
Glad you found the problem, but I still suggest totally draining the booster and then thoroughly cleaning the nearby water drains. It has ruined your engine before, and it will happen again if you don't do something about it. Good luck!
540i - Stock/Sport / 6MT / 13.9@100mph
WS6 - 231/234 / 6MT / 4.10 / 410rwhp
ITR - 262/262 / 5MT / 12.2:1 / 9600rpm
540i/6 Sport, Jet Black, Style 65, LED tail, DICE+GROM USB, !CDV, Redline MT-90, M1 0-40w
Old 02-23-2012, 06:46 AM
9bmw7 9bmw7 is offline
Mein Auto: 1997 BMW 528I not yet tho
Wow, good call Quick99si!! That was so good that you helped somebody fix a problem as big as that!! Thats what these forums are for! I am glad to see them finally work every now and then. lol
540i, e39, engine, icv, idle
