E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
#76
2005 545i 68k miles. So far. **** hit the fan all at once. Oil leaking from the driver side of the engine, dynamic drive malfunction causing my dash lights to dim and etc.., and a coolant leak. Hope you guys don't have to go through this...
#77
The '06 530i Sport Premium has clocked 68,975 miles and no issues other than faulty seat sensor that was replaced under CPO.
“The bravest are surely those who have the clearest vision of what is before them, glory and danger alike, and yet notwithstanding, go out to meet it.” - Thucydides
#78
2008 535xi with 13,900 miles. No problems.
Love the car so far.
#79
'08 535xi with 36000 miiles and owned since Feb '11
#80
08 535xi owned since April '11 with currently 36,500 miles. HPFP replaced before I bought the car. Since then, the battery was replaced. Other then that - no major issues (knock on wood)
'08 BMW 535xi '02 Porsche 911 '08 VW Eos (commuter car) |
#81
I don't understand how ppl can be changing their batteries after only 30,000 miles...
2005 525i, 20% tint, blue & white angels, xenon kit. |
#82
Almost 87000 miles.
#84
2006 525xi with 43k.
So far so good. Just normal maintenance besides a Sunroof seal replaced (under CPO) and a hood latch. fingers crossed F
2006 | 525xi | 6-speed Manual Silbergrau Metallic | Black Dakota Leather | Anthracite Bamboo | Comfort Access | Cold Weather | Navigation | Xenon | Sun Shades ![]() 1993 | Honda Civic Del Sol | 221k+ WoooHooo ![]() 1985 | Buick Regal | 120k dead 1984 | Toyota Tercel 4WD Wagon | 221k dead 1976 | Buick LeSabre | 83k dead 1979 | Oldsmobile Wagon | 91k dead |
#85
mileage
2007 525i w/87k. So far only rear brakes, oild changes, cabin /air filters and wiper blades. Fingers crossed for another 86K. Hwy fuel economy in 25-29 range under 75. Will replace battery and front brakes soon.
2007 525I AND LOVING IT 2005 RX330 1988 Jeep Comanche (Olympics Edition) BMWCCA #456336 "..... a donut without a hole is.... a danish" |
#86
2004 bmw 525i, 74k miles.. never taken to the dealers before. I just do it all myself or ask these guys! =)
#87
Bmw 545
I have a 2004 BMW 545i with 112,000 miles on it and have had the following: New Water Pump( Graf..Kinda loud but ok for now), Thermostat at 108k. Mechatronic seal at 72k and 109k($900.00 BMW) Leak near alternator at 90k(warranty). New Plugs at 100k and new Coils at 108k( Bosch from Ebay 23.00 ea). Coolant expansion tank at 44k(warranty). Rear tires Michelin Pilot Sport(So Smooth!!) Tie Rods replaced at 106k. Battery replaced at 102k. Oil Level Sensor replaced at 109k due to faulty Overheating signals being sent to the DME($465.00 and 3 days of diagnosis from BMW). Front brakes and rotors and sensor 3 times and Rear brakes and rotors/sensor 2 times. The car runs perfectly!! Very smooth tranny shifts and lots of power. Recently purchased an OBD reader to do any future maint myself. The only issue I have is some creaking from the rear shelf area....otherwise, its a winner
#88
135,120 miles so far on my 2004 545i. Just had repairs for oil leaks and SES warning light turning on. Shop replaced thermostat & water pump, valve cover gaskets, alternator bracket seal, PCV valves, ECU cooling fan and oil level sensor. Also had my crank pulley replaced since it was wobbling. Not too bad for a high milage BMW.
While the car was under warranty, I made several trips to the dealership because of transmission surge problems. After several fixes that did not work, the transmission was finally replaced and that did the trick. My car is now out of warranty but the transmission still is until Mach 2012. No issues with it so far. Car still runs great!
I think I need to drive more......27K on a 2009 535i xDrive only issue was two HPFP's
Current: 2012 550i xDrive | Dinan Stage II | DGMetallic II | Black Nappa | Anthracite | Convenience | Cold Weather | Driver Assistance | Luxury Seating | M Sport | Premium Sound | ARS | Paddles | Active Cruise | Ceramic | BMW Apps Current: 2012 X3 2.8 | Space Gray Retired: 2009 535i xDrive | Jet Black Retired: 2009 X3 Jet Black Retired: 2007 530xi | Monaco Blue Retired: 2003 530i | Sterling Gray BMWCCA:458650 |
#90
'07 550 w/ 63k. No huge problems, gotta get in and fix strut brace creak at the firewall and the e-box fan still too loud but CPO not helping ("Certain Problems Overlooked"). Still occasionally think about selling but it's just too great...hoping the 550 is long-laster for me.
"There's a lotta things about me you don't know anything about, Dottie. Things you wouldn't understand. Things you couldn't understand. Things you shouldn't understand." |
#91
153,700 miles today. Like many posts previous I had similar oil leaks issues. Most recently the alternator bracket gasket. I replaced the 1.89 gasket. ( two days to do it)
#92
"turned over" 37k miles this week on '08 535xi
#93
2009 535i Sport ... 37,100 miles ... HPFP replaced June 2009 after crapping out, and replaced again under recall with newer version (even though the first replacement seemed okay) ... the only other problem is a weird one ... the iDrive screen occasionally blinks off the on. Doesn't affect the driving, but after numerous tries to fix at the dealer, I gave up and just ignore it when it happens (and the car does NOT need to be moving when it happens, so no obvious loose connections). However, I think it could likely be a connection that heats up a bit, then cools quickly (I've had that happen in a computer years ago).
Anyway, love the car ... get 25mpg combined, and 28mpg on a trip, and I pass just about anybody I want!
BMW CCA Member 2009 535i Sport, Jet Black | Cobb Stage 1 | BMS Drop-in Filter | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus (no runflats) 2008 528i (Retired) 2006 328ci (Retired) 1975 US Army (Retired) Last edited by burnie35; 02-25-2012 at 10:37 AM. |
#94
50,100 on 2006 550i. And it too, is a rocket. Heh heh.
#95
137k miles 07 530xi No major repairs still going strong.
#96
Just broke 50K. Day time running lights replaced, Driver-side rear light cluster wiring and harness replaced twice, push rods and roller arm replaced due to tapping. All under warranty.
I've had my Bimmer experience. I'll probably keep it for a few more years and then trade it in for an Infinity, Lexus, or Honda. This car (528ix)is terribly sluggish for all that its touted for. I should have bought a 535 iX and put up with the HPFP issues. |
#97
73k miles on my 525I. Had brakes replaced.
Sent from my T-Mobile G2 using Bimmer App |
#98
2008 535i with 33.5 on it. No problems. HPFP and injectors replaced under recall about 18 months ago.
And not e60, but a 2003 Z4 with 44K on it, FWIW. No problems with the Z... the usual maintenance and replaced the godawful runflats with some real tires + AAA and a cellphone (never needed it yet). Last edited by KCbimmer99; 02-25-2012 at 08:26 PM. |
#99
IMHO the 528ix is not a car that does BMW justice (at least unmodded). The 328i is not sluggish or under powered. But throw the power demands of AWD on that engine and then add 3-400 extra pounds to slap it in a 5xx body... Not adequate. 328ix OR 528i probably okay. But the 5 PLUS the ix is too much. That's a car with the kind of "oomph" you'd get from... well... Infinity, Lexus or Honda (assuming you really mean Acura on the latter). Bottom line is the advice you see here regularly on the "528 vs. 535" threads: "If you're thinking about a 528... don't drive a 535 or the 528 won't be appealing any more." |
#100
2008 528i, 50K miles no issues just battery change same week due to defective battery, replaced under warranty. Love the car more every day.
