E46 (1999 - 2006)
Old 02-25-2012, 10:34 PM
LOUDLIQUID LOUDLIQUID is offline
Mein Auto: 03' BMW 330i
Angry Having trouble getting car to turn over
I have a 03' BMW 330i been having lots of problems but the worst one is when I turn the key to start it and push the clutch in I turn to acc gets power fuel pump turns on, then I turn the start it starter relay clicks on and doesn't turn over. I'm starting to think its the starter solinoid. Can anyone help
Old 02-25-2012, 11:35 PM
KenG KenG is offline
Mein Auto: 00' 323ci 5sp mt
It can be multiple things
first test the battery (free at any Autozone)
mentioned that the fuel pump works so we can rule that out
you can give the starter solenoid a decent tap and see if that help
if none of the above work
it can multiple things like key, ignition switch, clutch switch etc..
a little more info would help us festers' help you better diagnose
We never really grow up; we only learn how to act in public.
-unknown
I like Chile Verde Burritos
Old 02-26-2012, 01:22 AM
Lightbulb
Also it will sometimes start if I hold it in the start position for while. Sometimes. Or keep turning key repeated time. It takes half hour or more. Idk if that matter
Old 02-26-2012, 11:34 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
How old is your battery ? If it`s over 4 years old, or you don`t know, replacing it with a new one ($100 at Walmart or Autozone) will likely solve your problem. Buy a battery terminal cleaning tool, and clean ALL cable connections, making especially sure the ground to the car`s chassis is clean & tight.
The road goes ever onward....
(R.I.P. Jever)
Old 02-26-2012, 05:57 PM
Shop says to check fuse 12 check ground from chassis to subframe, battery is good they did a VAP 40 and it passed.
Old 02-26-2012, 05:59 PM
They also said it could be a 530 starting problem. Anyone know what that is??? They also said try unplugging the MAF so what's that??? Need help baddly
Old 02-26-2012, 06:20 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Had similar problems on my Jeep once. No CEL though. Replaced crank sensor and problem solved
Old 02-26-2012, 07:53 PM
Fast Bob's Avatar
Keeping it surreal
"VAP 40 is a test for *your cholesterol level*
"VAT 40" is a battery test....do you know what kind of a load they placed on the battery ?
(R.I.P. Jever)
Old 02-26-2012, 08:20 PM
I do not but I could ask. And it's been a while since I last had a change to test the battery coulda swore it was VAP lol well my mistake.
starter, starter problem, won't crank
