I found the donor today, a 12/2004 build ZHP with 72k miles. Bashed front end. everything rear of the accessories on the motor is in good shape or better. Car starts and runs; interior is lovely, it's just the front end that's ugly as hell...
I will be putting the following items into the wagon: M54B30 6MT Driveshaft Brakes (F & R) Steering rack (if truly undamaged) Front Control Arms (if truly undamaged) Rear trailing arms (with new bushings) Steering wheel HK Stereo Alcantara shift and parking brake boots Dashboard and Door trim ECU, EWS, Cluster, keys Any other suggestions? Everything else will be either scrapped or sold on eBay/craigslist...
CONGRATS! What a cool project!
Curious if we could work out a deal on the two front wheels for my two back wheels? Why would you not put the seats in the wagon? Along with the dash, and the entire interior? If the A, B and C pillars are not peeling I would like to talk about those too. |
![]() The interior of the wagon is in surprisingly good shape. Plus, I'm in Texas and I don't want the death of a black interior during our 18 months of summer every year. Are you saying you'd want the 18x8s? I'm thinking that the non-track setup will be 18x8 all around. As for the rest of the interior bits, you can have first right of refusal. Not sure when I'll start pulling stuff out. Mostly because I don't know when the shipper will drop it off in front of my house.
![]() Congrats man!. Looking forward to seeing this build thats for sure.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
Yes, I wanted the 18X8's so I could run 225/40/18 all around. But sounds like you'll need them. Ya know what looks amazing in a tan colored interior? Black Cube trim! |
My thoughts exactly!!!
Very cool project
Are you installing the zhp rear diffuser and side skirts?
![]() Mods: Smoked corners, smoked side markers, smoked tails, Hamann Front lip, 35% tint, blacked out kidney grills, ZHP emblem, angel eyes, 3000K biXenons, Lumnitics Yellow Fogs, CAI, Muffler delete, Sharked, front and rear strut braces, AUX cable |
No ZHP diff?
Won't fit the wagon?
This will indeed be cool when it is finished.
Alpinweiß E46, E83, E90 (all with three pedals) BMW CCA member |
This is the first time in a thread like this that I am not sitting over here thinking "I need the trim, I need the shift boots, I need the wheel, etc, etc, etc"
My car IS that car (only not wrecked). |
Great project! You will soon have exactly the car I want.
If you were closer I'd be interested in the seats. Black on black works fine here in NH! Best of luck, and definitely post lots of pics... |
The wagon came stock with a 3.46
And from the B-pillar back it's almost completely different. Subframe and frame rails are the same, so the mounting points are the same between sedan and wagon.
I'm assuming you're doing that because you want the MS45.1? Otherwise I'd say keep your stock components, swap the gauge faces and needles into your existing cluster... that way you'd keep your original VIN (not sure if it really matters for a car that modified).
Also, I am not sure if the MS45.1 DME will play nice with the earlier version of the DSC module that came with the 01 cars. There may be other issues since BMW switched from the ZCS system to the FA system between 2001 and 2002 (both are ways how the car identifies itself to the various diagnostics tools out there)
![]() Last edited by TerraPhantm; 02-27-2012 at 07:52 PM. |
edit It looks like both cars run the same Teves MK 60 DSC III system. Should be good there. /edit Maybe I'll just do the whole freaking wiring harness
The rear diffuser isn't compatible with the stock rear bumper, and I don't really want to spend the money to get the full M-touring body kit.
You are building the car that I wanted to buy in 2004!
The donor car's seats are Alcantara?
E91 "Classic" BMW inline six, six-speed manual transmission, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats. |
Ditto.
Can't wait to see how the wagon turns out Sent from my ADR6400L using Bimmer App
Arthur John Born 02-24-11 Has already been awarded the title "Destroyer of Sleep" |
What will you be driving while the drumwagon build is in process?
Drama queens don't wear panties. |
Also make sure to grab the LCM from the ZHP so that the cluster doesn't throw a tamper dot. It'll have to be recoded to work with the touring's taillights, but that's trivial. What you'll then want to do is wipe the FA from the cluster and LCM, and copy your touring's ZCS to the "new" EWS and cluster, just so your car is still seen as a touring. The DME being newer than what it's supposed to be wont hurt anything there When you're closer to doing the electronic/coding part, feel free to PM me; I'd be glad to help out as much as I can.
I was also thinking, when you get the car, maybe we can work out a deal on me sending you my front wheels for that cars rears? I want square, one way or another. I wish you lived closer. I would love to lend my time and effort to this project. Talk about FUN! Too bad the UUC lightweight flywheel/M5 clutch kit for the 6 speed just sold on fanatics for $750. You needed that
Check out my YouTube Channel for DIY's and other fun stuff HERE Check out my BMWBLOG! Last edited by smolck; 02-28-2012 at 06:55 AM. |
Very cool project, just like what I have been thinking but with two not four doors. Will look forward to following your progress.
Count me on on buying some parts. I am wanting some interior crap. So when you get to point of needing to clear out, put me on a list and give me a jingle.
PT ___________________________________ |
#25
![]() Quote:
