Old 12-22-2010, 11:34 AM
RV8Pilot RV8Pilot is offline
Mein Auto: M3
Trailer hitch for 2011 X5 5.0 w/ M Sports Pkg
My dealer just called me with the sad news that the M Package X5 5.0 I ordered yestereday cannot accomodate BMW's trailer hitch. It took me a month to whittle down my list of vehicles and test drives to come to the X5 solution and now this.
This is going to be a deal breaker if I can't come up with a solution. Any one out there have any experience with fitting this on an M- Package X5?
Thanks.
Old 12-22-2010, 12:09 PM
ChuckGr ChuckGr is offline
Mein Auto: X5 35D
Jody,
You might check out these guys. They have hitches that are designed to avoid cutouts. There isn't much as far as applications for different cars on the website so you will have to call them.
http://www.execuhitch.com/
Chuck
Old 12-22-2010, 06:48 PM
Mein Auto: M3
Thanks Chuck. I went to their site and there wasn't any information under BMW so I'll try and give them a call in the am.
Old 12-22-2010, 07:21 PM
335xray 335xray is offline
Mein Auto: X5 50i M Sport
Someone, somewhere, (xoutpost, xbimmers, or here) did a custom cutout on their M Sport package with a hitch that looked very nice. Factory fit and finish. If you don't want that, then getting a Non Sport, version with Adaptive drive will give you almost the same thing...no painted moldings and bumper but....you can tow your jet ski
X
___________________________________
PCD 12/3/10: 2011 X5 50i Alpine White/cinnamon with M-Sport 20"s/tech/premium/cold/premium sound/Sirius/HUD/comfort access/rear heated seat/multi-contour.
Wifey's ride: 2011 X5 35i SA Vermillion Red/Tobacco/Walnut Tech 20", Cold, Prem Sound, rear climate, CA
Old 12-22-2010, 07:22 PM
Found it...
http://www.xoutpost.com/bmw-sav-foru...ification.html
X
Old 12-22-2010, 10:23 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
Dealer will not install it but a good body shop can and it will look fine. The stealer will need to program the hitch lights
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 12-23-2010, 05:30 AM
Mein Auto: M3
Thanks for the sources, Ill check them out.
I know I could just drop the M Sport pkge but I really like the looks of the painted wheel arches and the front valence. The pictures that I have seen of the standard X5 with the hitch offered by BMW is not something I would want either with that big cutout and surround trim. I'd like to know what BMW was thinking when they designed the back of the X5 and called it a Sport Activity Vehicle? Does it imply that the X5 is the Sport part or that you can use it to get to or use it for other sports, e.g. towing a motorcycle trailer, carrying bicycles on a receiver hitch carrier? It all seems like an afterthought to me.
J
Old 12-23-2010, 06:20 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I did the drawtight on my 2011 X5 and I like it much better than the BMW hitch as it does not require you to hack up and ruin your bumper - I just had to trim a little under the bumper where you cannot see to cut a slot where the support comes down to the receiver, but you would have to crawl under the car to see it - no cutting on the face or visible pieces of the bumper. I did the wiring myself with aftermarket wiring, but you could just order the BMW wiring harness and have the car programmed just like the BMW hitch setup, but use the Drawtight hitch to work better with your bumper.
Here is a pic of it http://www.bimmerfest.com/forums/sho...&postcount=122
Rob
2008 335i Vert Montego/Saddle/Grey Poplar
2014 X3 35i Space Grey/Chestnut/Fineline Wave
Old 10-19-2011, 12:54 PM
CurtisF CurtisF is offline
Mein Auto: X5 M
Draw-Tite Hitch
Rob,
Which draw-tite hitch did you install on your X5M? What's it rated at and the road-height of the hitch? I'm looking at the 2012 X5M, and need to have a hitch in order to pull around my son's 4-wheelers..
Thanks,
Old 10-19-2011, 03:56 PM
Mein Auto: M3
Execuhitch in Atlanta is what I wound up having installed. I love it because unless the receiver is in you can't see anything from the back of the vehicle.
Old 10-19-2011, 04:46 PM
blacker2411 blacker2411 is offline
Mein Auto: 2012 BMW X5 SAV M-Sport
I also installed the Execuhitch myself on my 2012 X5 M-Sport... It took me about 4 hours and I must say that the hardest part was not the removal of the bumper (a couple of hidden screws under wheel arches) but stuffing the wiring harness thru the grommet. There is a large connector that plugs into the electronic module on the outside of the vehicle (under the bumper area) that is impossible to stuff thru the small grommet. The wiring is pretty straight forward inside the vehicle and everything worked first time with no error codes thrown by the computer. My dealer refused to install the hitch because it wasn't BMW OEM... I reminded them that there was NO OPTION for M-Sport and they acted like it wasn't their problem... They do charge about $700 labor to install the BMW hitch for total price of almost $1500 I was told by the service manager.
Dan
2012 BMW X5 3.5i SAV M-Sport (Alpine White/Cinnamon Brown)
ZCV, ZCW, ZMP, 300, 456, 655, 6NF, 6NR
BMW CCA Member # 461861
Old 10-19-2011, 05:47 PM
hotbox99 hotbox99 is offline
Mein Auto: 2012 X5 diesel
Blacker, just for clarification....you didn't need your dealer at all to code for the hitch?
Old 10-19-2011, 05:55 PM
Dealer did NOTHING to code for the hitch... Execuhitch (Dean) told me when I ordered that if the vehicle was going to tow "near the limit" which I believe is ~ 6,000 lbs. then he suggested getting to program computer to help with sway control or something like that. I did hear that the programming also changed rear camera focal area to above hitch for back-up assistance. I'm not sure if that change is permanent or only when a trailer is connected to the wiring harness. If it changes rear camera all the time I would not want that modification done I like current focal length. I just switch to "top view" and hitch is pretty visible when backing up.
Dan
Old 10-20-2011, 12:11 AM
Mein Auto: X5 35D
The rear camera change is not permanent. It is normal with the trailer software. To switch to the hitch view you just push down on the iDrive knob and to switch it back to rear view push it again. The software does the trailer anti sway and turns of the rear PDC when you have a trailer attached so it does not continue to beep because it sees the attached trailer. The anti sway feature is good for any weight trailer if you have to swerve sharply to avoid something.
Chuck
Old 01-19-2012, 12:01 PM
DEAN@EXECUHITCH DEAN@EXECUHITCH is offline
Past Sponsor
Mein Auto:
Execuhitch
After a big move to Duluth, GA and retooling we are ready to serve you at Execuhitch. Please visit www.execuhitch.com. Website is constantly updated but for best most current info please contact dean@execuhitch.com or call direct with phone number posted on website.
Thanks!
Dean
Old 02-08-2012, 09:02 PM
Fanjets Fanjets is offline
Mein Auto: BMW X5
Execuhitch also has a mechanical version of the hitch which my dealer agreed to install on my new 2012 X5 M Sport. This permits use of BMW's wiring harness and computer programming. Win/Win.
Great product!
Old 02-28-2012, 07:15 PM
LnG LnG is offline
Mein Auto: 2012 X5
Hi. For those who used the Execuhitch mechanical hitch, do you happen to have the part number for the BMW wiring harness? I recently purchased this hitch and am having trouble finding the BMW wiring harness that could be used with it online. I have the 2012 X5 3.5i w/M Sports Package. Thank you!
Old 02-28-2012, 07:39 PM
Mein Auto: X5 35D
Contents of Electrical Kit:
Trailer Control Module (AHM) 61 35 9 111 947
Trailer Hitch Wiring Harness 61 12 0 412 519
These part numbers are for an earlier year e70 X5 but I don't think that the parts have changed.
Chuck
Old 02-28-2012, 09:21 PM
Mein Auto: BMW X5
If that does not work I can get numbers from my dealer.
Now I just need to permanently silence the PDC when using a bike rack.
Has anyone had success?
Old 02-29-2012, 06:14 AM
jashearer jashearer is offline
Mein Auto: X5d, CTS-V, Silverado HD
Take a look at a couple threads down about bike rack. One poster here mentioned they used a set of resistors plugged into the wire harness to simulate trailer lights. You would have to have it programmed of course to recognize it.
Jay
eidt: It was alphaod
http://www.bimmerfest.com/forums/sho...d.php?t=602980
Herbert - '12 X5 35d / Sapphire Black / Black Perf Nevada / Aluminum trim / ZPP / ZPS / ZCW / ZAV / Apps / 3rd row
Betty - '04 CTS-V / Black Raven / Black Leather & Suede / 6 speed LS6 combo 400 hp & 400 tq
Sterling - '06 Silverado HD / White / Grey Leather / LBZ Duramax - Allison 6 speed combo / Crew Cab Short Bed LT3
Old 03-01-2012, 07:17 PM
Mein Auto: BMW X5
Many thanks
Old 03-02-2012, 06:49 AM
wanderlust wanderlust is offline
Mein Auto: 2012 X5 35d
maybe just buy a used beater pickup to tow with. then dont have to worry bout hitch
powered by lemings
Though I did not know the place, I set out for the land of my dreams.
Having arrived at the land of my dreams, I found I did not know the place.
