Looking to get some great BMW parts for your car? Get the latest info on sponsor group buys, new products or simply ask a site sponsor a question here!
Old 02-28-2012, 05:18 PM
shelby745li shelby745li is offline
Mein Auto: 02 745li
when and where can i order
Old 02-29-2012, 02:17 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
PM replied...
Old 02-29-2012, 08:54 PM
rmerkushen rmerkushen is offline
Mein Auto: E90 330i, E83 X3si
Technic, I am still interested in the harness, please send paypal invoice to rmerkushen@comcast.net
Roman
Old 03-02-2012, 01:02 PM
z168 z168 is offline
Mein Auto: 01 540i/6
will this work on a 2000 X5? Nav no DSP
Old 03-03-2012, 03:06 PM
Technic's Avatar
Mein Auto: 2017 M3
There was no Logic7 system in 2000 in any BMW.
Old 03-09-2012, 04:52 PM
Dex335 Dex335 is offline
Mein Auto: 2007 335i JB4 METH
PM SENT! Awesome Idea and design!
Old 03-10-2012, 01:14 AM
Calibur Calibur is offline
Mein Auto: 2007 335i e92
I'm interested in one of these, how do i order?
Old 03-10-2012, 09:11 AM
with the 335i logic 7 and this harness i can add everything in the trunk makes perfect sense but will the stock amp push bigger underseat subs while the monoblock pushes the trunk subs only? A little off harness topic sorry I just want to use the harness to add an amp and subs in the trunk but let the stock amp push bigger underseat subs if possible.
Old 03-11-2012, 06:45 AM
Payment sent!
Old 03-11-2012, 06:47 AM
Thanks for answering the under seat sub question as well. I assumed the stock amp couldn't power new ones like you said just wasnt sure. I just get a three channel and do the whole setup.
Old 03-13-2012, 08:15 AM
Technic's Avatar
Mein Auto: 2017 M3
A JL Audio XD500/3 3-ch amp would be perfect for the OEM woofers and a trunk sub.
Old 03-13-2012, 08:26 AM
Awesome, do you think thT would go well with the JL custom 3 series box http://www.jlaudio.com/product/54216...580.0/3-Series
two low-profile TW5 13.5-inch drivers
Thanks should have my harness tomorrow and I have a temp set up set of subs until I can afford the JL's
Old 03-13-2012, 02:10 PM
gifsis gifsis is offline
Mein Auto: 2007 750li
Will I be able to use this harness with an aftermarket 5 ch amp and bypass the Logic7 completely? My underseat subwoofer is not working and both rear door speakers sound fuzzy.
And can anybody confirm if this works on a 2002-2008 e65 7 series with logic7?
thanks
Old 03-15-2012, 03:03 AM
Technic's Avatar
Mein Auto: 2017 M3
That Stealthbox needs around 600W RMS as stated in that link, the XD500/3 is 300W RMS.
Old 03-15-2012, 03:05 AM
Technic's Avatar
Mein Auto: 2017 M3
thanks
If your OEM amp is defective then there's not much that you can do... the harness requires a functioning OEM amp to work. This harness is just that, a harness and not a replacement or a bypass of the OEM amp.
Old 03-19-2012, 11:30 AM
makoy2 makoy2 is offline
Mein Auto: 2011 335is
Hello Technic
I am planning to add a powered subwoofer for now, then later upgrade the stock amp with a JL Audio HD Amp to power the car. Car has HK system. Can I use your harness now for the powered sub to make it easier for the next upgrade ? Thanks
Marc
Old 03-19-2012, 07:34 PM
Technic's Avatar
Mein Auto: 2017 M3
Originally Posted by makoy2 View Post
Hello Technic
Marc
Yes, you could do that.
Old 03-22-2012, 10:40 AM
BostonCEO BostonCEO is offline
Mein Auto: 745li
Hey where can I get this harness for the 745?
Old 03-22-2012, 10:41 AM
Mein Auto: 745li
BMW 745 logic 7 harness
Old 03-23-2012, 01:55 PM
Technic's Avatar
Mein Auto: 2017 M3
PM answered...
Old 03-28-2012, 04:55 PM
laced1985 laced1985 is offline
Mein Auto: 535d
BMW 535d
Hello Technic,
Im from the Uk and just brought my first BMW (535d 2005) today.
The audio system I have seems ok but not enough for me. I want to amp the underseat subs but not sure I have an oem or L7 amp or none. So my question is where would the amp be located in my car?
All I know about my car because I only picked it up a few hours ago. It has the CCC IDrive computer installed.
Thanks in advanced.
Lance
Old 04-01-2012, 07:15 AM
kanine kanine is offline
Mein Auto: 535d E61
Hi,
In the UK here, got an E61 535d with 676 Hifi sound - I can confirm there is an amplifier in the back, and tweeters.
1. Please let me know how much a harness sent to the UK will be - am I right in thinking this harness is perfect for the 676 Hifi setup?
2. I'm thinking about gradually upgrading, starting with an AMP first - will the OEM speakers and tweeters be ok with a 60W amp (it's a kenwood KAC-7404 - not great I know but it's hanging about) or will the amp be too powerful?
3. The amp has two sets of inputs and outputs - A L+R, and B L+R. If I wanted to drive the subwoofers, how could I do this? (Presumably the outputs would only do the Fronts and rears?)
Cheers!
Old 04-01-2012, 05:43 PM
Cmonteve Cmonteve is offline
Mein Auto: 2008 335i E90
Technic, how much for the harness shipped to 85742? I have an 08 335i sedan with the logic7 setup...
Old 04-02-2012, 09:40 AM
Technic,
I'm going to be using a Clarion mono 850 watt amp to push 2 alpine type R (SWR-1023D), which I had hooked up to a custom system in my 370z; will this be too much for just an add-in amp and sub, for a Logic7 system? I had also used a 2.4 farad cap for the setup in my Z; should I run my capacitor with this, as well?
Thanks for any info you can provide!
Old 04-02-2012, 03:44 PM
Technic's Avatar
Mein Auto: 2017 M3
The Logic7 harness/LOC can use any known mono amp as it only provide the low-level RCA-connectors inputs.
