Old 03-03-2012, 11:27 AM
seoul panda seoul panda is offline
Mein Auto: BMW 530i
Need opinions HG v. "new" engine
My car won't start, oil looks milkshake like, but car doesn't overheat when I drive it. A mechanic that I took it to thinks that the previous owner overheated it and blew the HG, he estimated me the cost and labor for a "new" engine. I'm trying to find the least expensive route and still keep my car. Should I fix the HG and whatnot or just replace the engine? Any help would be much appreciated cos the estimated cost to replace the engine is 2000 for engine plus tax then labor I'm looking at almost 4 grand. I've got someone looking at it now over the weekend while the mechanics shop is closed and he's been a mechanic for over 15 years. He's going to run some tests on it and his labor cost is a lot less than the ASE certified mechanics. The car is an 01' 530i with 89k on it. Thanks have a nice day
Old 03-03-2012, 12:43 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Oil and coolant mixed usually points to one (or more) of the following:
Bad head gasket
Cracked head
Cracked block
All of the above were usually preceeded by at least one episode of overheating, with the more severe damage caused by someone who continued to drive with the car in an overheat situation.
A compression/leakdown test will help diagnose the actual problem. Good luck !
The road goes ever onward....
(R.I.P. Jever)
Old 03-03-2012, 01:21 PM
PAULIN540I PAULIN540I is offline
540i stept bld date 6-02
Mein Auto: 2012SRX--2002 540i Steptr
If you put 4 grand into the car--you will still have a car that is worth exactly the same amount
as it was the day before the HG blew. Not worth putting 4k into a 7-8 k car. Plus-I assume the
new engine is "new to you" as in used. Could last a 100,000 miles or could last 1000 miles.
If you put 4 into it --then you are committed to putting X more when something else goes out.
Used cars force some hard decisions.
2002 540I SPORT/STEPTRONIC
TITANIUM SILVER/BLACK 6-2002
Old 03-03-2012, 01:53 PM
Mein Auto: BMW 530i
I agree. Which is why I am using that as a last resort. And yea the "new" engine is a used engine, it has 94k on it where mine has 89 and it comes with a 6 month warranty. I have an extended 5 year warranty: ***65532;***65532;ENGINE and WATER PUMP - All internally lubricated parts of engine, including pistons, piston rings, piston pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft and camshaft bearings, timing chain and timing gears, intake and exhaust valves, valve springs, oil pump, push rods, rocker arms, hydraulic lifters, rocker arm shafts and water pump. The Engine Block and Cylinder Heads are not covered unless damaged by an above listed internally lubricated covered part.
But that doesn't help me in this case or I would just have the warranty cover it.
Old 03-04-2012, 12:33 AM
This list of links was developed to help you ...
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47)
