Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 02-23-2012, 06:54 AM
mortyx10 mortyx10 is offline
Mein Auto: 745i
DIY - E65 Video In Motion using NCS Dummy and NCS Expert
Hello everyone
here is my original thread, thought post it here as well. http://www.bmwcoding.com/showthread....ideo-In-Motion
First things first....
Big thanks goes to macchiato66. This was his original idea and he is the one who helped me to get it right, So full credit goes to him.
Also thanks to Revtor for his great app and informative posts.
Warnings: 1. This is intended for passanger use only
2. I am not responsible if you break anything in your car
okay lets get to business....
1. Download NCS Dummy if you don't have it from http://forums.bimmerforums.com/forum....php?t=1553779
2. Backup the following files from daten/E65 folder:
Code:
E65CVT.000
MMI_E65.C02 (or whatever your MMIGT module is, it could be MMI_E65.C03, etc.)
SWTFSW02.dat
3. Disassemble SWTFSW02.dat
Add the following and reassemble.
Code:
SWT_EINTRAG : 1500 "TV_ABSCHALTUNG"
4. Disassemble E65CVT.000
under GRUPPE : {"Codierung_MMI"} add the following and reassemble.
Code:
FSW_PSW : 1500 0007 // TV_ABSCHALTUNG aktiv
It will look like:
Code:
AUFTRAGSAUSDRUCK : S0001,S0002,S0003,S0166 // E65,E66,E67,E68
FSW_PSW : 0831 0007 // KEY_MEMORY_MMI aktiv
FSW_PSW : 0832 0007 // WELLENBAND_MW aktiv
FSW_PSW : 0833 0007 // LETZTES_MENUE aktiv
FSW_PSW : 0834 0007 // ANIMATION_SCHIEBEN_4 aktiv
FSW_PSW : 0835 0074 // FARBSET_4 farbset_b
FSW_PSW : 13C5 0007 // HILFE_ALLG aktiv
FSW_PSW : 0837 0007 // ANIMATION_SCHIEBEN_1 aktiv
FSW_PSW : 0838 0007 // ANIMATION_SCHIEBEN_2 aktiv
FSW_PSW : 0839 0007 // ANIMATION_SCHIEBEN_3 aktiv
FSW_PSW : 083A 0074 // FARBSET_1 farbset_b
FSW_PSW : 083B 0074 // FARBSET_2 farbset_b
FSW_PSW : 083C 0074 // FARBSET_3 farbset_b
FSW_PSW : 083D 0076 // ASSISTENZFENSTER_1 kurzinfo
FSW_PSW : 083E 0076 // ASSISTENZFENSTER_2 kurzinfo
FSW_PSW : 083F 0076 // ASSISTENZFENSTER_3 kurzinfo
FSW_PSW : 0843 0076 // ASSISTENZFENSTER_4 kurzinfo
FSW_PSW : 0844 000B // TEL_US_BUSINESS nicht_aktiv
FSW_PSW : 11C5 000B // FARBEINST_ECE_SINGLE nicht_aktiv
FSW_PSW : 13C7 0007 // MENUENAME aktiv
FSW_PSW : 13C6 0007 // KLIMAPFEILE aktiv
FSW_PSW : 13C9 0007 // SERVICE aktiv
FSW_PSW : 13C4 0007 // CHECK aktiv
FSW_PSW : 13C8 0007 // PREV_TELN aktiv
5. Disassemble MMI_E65.C02 and add the following coding block and reassemble:
Code:
CODIERDATENBLOCK : {00003021} 00000000 0010 "Erprobungsumfaenge"
UNBELEGT1 : {00003021} 00000000 0001 {} (FC)
UNBELEGT2 : (02)
PARZUWEISUNG_FSW : {00003021} 00000000 0001 1500 {} (02) {h} {} // TV_ABSCHALTUNG
PARZUWEISUNG_PSW1 : 000B (00) // nicht_aktiv
PARZUWEISUNG_PSW1 : 0007 (01) // aktiv
UNBELEGT1 : {00003021} 00000000 0001 {} (01)
UNBELEGT2 : (00)
UNBELEGT1 : {00003021} 00000001 000F {} (FF)
UNBELEGT2 : (00)
6. Replace your original files with the reassembled ones.
7. Using NCS Expert read your MMIGT.
8. Find the function TV_ABSCHALTUNG
it is set to aktive by default. (Which means video in motion is disabled)
9. Change it to nicht_aktiv and code.
10. Done
To make everything easier I have attached my modified files (you can find them in other thread, I couldn't attach here), but they only work for you if you are using the same NCS version files as mine.
Check your original files see if the creation date is 31/08/2009 then we are using the same files.
Good Luck
Morty
Old 02-23-2012, 06:41 PM
Mein Auto: 745i
I can see here everyone has already bought the hardware VIM and have it installed. lol
Old 02-24-2012, 01:53 AM
Blackbox760 Blackbox760 is offline
Mein Auto: 2003 E66 760Li
Thank you for this, and maybe I can answer your question here about working with bytes and bits instead of using NCS, if we understand the bytes and bits we can do reverse engineering like adding the code you described.. Of course we will ultimately use the tools to do the changes but first we must understand how to change before we use the tools like NCS for dummy and NCS. But I find it very interesting that the guy could figure out how to add code and activate it.
Old 02-24-2012, 01:58 AM
Mein Auto: 745i
I can understand that but to add cd changer for example (as someone asked) you don't even need to modify nettodat just simply activate it in MMI. but I'm with you.
Old 02-24-2012, 06:36 AM
Ggreg Ggreg is offline
Mein Auto: 2002 E66
This is great work..... The link to NCS dummy does not work,
Old 02-24-2012, 06:40 AM
Mein Auto: 745i
The link is fixed.
Old 02-24-2012, 07:16 AM
dgoodsell's Avatar
dgoodsell dgoodsell is offline
Mein Auto: 2005 745LI
Great info.... I hope to try it out this weekend....does this make the front screen similar to the back screen for those with rear entertainment? does it use the DVD player in the trunk to play the movies?
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Rear Entertainment Pack
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 02-24-2012, 07:18 AM
Mein Auto: 745i
This is only to make the video play while in motion.
can you watch dvds (or TV) in front when stationary?
Old 02-24-2012, 07:22 AM
dgoodsell's Avatar
I can not...is there a way to code the front scree to operate like the rear entertainment screen?
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 02-24-2012, 07:30 AM
Mein Auto: 745i
Take a look here http://www.bimmerfest.com/forums/sho...395&highlight=
it might work for your car as well.
Old 02-24-2012, 07:36 AM
dgoodsell's Avatar
Thanks Bro!!....
You know if your technique works with this method mentioned in that post?
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 02-24-2012, 07:41 AM
Mein Auto: 745i
Thanks Bro!!....
they are two different things, you first need to enable video in your front screen, then you'll see that it stops showing the image as soon as you drive, only the sound plays.
by doing what I've explained in this thread then you can watch videos on the move as well.
Old 02-24-2012, 07:42 AM
Mein Auto: 745i
just make sure you know what you are doing, having any problems let me know by pm, Thanks
Old 02-24-2012, 07:44 AM
dgoodsell's Avatar
Got it....thats what I was trying to ask just didn't word it right I guess. I will try it this weekend it seems pretty easy.....thanks for the help bro....appreciate it.
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 02-24-2012, 07:46 AM
Mein Auto: 745i
Happy that it helped
Good luck
Old 02-24-2012, 09:18 AM
Dead Dead is offline
Mein Auto: 2014 730LI
waw excellent find man , but why didn't you disable it the first time
FSW_PSW : 1500 0007 // TV_ABSCHALTUNG nicht_aktiv
so it well be 1 step and you don't need to reprogram with ncs
this needs to be Sticky
Old 02-24-2012, 02:29 PM
Mein Auto: 745i
I'd like to mention macchiato66 once again, all credit goes to him.
as for your question I can answer.
what we are doing here is unhidding a hidden function already existed in our module. we can never introduce a new functionality to a module.
so by disassembling, modifying and reassembling these files, we are just giving this hidden function a human readable translation. This is actually all NCS expert does. (you can read more about this in NCS dummy threas by Revtor)
It is there and it is active by default, so by doing the above procedure you are just telling your NCS to show this function in your trace file as well.
one more thing you can never code your car just by modifying your daten files, you don't even need to be connected to your car to do so.
Hope this helps.
Old 02-25-2012, 02:20 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Hello everyone
Code:
E65CVT.000
SWTFSW02.dat
Code:
Code:
It will look like:
Code:
Code:
UNBELEGT2 : (02)
UNBELEGT2 : (00)
UNBELEGT2 : (00)
10. Done
Good Luck
Morty
Very Nice write up , & Great news for those that want this ...
Old 02-26-2012, 05:16 PM
Mein Auto: 745i
Thank you Paper
Has anyone actually done it?
Old 02-26-2012, 11:30 PM
Patriot123 Patriot123 is offline
Mein Auto: 740i E38 99
Hi all! Please, say me what is the programm for disassemble NCS *.dat files?
Old 02-26-2012, 11:33 PM
Mein Auto: 745i
All done by NCS Dummy, you can download from the link provided.
Old 03-02-2012, 09:28 AM
richpu richpu is offline
Mein Auto: e65 745
Hi All,
I can confirm that this works. I did this tonight. it took me around 5 mins to make the changes.
Fantastic.
Big thanks to macchiato66, Revtor and Mortyx10
Cheers
RichPu
Old 03-02-2012, 01:10 PM
PAPER's Avatar
CRISP & CLEAN
Thank you Paper
I'm not sure if any 1 has . I already have it in
my car so it was not necessary .
great work done by you & the others !!!
Old 03-05-2012, 02:10 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
Hope this helps.
The example on the page for NCSDummy shows adding to the list of parameters for "SPEEDLOCK_X_KMH_MIN_C0E" and "SPEEDLOCK_X_KMH_MAX_C0E" functions. I assume the reason we can not add a parameter to the existing function in the MMI (0AA7 "TV_VIDEO_ABSCHALTUNG") is because this would not change the "hidden function"?
PARZUWEISUNG_FSW : {00003002} 00000004 0001 0AA7 {} (08) {h} {} // TV_VIDEO_ABSCHALTUNG
PARZUWEISUNG_PSW1 : 0007 (00) // aktiv
PARZUWEISUNG_PSW1 : 000B (01) // nicht_aktiv
I also assume we can call it what ever we want, be it "TV_ABSCHALTUNG" or "Bob", as long as we are consistent.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 03-05-2012, 05:27 PM
Mein Auto: 745i
correct...you can only add parameters (which is simply possible by nettodat coding, no disassembly required) if the function is already defined. in this case we define it first in our SWTFSW02.dat and your right we can name it whatever, the keyword 1500 is more important. it must be unique.
