Old 03-03-2012, 06:26 PM
SEXSPHERE SEXSPHERE is offline
Mein Auto: 03 E65
Noise during cold start and low coolant, leak?
I took a picture from underneath, it seems that something is leaking. There is no trace of leak on the ground though. Picture taken from the passenger door area. Is it a leak? If so what is the source?
I had a power steering pump leak before, could it be just the leftover fluid?
Old 03-04-2012, 10:49 PM
Mein Auto: 03 E65
can someone help identify the leak?
Old 03-04-2012, 10:54 PM
Tarek307's Avatar
Tarek307 Tarek307 is offline
Send a message via MSN to Tarek307
Mein Auto: Porsche 911/ BMW 04 745Li
What does the fluid look like? also are you sure the leak is exactly from there? not being redirected by plastics, etc? could be coolant, power steering, even Washer Fluid Pump (which is what mine ended up being- clear but a bit oily almost like coolant)
E66//ACS Front Lip//License plate Delete//H&R SPRINGS//STATUS KNIGHT 5 STAGGERED 22" WHEELS//UMNITZA ANGEL EYES//15mm REAR SPACERS//
Old 03-05-2012, 07:54 AM
B7M4W5's Avatar
B7M4W5 B7M4W5 is offline
Mein Auto: BMW 745LI
Yes the color of flued would help, is it dark brown or dark red or green/ blue coolint.
E66 745LI 2004 Sport / Sterling Grey Ext. Blck Int./
22" Wheels / ACS Pedals / ACS Rug Plates/
Black Out Tail Lights / Carbon Fiber Blck.-Gry. Emblams/
Grill Chrome-Blck. /
12" Subwoofers 2000 watt Amp
Old 03-05-2012, 06:14 PM
Mein Auto: 03 E65
Cant tell the colour because it does not drop to the ground. I topped up the fluid this morning, only needed a little bit. The low coolant message wont disappear though, checked on the fluid again tonight, still the same amount as the last i topped up. What could have triggered the warning?
Old 03-05-2012, 07:23 PM
B7M4W5's Avatar
If u can wipe the bottom with a paper tow so that way u can c the color n does it smell like antifreeze.
Old 03-05-2012, 07:43 PM
DeaconG DeaconG is offline
Mein Auto: 2006 750Li
Go get some wrapping paper from your local office supply store and spread it under the car's engine. Get a couple of bricks, tiles or some other type of heavy objects to keep the paper in place.
That would at least give you some idea of where the leak was coming from if it does drip.
Old 03-05-2012, 08:14 PM
pkathee's Avatar
pkathee pkathee is offline
Mein Auto: 760 Li
Sexphere,
When you mentioned noise, did you mean squeaky noise or grinding noise? The squeaky noise could potentially be the drive belts soaked in coolant. And that explains noise during cold start up. Alternatively, grinding noise could be a failing water pump. Anyway, this is what you need to do. Just like what Tarek said, the leaky coolant fluid may have been re-directed by the plastic engine protective cover located underneath the car.
To help us help you, take that protective cover off (green screws and two push/pull pins adjacent to the front end car lift point rubber support). Grab a couple of brake cleaners (from local parts store) and clean entire area that appears to have coolant residue. Also, inspect your belts to see if there is any traces of coolant on there. Cuz, if you have a failing water pump, there would be evidence of coolant around the belt area.
Depending on how gradual/ fast your leak is, you should be able to pinpoint exact leak origination point. Just clean that area off real good first.
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels.
2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
