Mobile Electronics and Lighting
Car Stereos, Cell Phones, DDEs, HIDs, foglights etc... |
#176
when and where can i order
#177
PM replied...
#178
Technic, I am still interested in the harness, please send paypal invoice to rmerkushen@comcast.net
Thanks Roman |
#179
will this work on a 2000 X5? Nav no DSP
There was no Logic7 system in 2000 in any BMW.
#181
PM SENT! Awesome Idea and design!
#182
I'm interested in one of these, how do i order?
#183
with the 335i logic 7 and this harness i can add everything in the trunk makes perfect sense but will the stock amp push bigger underseat subs while the monoblock pushes the trunk subs only? A little off harness topic sorry I just want to use the harness to add an amp and subs in the trunk but let the stock amp push bigger underseat subs if possible.
#184
Payment sent!
#185
Thanks for answering the under seat sub question as well. I assumed the stock amp couldn't power new ones like you said just wasnt sure. I just get a three channel and do the whole setup.
#186
A JL Audio XD500/3 3-ch amp would be perfect for the OEM woofers and a trunk sub.
#187
Awesome, do you think thT would go well with the JL custom 3 series box http://www.jlaudio.com/product/54216...580.0/3-Series
two low-profile TW5 13.5-inch drivers Thanks should have my harness tomorrow and I have a temp set up set of subs until I can afford the JL's |
#188
Will I be able to use this harness with an aftermarket 5 ch amp and bypass the Logic7 completely? My underseat subwoofer is not working and both rear door speakers sound fuzzy.
And can anybody confirm if this works on a 2002-2008 e65 7 series with logic7? thanks
#189
If your OEM amp is defective then there's not much that you can do... the harness requires a functioning OEM amp to work. This harness is just that, a harness and not a replacement or a bypass of the OEM amp.
#191
Hello Technic
I am planning to add a powered subwoofer for now, then later upgrade the stock amp with a JL Audio HD Amp to power the car. Car has HK system. Can I use your harness now for the powered sub to make it easier for the next upgrade ? Thanks Marc |
#192
Hey where can I get this harness for the 745?
#194
BMW 745 logic 7 harness
#195
PM answered...
#196
BMW 535d
Hello Technic,
Im from the Uk and just brought my first BMW (535d 2005) today. The audio system I have seems ok but not enough for me. I want to amp the underseat subs but not sure I have an oem or L7 amp or none. So my question is where would the amp be located in my car? All I know about my car because I only picked it up a few hours ago. It has the CCC IDrive computer installed. Thanks in advanced. Lance |
#197
Hi,
In the UK here, got an E61 535d with 676 Hifi sound - I can confirm there is an amplifier in the back, and tweeters. 1. Please let me know how much a harness sent to the UK will be - am I right in thinking this harness is perfect for the 676 Hifi setup? 2. I'm thinking about gradually upgrading, starting with an AMP first - will the OEM speakers and tweeters be ok with a 60W amp (it's a kenwood KAC-7404 - not great I know but it's hanging about) or will the amp be too powerful? 3. The amp has two sets of inputs and outputs - A L+R, and B L+R. If I wanted to drive the subwoofers, how could I do this? (Presumably the outputs would only do the Fronts and rears?) Cheers! |
#198
Technic, how much for the harness shipped to 85742? I have an 08 335i sedan with the logic7 setup...
#199
Technic,
I'm going to be using a Clarion mono 850 watt amp to push 2 alpine type R (SWR-1023D), which I had hooked up to a custom system in my 370z; will this be too much for just an add-in amp and sub, for a Logic7 system? I had also used a 2.4 farad cap for the setup in my Z; should I run my capacitor with this, as well? Thanks for any info you can provide! |
#200
The Logic7 harness/LOC can use any known mono amp as it only provide the low-level RCA-connectors inputs.
