Old 03-12-2012, 06:35 PM
TopNotchWatch TopNotchWatch is offline
Follower of Christ!
Mein Auto: 2013 X5 5.0
20 inch wheels... vs... 19 inch wheels???
Could someone enlighten me on wheel size please? Ordering a new 5.0 and can't decide on 19 or 20 inch wheels? What are the advantages or disadvantages to both? I hear the 20's come with staggered size tires... if that is true... why do they do that? Any help would be great. Thanks~
Old 03-12-2012, 07:54 PM
PhilT3 PhilT3 is offline
6' / 250lbs
Mein Auto: '12 X5 + '14 M5 SOON!
Go big or go home!
The muscular look and the increased handling that the 20's give is worth ANY downside that comes with them.
But I also am not looking to do any regular or serious off road with my X.
The 19's would provide a taller sidewall so should provide a softer ride. Again, i'd rather have the handling and looks of the 20's.
You got to determine what you want the truck to provide for you and make the choice with that goal in mind.
Old 03-12-2012, 09:26 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
I have had 19's and 20's on my X5's. Personally I like the look and performance of the 20" over the 19". The 19's still make the car feel solid but the 20 adds a bit more feel. I had 18" winters and sold them weeks after I had them because I felt the X5 was too soft moving from the 20's the 18's. If you get the 20's you will need to purchase a Winter setup. You will not want to drive the X5 in the snow with 20" summer performance tires. It is absolutely scarey. I got caught in 1 inch of snow in a freek snow storm early winter one year and the first time i was on a slight decline, i was sliding with no control even at 15 mph. Personally I don't feel it is an inconvenience having to swap out my wheels twice a year. I run winter/summer setups on both my BMW's. You get the best of both worlds, excellent summer performance, excellent winter performance and you summers say nice. The cost is negligible because you split the wear over two sets and the winters wear very very well. Good luck
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 03-12-2012, 10:56 PM
Cdnrockies Cdnrockies is offline
Mein Auto: X5 35d; 750Li; IS F
Agreed.
I run a non-staggered 19" winter set up that is very comfortable and reliable. I run 20" staggered for the summer with 275's up front and 305's out back. Conti DWS's. Very happy all year round.
'11 750 Li Xdrive Alpine White
'10 X5 35d Space Grey
Old 03-12-2012, 11:03 PM
1HOT BMR's Avatar
1HOT BMR 1HOT BMR is offline
Mein Auto: 2015 X5d/ 2012 X5d
The 20s look cooler, they also make the car look bigger, more agressive and it also feels heavier and bigger when you drive it. The 20s will give you a rougher ride and will be useless in bad weather. They also cost more to replace and your wheels are more likely to bend when you hit a pothole.
The 19s will give you a better cushier ride, will make the car look and feel lighter when you drive it - more tossable. They have better traction in bad weather conditions, they cost less to replace and your wheels will be safer when you hit that pothole.
IMO go with the 20s if looks are everything to you, otherwise, the 19s are the much better choice BTW, the 20s will not improve your handling, on the contrary - all that additional unsprung weight will make your handling worse.
Old 03-13-2012, 04:53 AM
6' / 250lbs
In my experience, the additional weight of the 20's over the 19's won't be enough to notice at the levels the x can be reasonably pushed on the street. Technically, I would agree, but in real world conditions, the smaller sidewall will give the driver more feedback and be perceived as better "handling". This of course is completely separate from acceleration characteristics and braking performance that will be affected by the additional rotating mass on the four corners of the car / attached to the drivetrain.
But I am no mechanic or rac car driver, I just play one on TV.
Old 03-13-2012, 05:21 AM
smyles smyles is online now
Mein Auto: X5
20" is primarily for the looks. They are heavier, more expensive to replace, and the staggered setup is good on perfect roads only; on bad surfaces, with ruts, your car will jerk left/right more than on 19"s. Whether it's worth the looks is a personal choice.
Old 03-13-2012, 11:35 AM
Kzang Kzang is offline
Mein Auto: 2015 X5 ///Msport 35i
I don't have an X5 but I do have a staggered set up on my 535i. As everyone has already mentioned the staggered set up makes it a phenominal handling and makes the car look more aggressive image wise.. However if you don't plan on swapping out on winter tires ( I will assume your in Buffalo NY ) then you will have some issues during winter weather driving.
Another problem with 20's and most likely the 19's as well is that the tire and rim will be more susceptible to damage ( ie. potholes, cracked rims, tire damage ).. On mine, the first winter I drove my car I had to replace 3 warped/cracked rims and 1 damaged fairly new tire.
2015 X5 Msport Space Grey
Old 03-13-2012, 08:30 PM
Follower of Christ!
Can you stagger 19 inch wheels for summer driving?
Old 03-13-2012, 08:40 PM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
I'm looking for the same thing. Figure 19 s will be cheaper and ride smoother. Not sure if they offered them frm the factory though.
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 03-13-2012, 09:20 PM
1HOT BMR's Avatar
I don't see why you couldn't. My 550i has them - OEM with summer tires. I would stay close to factory offsets to preserve the geometry of the suspension and not upset the handling.
Old 03-14-2012, 03:36 AM
ND40oz ND40oz is offline
Mein Auto: 09 135i
Jay
The 50i with the M Sport package comes with 223Ms which are 19x9 in the front with 255/50/19 tires and 19x10 in the rear with 285/45/19 tires. You should be able them from the dealer if you want them.
Either way, the 20s have a high enough sidewall it really doesn't make too much of a difference, 315/35/20 has a 110 mm sidewall. Compared to a 5er with 19s running 275/35/19 on the rear, they only have a 96 mm sidewall.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Old 03-14-2012, 08:29 AM
Thanks for the heads up on the 223Ms I'll have to google those to see what they look like.
I would be okay with a 255/285 stagger as it wouldn't be as much of a friction drag either. The 19s would theorectically have ~17% more sidewall then the 20s which is a decent amount.
I love big fat wheels/tires as much as the next guy, but for my commuter the 19s should be sufficient.
Jay
Old 03-14-2012, 08:30 AM
Should have google imaged them before replying... not in love with them
Jay
Old 03-14-2012, 08:48 AM
Mein Auto: 09 135i
The 19" 177, 213 and 265 were all also offered in the same staggered setup, I think the 223M is the best looking of the 4, depends on what you like. I don't think I've ever seen the 265 in person though.
13 Honda Insight EX
Old 03-14-2012, 10:31 AM
LOVE the 177s!
Thanks for the follow-up. I can't find a picture of the 265s on google images... weird, lots of 3 series pics come up but nothing with an X5/6.
Old 03-14-2012, 11:08 AM
Mein Auto: 09 135i
The 265s were/are only available with the Individual Package I believe, pics can be found here: http://www.bmw.com/com/en/newvehicle...ndividual.html
13 Honda Insight EX
Old 03-15-2012, 03:00 PM
2rlake 2rlake is offline
Mein Auto: 2008 X5
i have 20" y-spoke summer tires and love the look ... the 18" winter tires do not look as sexy
