E36 (1991 - 1999)
Old 08-08-2010, 05:47 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 1996 Z3 1.9L M44
Front Crankshaft Oil Seal DIY
Anyone have a good link. I'm searched the net and haven't come across one.
thanks.
1996 Z3 (M44)
Old 08-08-2010, 06:29 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
pretty simple job, a bit cramped for non-regular diy'ers. depending on the tools you have available.
secure the vehicle on stands (or lift, if available)
remove the belts
remove the crank bolt (an impact gun works well here...)
remove the balancer, crank gear, and hub.
remove old oil seal.
since the housing is aluminum, i do not suggest banging the new seal in without lots of caution as to not damage anything. you may wish to size up the new seal with a socket*, or, use a piece of pvc pipe and washer(s) and use the crank bolt to seat the new seal.
*a regular seal driver will not work due to the snout of the crankshaft sticking out beyond the lip of the timing cover.
other than that it's pretty simple. i do suggest proper torque specs, though. the crank bolt is listed at 303ft lbs, and is suggested to be replaced with a new one. (might be torque to yield design, not sure)
df
Old 08-08-2010, 09:37 PM
IgotBMW's Avatar
BE IRIE
Thanks, drivinfaster!
May have to leave this to the Pro's.
1996 Z3 (M44)
Old 08-20-2010, 06:37 PM
IgotBMW's Avatar
BE IRIE
drivinfaster, I may take a crack at DIY on this.
Do you know if I will need a Crankshaft puller to pull the Crankshaft Pulley off?
1996 Z3 (M44)
Old 08-21-2010, 01:46 PM
no, it is bolted to the snout hub. undo the bolts that hold it to the hub, and then undo the crank bolt. the hub should slide off the crank snout with the crank bolt removed.
did you get a new crank bolt?? they're not supposed to be reused per bmw.
df
Old 08-21-2010, 03:29 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
df, to verify your speculation, the crank bolt is indeed a "torque to yield" fastener. That's why it can't be reused (as you guessed).
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 08-21-2010, 04:41 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
You need a nice impact gun too.
Make sure to torque to spec afterward, it's somewhere around 300+ ft pounds. If you just use an impact gun, it WILL come loose.
Turbo Build Here
Parting Out Complete 96 328is
Old 08-21-2010, 07:14 PM
IgotBMW's Avatar
BE IRIE
Didn't know about the bolt.
I'm glad this forum exist. You guys are so helpful.
What do I do if I only have an electric impact wrench with only 220 lbs/ft max?
1996 Z3 (M44)
Old 08-21-2010, 07:48 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Be strong.
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.”
- Hunter S. Thompson,
Old 08-21-2010, 08:15 PM
Needs Boost
Mein Auto: Red Sled
VERY strong!
You'll need a very long breaker bar at minimum.
Turbo Build Here
Old 08-21-2010, 11:01 PM
AdmKlondikebar AdmKlondikebar is offline
Mein Auto: '97 328i sedan
-Ryan
Member #1 of the Boston Green Mafia
"We'll break your kneecaps"
Old 02-19-2012, 06:38 PM
ethereal45's Avatar
ethereal45 ethereal45 is offline
Send a message via AIM to ethereal45
Mein Auto: 1998 328i
Bumping this because I think I'm going to have to do it soon -- this can really be done without ripping the timing case apart? I think this is where my oil leak is coming from.
I assume you have to remove the radiator to get enough clearance in there, right? How do you get the old seal out? How do you stop the crank from turning when you are trying to get the bolt off? Do you need one of the tools to hold it in place (or could you do it with the locking pin?).
I need to pinpoint my oil leak, but I think it could be my front crank seal. I saw some pictures somewhere else that looked exactly like I was experiencing and he solved it through replacing the front crank seal.
Edit - my leak looks exactly like this. This guy talked about replacing the hub behind the crank pulley....why would that be necessary? http://www.bimmerfest.com/forums/sho...d.php?t=188324
1998 328i
Koni Sport Suspension
Old 02-20-2012, 01:03 PM
the oil seal has a spring that holds tension to the hub. over time, and this is lots of time mind you, this pressure will cause a seal to wear into the hub creating a little groove.
this groove could allow oil to seep past even with a new seal.
there are 'fixes' for this on more common vehicle makes, like small block chevy and ford motors, that consists of a thin metal sleeve that gets pushed over the snout to create a freash surface for the seal to seal against.
there are (apparently) similar 'fix-its' for the rear main sel as well, but i do not know if there are any made for the bmw motors. (i did not bother to check, but i'm sure a quick google will reveal any possible repair kits out there)
most repairs for the oil seal do not require the replacement of the hub. only if it is grooved.
a regular seal puller should be sufficent to remove the old seal.
df
Old 02-20-2012, 01:11 PM
ethereal45's Avatar
So can you get this bolt off with an impact? Or do I need to get the crank locking tool and go to down with an epic breaker bar/pipe combo?
Why do you need a seal puller, can't you just pop it out with a thin flathead? (Sorry, I have no experience with rotational seals like this....)
1998 328i
Old 02-20-2012, 03:00 PM
yes, an impact will be helpful.
yes, a crank locking pin will be useful to torque the new crank bolt down properly. (they're torque to yeild, so they need to be replaced)
yes, a screwdriver will work, but the seal puller has a curved shape which adds leverage and pivot point that you do not get with a screwdriver.
df
Old 02-20-2012, 08:18 PM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
ethereal if you do this please take DETAILED pics. i may have to do the same job...
i <3 you!
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 03-15-2012, 08:55 AM
MrToSlo MrToSlo is offline
Mein Auto: 1996 BMW 328i
i may have to do this and want to confirm the parts that need to be replaced. i'm going off the parts listed here - http://www.realoem.com/bmw/showparts...35&hg=11&fg=18
also, do any other parts need to be replaced besides what is listed above?
Old 03-15-2012, 09:39 AM
IgotBMW's Avatar
BE IRIE
Look under Engine Housing.
On my M44 it's shown like this:
http://www.realoem.com/bmw/showparts...85&hg=11&fg=10
For my car, it's part
03 Shaft seal 44X60X10 1 11141439570 $24.92
1996 Z3 (M44)
Old 03-15-2012, 09:54 AM
thanks! updated my post.
Old 03-15-2012, 04:54 PM
ok, this is twice...where are you guys getting the idea that the hub needs to be replaced?? i am not aware that this is a wear part, and subject to needing replacement on occasion. it is also not like a bearing that could be damaged upon removal, so i don't think that would be it.
please essplainz, as i are confuzzeded...
there is no explanation as to why the hub was replaced in the thread...i checked...
df
Old 03-15-2012, 07:40 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Just for reference, an average air wrench is not going to get that bolt off. Mine is rated at 300-something ft-lbs and it didn't stand a chance. You'd need a professional one.
What I did was I set up a breaker bar against the ground, and used the starter to crank the engine. It nearly lifted the car off the ground the first couple times, but it worked. Getting it back on is the tricky part, though. Might wanna just tighten it up as much as possible then bring it to a mechanic to torque it down.
-CJ
Old 03-15-2012, 08:04 PM
crisscross's Avatar
crisscross crisscross is online now
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Or just lock the flywheel and use a ratchet with a 4' pipe?
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-15-2012, 08:09 PM
D'oh, You kids!
God bless my 3/4" drive socket set and 5' aluminum pipe cheater bar.
Quotes to live by:
BMW-CCA #441426
Old 03-15-2012, 08:20 PM
cj.surr's Avatar
some kid
I'm talking about if the engine and transmission are still in the car. The clutch slips if you don't hit it quick.
-CJ
Old 03-15-2012, 08:43 PM
crisscross's Avatar
Right, when you do the vanos, you have to lock the flywheel with a pin (dowel) with the engine in the car. Clutch has nothing to do with it....
There is a hole in the bellhousing where you can insert the dowel when the engine is at TDC, and it will be impossible to rotate the crank.
-Alan
