Old 03-11-2012, 11:08 AM
X3mech X3mech is offline
Mein Auto: 2007 x3 3.0 si
Talking 2007 BMW X3 Suspension Upgrade
I am currently planning to upgrade the following on my 2007 bmw X3:
-Front Struts (Bilstein)
-Rear Shocks(Bilstein)
-Front Springs(Eibach Prokit)
-Rear Springs (Eibach Prokit)
I am trying to find instructions on removal of the rear coil springs. I Plan to post pics of the complete DIY for the benefit of other forum members next week.
Old 03-11-2012, 12:56 PM
Espen Lysholm Espen Lysholm is offline
Mein Auto: 04 BMW X3 2,5IA
Perfect. I will follow your thread
Kind regards
Espen Lysholm
Old 03-11-2012, 03:41 PM
whiterasta whiterasta is offline
Mein Auto: 2004 x3 2.5 premium/sport
I've subscribed to it and following it. Are you going to lower at all?
Old 03-11-2012, 06:54 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
How much are these parts please? Recently had my X3 aligned and they said they could not do it dead on as my left front strut was slightly bent. Off course replacement and repair from dealership was just over $1k.
I'm betting that the whole thing as your propose can be done for that amount or less.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 03-11-2012, 07:09 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
Forum member chagrin posted this:
http://www.bimmerfest.com/forums/sho...0&postcount=58
Old 03-11-2012, 10:31 PM
Still waiting for the remaining parts to deliver on Monday for part numbers please refer attachments. I will post pics of the parts on Monday night. Work is keeping me busy so this will be a DIY in installments. Please note some of the parts ordered are not required to be replaced. I have 53k miles on my vehicle and dont plan to touch the suspension for another 50K after this job. My symptom is a leaking front left strut and leaking right rear shocks. The vendors that i purchased from are eshocks.com, ddmtuning.com, bavauto.com, rmeuropean.com. Thanks to Supercourse I was trying to find out how to get the rear apart to reach the shock mounts.
ID:	316148   Click image for larger version
ID:	316149   Click image for larger version
ID:	316150   Click image for larger version
Old 03-12-2012, 10:47 PM
The parts arrived. Assembled the front strut pending the tightnening of the strut nut. The strut shaft uses a 8mm allen which i need to accquire.
ID:	316354   Click image for larger version
ID:	316355   Click image for larger version
ID:	316356   Click image for larger version
ID:	316357   Click image for larger version
ID:	316359   Click image for larger version
ID:	316360   Click image for larger version
ID:	316361   Click image for larger version
ID:	316362   Click image for larger version
ID:	316364   Click image for larger version
ID:	316365   Click image for larger version
ID:	316366   Click image for larger version
ID:	316367   Click image for larger version
ID:	316369   Click image for larger version
ID:	316370   Click image for larger version
ID:	316371   Click image for larger version
ID:	316372   Click image for larger version
Old 03-13-2012, 04:17 AM
ioannis214 ioannis214 is offline
Mein Auto: X3, 2.0i, Manual, 10/06
How come you decided to opt for this setup? Your car which suspsension setting did it have, sport or normal? Did you find the ride hard? Let us know how the new suspension setup feels afterwards!
Old 03-13-2012, 07:19 AM
mlukas161's Avatar
mlukas161 mlukas161 is online now
Mein Auto: 03 330i, 04 X3
Looks good! This is the same setup that I put on our 2004 X3 last summer.
Still a firm ride, but much more controlled! And a lot more cost effective than replacing with original BMW replacement shocks / struts.
The biggest pain for me was removing the interior trim panels in the rear cargo area.
Old 03-13-2012, 07:41 AM
Did this lower the truck at all on the 2004? I have a broken pig coil and I'm thinking about doing the same thing.
Old 03-13-2012, 07:49 AM
I have standard suspension. The ride was spongy and i take turns fast. The X3 was hopping on Michelin tires and activating 4X4 at my turn speeds. So i needed a firm suspension to reduce body roll, lower the vehicle as well as reduce braking distance.
Old 03-13-2012, 07:51 AM
It is supposed to lower by 1" front and rear.
Old 03-13-2012, 08:42 AM
EricS4 EricS4 is offline
Mein Auto: 2008 BMW X3
Great thread. Please keep the updates coming. I plan on doing the same upgrade to my recently aquired 2008 X3.
Old 03-13-2012, 11:46 PM
Assembled both set of shocks. Remember the black side is up for the washer on the upper front spring mount otherwise the strut mount will not spin freely. The final torque check of the front strut to 55lbs will occur after install.
ID:	316526   Click image for larger version
ID:	316527   Click image for larger version
ID:	316528   Click image for larger version
ID:	316529   Click image for larger version
ID:	316531   Click image for larger version
ID:	316532   Click image for larger version
ID:	316533   Click image for larger version
ID:	316534   Click image for larger version
ID:	316536   Click image for larger version
ID:	316537   Click image for larger version
ID:	316538   Click image for larger version
ID:	316539   Click image for larger version
Old 03-14-2012, 08:46 AM
gzep23's Avatar
gzep23 gzep23 is offline
Mein Auto: 2004 X3-current 2002 S500
what was your total cost for everything shipped?
Old 03-14-2012, 08:00 PM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
Awesome thread. Please post up pics of the install and any issues you have. I'm interested in hearing any issues/tricks with getting the rear springs out/in, in particular.
Old 03-14-2012, 11:52 PM
Please reference reciepts with part numbers and costs attached in my previous post above
Old 03-14-2012, 11:54 PM
Further progress has occured. I managed to install one front strut on the x3. Pictures to follow. Had to grind 1 18mm spanner to hold the sway bar link nut from spinning. The harbor freight grinder rocks
Old 03-15-2012, 08:09 PM
Evlengr's Avatar
Gotta love harbor freight. To cut down on confusion my little girl cuts out things she likes and makes a collage for Xmas and Birthday.
I started doing this with Harbor Freight and my favorite Electronics Stores for my wife. Works wonders.
Got my uber radar detector and polishing tools. So Xmech for those of us that are getting lazy in our old years what do you charge for this
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 03-15-2012, 09:44 PM
Well I am not a mechanic by profession but have worked on cars for a long time. I dont know what the labor rates are in the US since I have never taken any of my cars to a mechanic.. . The dealer however wanted 1200$ just for the front axle.. which felt was daylight robbery. I feel 50$ per side will be a fair price.
Old 03-15-2012, 09:56 PM
Ok so front axle is complete. Attached are the pics.
ID:	316798   Click image for larger version
ID:	316799   Click image for larger version
ID:	316800   Click image for larger version
ID:	316801   Click image for larger version
ID:	316803   Click image for larger version
ID:	316804   Click image for larger version
ID:	316805   Click image for larger version
ID:	316806   Click image for larger version
ID:	316808   Click image for larger version
ID:	316809   Click image for larger version
ID:	316810   Click image for larger version
ID:	316811   Click image for larger version
ID:	316813   Click image for larger version
ID:	316814   Click image for larger version
ID:	316815   Click image for larger version
ID:	316818   Click image for larger version
ID:	316820   Click image for larger version
ID:	316821   Click image for larger version
ID:	316822   Click image for larger version
ID:	316823   Click image for larger version
ID:	316825   Click image for larger version
ID:	316826   Click image for larger version
Old 03-15-2012, 10:32 PM
Steps Followed to Replace front Struts:
-Break Lug Nuts with car on ground
-Use front jack point and jack up the car
-Place Suv jack stands under the side jack points
-Remove front wheels
-Take a picture of the current install
-Release the brake hose mount clip.
-Gently remove the brake hose from the strut mount hook
-Gently remove the other cables from the strut mount
-Remove the sway bar link nut by using a socket and a ground 18mm wrench
-Support the suspension as shown in the picture with the floor jack.
-Remove the lower strut mount bolt and nut
-Remove upper strut mount nuts.
-Dont even think about removing the main strut shaft nut. That will be the most illogical act ever.
-Now spray penetrating oil at the junction of the base of the strut. Let it sit overnight if you have the bandwith.
-Try to move the strut by wiggling it from side to side. If it wigggles well and good spray a litle more penetrating oil. Remember to place rags under the base of the strut to prevent spraying oil all over your suspension.
-Take a neoprene hammer and hammer at the strut sprint base plate. The strut will start moving towards the top. Gently lower the suspension to the max. Keep an eye on the drive shaft boot since you dont want to tear it when the axle will slightly pop out. Support with jack as shown in picture.
-Keeping hammering by pushing down on the brake rotor front until strut is ready to pop out. At this point stop hammering.
-Slowly remove strut. A this point the axle will pop out in the drive shaft boot. Dont panic!!!
-Take the bilstein assembled strut and install in the strut mount cavity and use the old strut mount nuts to loosely bolt the strut to the car.
-Match the two pins at the bottom of the strut with the slot in the strut mount. The rotor will be at an angle as shown in the pics.
-firmly push the rotor towrads the car in a lifting motion such thet the axle moves back in. At this point wiggle the strut such that it is in the base of the strut.
-Now place the jack as shown in the pics and apply force simulating a hydrauclic press. As the suspension rises the strut gradually moves in the base. Check periodically that the strut angle is accurate.
-Apply penetrating oil at strut base to ensure smooth and easy movement.
-As the strut starts moving into the base, raise the suspension higher until the drive is close to paralle to the ground and you will hear an sudden snaping noise which is the srut moving completely inthe the strut base. At this point the strut is now firmly seated in the base.
-Install new upper strut mount nuts and torque to 25lbs. If you torque any higher you will shear the mount bolts.
-Use throttle body cleaner to get rid of the penetrating oil at the bottom of the strut.
-Install the lower strut bolt and torque to 85lbs.
- lower the floor jack and install the sway bar link. I used the same torque as befroe aprox 65lbs. Mine were a little worn out so the next DIY will be replacing the sway bar links.
-Install all the hoses in the mount as before.
-Repeat for the other side.
-Install Tires and tighten lug nuts as much as possible when on jack stands
-Lower car and tighten lug nuts to 95lbs.
-check the torque on the main strut shaft nut and install dust caps after ensuring that the grease in there is sufficient.
-Time for a test drive.
Old 03-15-2012, 10:40 PM
So I still have to do the rear. But decided to test drive the front. What a difference!
-Smoother acceleration
-Fantastic braking response
-Gobbles up the turns
-Not harsh at all. Very smooth.
Glad i chose this setup. Cant wait to install the rear.
Old 03-16-2012, 04:20 AM
Mein Auto: 2007 X3
I noticed you have the same tires I do, and I also have the 17" wheel and standard suspension. Have you noticed any difference with the squishiness of the Primacy's? I'm looking to put the HD's on mine, but not sure about the lowering springs.
Old 03-16-2012, 07:59 AM
I run my tires at 37 psi. The only way to get rid of the squishiness completely is to go for low profile tires but that will mean greater rim dia and headaches where the rim get easily damaged and harsher ride.
