#151
Another 6"-8" last night! A mere dustin'. However, we are getting bumper crop this year. |
#152
I have not read all postings here, so I am not certain if everyone had similar experience, but I always get these mysterious misfires in the spring or more specifically when the temperature differential between the moment when I shut off the car and I start it is significant. I know to turn the engine off and on and that always fixes the problem. Sometimes I have to repeat the off/on procedure a couple of times. A good friend of mine who works on BMW told me once that this is a problem many BMW cars have. I don't remember his explanation, but I do remember he told me that turning the car off and on should fix it. I don't want to discourage anyone from changing their vanos seals. I bought mine some time ago and need to find time to put them in. I am just thinking that the underling cause for this erratic behavior of our cars might be a software problem that has to do with the ambient temperature and the mixture preparation. My car has been acting up every spring now for 4 years. It never does it more than 3-4 times per "season". I am certain it has to do with temperature and humidity. I am not certain if it is a software problem. This is a hypothesis, although many cars have software problems, being the computers that they are nowadays.
#153
Now, the key question (for any hypothesis) is HOW to test it??? Note: I suspect the reason it doesn't always work the first time for you is that you purportedly need to wait 30 seconds of shutdown before restart. |
#154
To create negative differential delta I guess we need to do nothing. Because morning is usually colder than evening. Personally I can not confirm that "every time I create temperature differential - I have rough idle". But I am 100% sure that I experience rough idle for only last 2 years in my 10 years old car, 70K miles driven. And usually rough idle apears when car was not used for a week. I believe these two condtions should be in "top5- how to create rough idle by youself" |
#155
Just an idea: if small and stupid ODBII scanner-eraser bug is connected to the car, and programmed to erase some particular missfire codes by the time they appear - rough idle problem could be tricked.
what do you think? |
#156
That's only a bandaid solution to this problem. But it will work until it gets worse and worse
mujjuman |
#157
Or, until the next mandatory smog inspection.
#158
Interestingly, the sudden and severe cold-engine misfire with resulting fuel shutoff still has not occurred again since that fateful first day when this thread was started.
I've had 'other' misfires, and vacuum problems, but not that sudden and obvious shuddering where the car would barely move down the driveway. I think there could be a whole bunch of potential culprits: - Vanos - Engine computer problems with certain temperature changes - Engine computer problems with starting the car at one temperature just to move it and then letting it sit overnight to a different starting temperature - etc. And, a new idea, for a cold-start single-cylinder misfire with resulting fuel shutoff popped up in the E46 forums today (M54 engine) ... - E46 (1999 - 2006) > Misfire on cold start? Check in here... Quote:
#159
Wow, nice find, Bluebee. It was interesting to read about how the lifters fail, and it wouldn't have occurred to me that they could induce a misfire. With the recent advent of all the electronic technology, more and more systems are interrelated in mysterious ways.
#160
If we have lifter damaged, it should cause rough idle every start, or every cold day. In my personal case I had at least 10 rough idles in 2008-2009 winter, but in 2010-2011 winter only one rough idle was reported by my wife. Does this mean my lifter gets better? ![]() The only difference I see is the weather (humidity), and I changed motor oil from unknown to thin 0w40 Arctic. |
#161
This is a perfect temperature to build a condensate early in the morning. Humidity will do the job. This winter I opened oil changing cap on the engine in the morning and was surprized with WATER condensate (ice) under the cap. I also see some water (melted ice) coming out of exhaust side when I start my car in the morning. The rough idle cold start problem could be related to condensed water somewhere in the car: inside the engine -vanos, outside - coils, or even ice chocked exhaust. |
#163
Regarding cold-start problems ...
Pay attention to the little vacuum hose in the middle of the CCV, based on these warnings from PhilH on another forum today (thanks Doru for pointing this out): - Cold start issues, Indie VS. You Read post #15 where PhilH says: Quote:
#164
Here is the pic of different version of CCV (w. small vacuum nipple plugged)
#165
I know this has been a while and this is my first post, but being from the UK I normally use a different forum.
Since I bought the car I have had a problem whereby when starting the engine from cold there is a definite miss, although it never used to trigger any warning lights. Then it started triggering the exhaust emissions light and scanning the car using INPA revealed that it is: 242 cylinder 5 burning failed Therefore it only affects one cylinder and also, once the engine has been running for around 30 seconds and the revs lower the miss stops. I believe this is all similar to previous examples shown on this thread. However, I wish to diagnose this so that my car is working properly. I have added to the following quote in colour. Quote:
Mike NOTE I am aware that I own a 320Ci, however, it has a 2.2l M54 engine. Last edited by hontoir; 08-21-2011 at 03:30 PM. Reason: Adding note |
#166
Here in Russia, some people like to do "Wynns" chemical or "ultrasound" mechanical injector cleaning at yearly basis.. As for "wynns" injector cleaning, this is simple. Mechanic has to plug a hose with wynns cleanout fluid somewhere in fuel supply line, start the enginge and keep it running idle for a while. $50 procedure, but you have to change dirty spark plugs after it.
It is believed injector could be clogged and shape of the jet could be affected, (instead of spray, you get drops) which could lead in misfire, loss of power and starting problems. You can try wynns. or you can get injector out of the engine and visually check if it creates spray in cyl 5. But, if it was me, I would start with check of compression in cyl 5. |
#167
Well started the car this morning, although it didn't register a misfire or cause any misfire symptoms the INPA showed that cylinder 5 was running very 'rough'. The readings climbed progressively to quite a reasonable peak, and the dropped as the car dropped its idle speed.
I also tested the injectors using the screwdriver method, all were ticking away happily. So this doesnt rule out the injectors leaking, however, it is still working. We knew that anyway as the car performs perfectly once warm. |
#168
This brand new DIY today from Doru:
- E39 (1997 - 2003) > Injectors replacement and/or servicing DIY ... mentions a particular cold-weather injector o-ring problem known to BMW ... Quote:
#169
Vibration on a cold M54 engine with a misfire on one or two cylinders and a fuel shutoff is due to Hydraulic valve lifters wear / weak valve springs
On a cold start where there is not enough oil and valve can NOT be fully closed ( due to oil build-up in engine as result of bad oil /15k miles oil change ) DME shutoff this cylinder to prevent gas to drop on catalizators When the engine is warmed up Hydraulic valve lifters start to work normally so no fuel shutoff and no misfire The problem is, - this is a huge job and not a common procedure here in US This is a common issue and replacement on euro forums if your car has more than 100k miles and all the rest of repairs like plugs/ejectors/CVV/Vanos/Air leaks etc do not help Last edited by champaign777; 10-01-2011 at 01:33 PM. |
#170
/rant
mujjuman |
#171
My small update is that:
My car has only done 55k, and compression test hot and cold show everything to be in order. This should rule out the lifters as the reason for causing misfire is that they do not CLOSE the valve, which would have been seen in the compression test. I swapped two of the fuel injectors around and the problem did not migrate. Not the fuel injector then. Car has gone into the indy today to have the ECU updated and to have the electronic signals for the coils/injectors scoped. |
#172
Help-at point of no return. Cut hose to dipstick :-) I'm actually flying along and doing great! However, there appears to be a non-OEM electrical connection that doesn't have the spring clip? I can't figure out how to get it off. I got all the other ones off no problem (other than someone going crazy with zip ties in crazy places to reach). I'm ready to remove throttle bottle. but electrical box is in the way. I could probably do it with it like it is but it will be a royal pain. as an FYI, I haven't found any of that mayo yet. dipstick looks clean. Did notice that there was no dipstick gasket in place. Dipstick came out no problem and no mess at all.
The problem with the connector is that it looks like either the smaller end could come out of the bigger plastic piece, or the whole things comes out. The plastic clips are very rigid and can't tell if the push in, or you have to open them outwards. Either way is very very hard as the plastic is very hard. Once I get this connect off, I'll be flying along again. Notice the yellow circle with the normal metal clip. All the others have that and came right off. Do I remove piece in the red circle from teh piece in the blue circle? or remove the blue circle (which takes the red one with it)? and how hard/far to I squeeze or open that connector? I've tried but no luck either way. But also not sure which piece(s) come out. Another note. While I cleaned the MAF a month ago, I did not inspect it well enough. there are major cracks in the both boots. Guess it's always good to replace if old, or you do not know the vehicle history. CCV hoses look better than boots. CCV so far looks good from outside. Will check for mayo as I get more things out--once I get this flipping connector off. :-) |
#173
You can take it out on the red connector. There are two squeeze tabs on it. It's probably brittle from the heat so it hardened up.
#174
Thanks George16.
I'm dissapointed in the ECS tuning non-vented hose, in the the winterized kit (really). I knew it was non-oem, but they told me it was a winter kit. Guess winter mostly :-) that aside, it was not as flexible as the OEM hose. It was almost as bad the the 90 degree turn hose! serious. Also noticed that the valve in the throttle body used to go about 2 or 3mm further than it does now. it's not vacuum I think as i had to push hard to get it close the rest of the way. Pics later. But open to ideas on what it is, if ok, and what it does not closing 100% of the way. Also there was a post about needing a T27, I didn't. Just the T25 and I did take my DISA off for ease and more working room. I can't say that I found any mayo in the CCV oro hoses. I'm going to clean the dipstick next but it too looks really good. I suspect my CCV was ok, but since I didn't know the history, it was a worthwhile venture. I'm not quite done, but taking my time, i'd say 4 hours for a first time. I probably spent an hour of that on the stupid electrical connection by the vanos. I also tried to take off teh air distribution to clean it but it wasn't budging and I didn't want to force it. I may get a new one anyone since I'll be doing more work next weekend when I replace the two boots that are cracked. oh, since my last ICV cleaning a month ago, it still looks clean, but not shaking that inside roller like it should. I'll do more reaserch on that later. Most of the hoses I found in there looked ok. The short stub/stop at th eback of the engine is there. The CCV had an internal block/stop as well (new design I guess as others have reported). There is a small 1/8" ish looking hose that while not cracked that I can tell, it's very very fragile looking. pics later on that too. I can't remember the name of the metal vacuum disc on the ABS side of teh engine, above the front O2 sensor where others report just touching that vacuum hose and it breaks. Mine was fine and soft. Well, off to close everything up, do VCG, oil change, then order some more parts (boots/air distribution). fun stuff. Last edited by mjbennett9; 03-18-2012 at 08:23 AM. |
#175
Crap. Looked under car an found and extra o-ring. I'm hoping it's from the old hoses and breaking them off. I never did check the o-rings on the new hoses before putting them on. I only paid attention to the snapping of the going on. The hoses aren't looking, so I think it's from the old hoses. The little o-ring has a crack in it too. I doubt the new one if it fell off, would be cracked already. The bigger o-ring is for comparison. it's the old dipstick oring (which I did find inside where the dipstick goes. It was stuck in there pretty good). At first when I took the dipstick out, I didn't think there was an o-ring.
