RFT tires vs. Performance non-RFT - Bimmerfest - BMW Forums
Old 03-17-2012, 11:41 AM
tcandmm tcandmm is offline
Mein Auto: 2012 550i
I read that many of you have replaced the RFT tires with conventional summer performance tires, I intend to use the stock RFT Dunlop tires until they're worn, but since they're stagger configuration and cannot be rotated, the rear will likely be worn out quicker. Do most of you replace all four at once or is it safe to replace rear 2 RFT first then replace front 2 at a later time?
Thanks.
BMW CCA member. 2012 550i M Sports, Carbon Black/Cinnamon Brown leather/Aluminum Hexagon trim/ZLS. Dinan springs, Xpel paint protect film, Llumar tint. Retired: 2009 535i, 2006 530i, 2003 X5, 1998 318i
Old 03-17-2012, 01:51 PM
solstice solstice is offline
Mein Auto: 2015 F80 M3
Thanks.
Yes, replacing only the rears or fronts is fine as long as you put on the exact same tire model.
