Old 03-18-2012, 07:47 PM
Julio_Lujambio@ Julio_Lujambio@ is offline
Mein Auto: BMW 535xi
How to replace Thermostat e-60 (535 xi)
Just finished replacing the thermostat in my 535 and I am sharing learnings.
Expected time to perform for home mechanic: 2 hours. Pro: 1 hour max.
Thermostat is located in the non-driver side below the engine.
Procedure:
1- rise your car so you can reach all the lower splash panels/cover in the bottom of the car
2- secure the car so it does not move
3- take out front and back splash (around 20+) screws
4- remove lower protector plate ( 6 big bolts). You will need air powered tools or heavy and good wrenches.
5- remove bolt and move hydraulic hose to the left so you can make room.
6- remove hoses from the thermostat
6.1 - start removing the ones that have the secure wire to keep them in place. Take out the wire lock (you can pry it with a small screwdriver) and then pull the connector out of the each one. (you can drain your system at this time :-) ) thus, have a handy container to collect the cooling fluid.
6.2 - remove the 2 bolts that keep the thermostat in place
6.3 - pull the thermostat to the side so you can see and reach the other 2 hoses
6.4 - gently unscrew the clamp that holds the small hose - fluid will drain when you remove the hose- and then pull to the side to remove the hose.
6.5 - gently unscrew the clamp that hold the big hose - fluid again - and with one hand reach the hose from the back of the frame and pull with your other hand the thermostat.
Installation procedure is the opposite.
good luck!.
change, procedure, replace, thermostat
