Old 03-19-2012, 03:48 PM
Manybrews Manybrews is offline
Mein Auto: Car
overheated M54. Pictures of a complete removal, teardown, and inspection.
so im not sure if ANYONE here is interested in this, but I figured Id post it anyway.
I purchased a badly overheated E39 about 5 months back. I knew the cylinder head was toast, but rolled the dice on the rest of the engine (its pretty hard to properly diagnose without a full teardown).
I time-serted the block threads at the time as I knew the engine had been cooked not once, but twice. The owner knew it was overheating, pulled over, waited 15 minutes, then started it again and drove it until it stopped.
the head was warped enough that every fluid inside the engine (including fuel) was coming out between the block and head.
so i got the car cheap and yanked it apart. The head was warped, but repairable. There was no obvious damage to the cylinder walls, so I just said "the heck with it" and assembled it.
however, more damage was present. The engine had pretty awful piston slap from the moment it was started. The noise was very obvious when cold, would diminish, then come back with a vengeance as the engine hit operating temp.
I drove it for 4 months anyway, as it ran fine. It was just rattling pretty badly.
Finally i decided to find out exactly what else was ruined, as my first guess was piston damage.
the following are photos of my repair up until now, as Im waiting for some parts to be delivered and a little free time.
it turns out the noise is NOT from the pistons.. but rather the block itself. The deck is flat, but a few cylinder bores are royally tweaked. Number 4 in particular is out of round by .010! The piston flops around inside it like a fish.
Cylinder one and two are perfect, and the others are a little messed up but usable.
the options are to bore it, replace it, get a new engine, used engine, etc..
I dont trust used assemblies, and I dont want to invest the time/money in oversizing this block... so I searched and found a nice used bare block. They are MANY available, especially if you consider that the 2.5 block is the same as the 3.0 block.
so ill replace the block, use my rotating assembly, replace maybe one or two pistons along with misc other parts, and have a nice, quiet M54.
I shall update with other info and photos if it turns out that anyone actually cares.
ID:	317477   Click image for larger version
ID:	317478   Click image for larger version
ID:	317479   Click image for larger version
ID:	317480   Click image for larger version
ID:	317482   Click image for larger version
ID:	317483   Click image for larger version
ID:	317484   Click image for larger version
ID:	317485   Click image for larger version
ID:	317487   Click image for larger version
Old 03-19-2012, 04:44 PM
Turbo_525 Turbo_525 is offline
Mein Auto: 2002 525i 5-spd
Interesting! Thanks for positing this.
Interesting too how the calipers don't lie, whereas our eyes may tell you all's well. Hope you can get it all back together and have a better deal this time around!
  • N/A 525i, 5-speed, 138+K
  • BMW's are not like other cars, they have issues and cost you real $$$ to sort.
  • Affording to Buy a BMW is not the same thing as affording to OWN a BMW.
  • Pre-Purchase Inspections by a qualifed BMW tech should be considered required PRIOR to purchase.
  • Service Records matter - a whole lot!
  • Plan to spend $2-3000+ in maintance & repairs the first year of ownership.
  • Plan on something unexpected to happen, more often than you are used to.
Old 03-19-2012, 05:10 PM
PAULIN540I PAULIN540I is offline
540i stept bld date 6-02
Mein Auto: 2012SRX--2002 540i Steptr
When you say you got it cheap---I do hope you mean FREE !
2002 540I SPORT/STEPTRONIC
TITANIUM SILVER/BLACK 6-2002
Old 03-19-2012, 05:21 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 120k
Wow, amazing pictures.
It's rare to see photos of such extensive work.
Entire front end seems to be taken apart.
Are you a professional mechanic?
Do you feel this car was worth getting into?
Or do you wish you just got a normal condition E39 for $6000 or so...
Old 03-19-2012, 05:57 PM
Mein Auto: Car
Its the easiest way to take it apart. Not the ONLY way, just the easiest assuming you have the facilities. Obviously, doing this in your garage is unlikely. You'll need a minimum of a car hoist and a large set of tools.
And yes, Im a bimmer tech.
my total invested will be approximately 3000$ (if you don't include time).
it blue-books at about 7000-7500$ (its a lower mileage 03), so yeah, Its worth it. It would have been MORE worth it had the block not been warped from the heat, because my total investment then would have been only about 2000 bucks. But whatever! Cant win 'em all.
Old 03-19-2012, 07:45 PM
gary@germanautosolutions's Avatar
gary@germanautosolutions gary@germanautosolutions is offline
Mein Auto: 528-530 Hybrid, Duc. 748
I have a set of good used M54 3.0L pistons that you can have cheap if you're interested. I'm in the process of doing a performance build on the same motor.
Gary
"I'm a little rascal on my Little Rascal"
- unknown
Old 03-19-2012, 08:13 PM
Schitzo Schitzo is offline
Mein Auto: 2000 528i
I see you are in MN. Is that motorwerks? Do you work there?
Awesome to have a lift for such a task. GL
l Stock 2000 528i l
Old 03-19-2012, 08:22 PM
I had decided to reference only the last 50 threads in the bestlinks for people to get an idea how others resolved a badly overheated E39 engine ... so ... with that in mind, I think it's fitting to make this the fiftieth and final thread referenced in the bestlinks pointer on this topic:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Old 03-19-2012, 09:41 PM
DinanBimmer's Avatar
DinanBimmer DinanBimmer is offline
Mein Auto: 1998 540i 6-speed
Just looking at those pictures fascinates me, I hope to be able to tackle more and more complex jobs myself on my E39. I'm interested in seeing more for sure.
Dinan Free Flow Exhaust, M5 illuminated shifter and boot, black kidney grills, tinting on back windows, CCFL Angel Eyes, CDV delete, 15mm spaced (M5 rear sway bar soon)
Old 03-20-2012, 06:15 AM
BentValve's Avatar
BentValve BentValve is online now
Mein Auto: 00 528i 3 pedals
I miss having the facility to do tear downs. Glad you got this issue sorted out.
Old 03-20-2012, 09:03 AM
Jason5driver's Avatar
Nifty thread!
Thanks for the expertise and pictures!
Thanks!
Jason
Old 03-20-2012, 11:17 AM
pleiades pleiades is offline
Mein Auto: '99 528i/5-spd M52TU
Oooh ... nice pics, Manybrews, please update as you go. Very educational.
Wondering to myself if it's possible to slap a 3.0 head/pistons on my M52TU (2.8 L) block....
Old 03-20-2012, 07:17 PM
Mein Auto: Car
Dont quote me, but I'm pretty sure the m54 head is the same casting as the m52tu.
Pistons, I dunno.
The m54 blocks are the same between the 2.5 and 3.0, as are the heads.. But the crank, rod, and pistons aren't. Neither is the intake, throttle, or dme.
Externally nearly identical, though.
Old 03-25-2012, 05:53 AM
Mein Auto: Car
More pics.
not always the best, but you get the idea.
Here you will see me measuring a cylinder on the new block... and its perfect.
the same cylinder on the old block? You'll see its .010 out of round widthwise. And thats
not taking into consideration that it pulled the cylinder walls IN longitudinally .002, which makes a grand total of .012 out of round.. or 3 times the allowable.
ID:	318388   Click image for larger version
ID:	318389   Click image for larger version
ID:	318390   Click image for larger version
ID:	318391   Click image for larger version
ID:	318393   Click image for larger version
ID:	318394   Click image for larger version
ID:	318395   Click image for larger version
ID:	318396   Click image for larger version
ID:	318398   Click image for larger version
