Old 11-19-2011, 12:22 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Originally Posted by XtrlRulz View Post
Today my bimmer just went without luck. I was driving it without any problem and suddenly start for GAS SILVER ( 89 octane ) and i got around 50 mile left in the tank, so i filled it up 20 dollars in the car, suddenly when i tried to start the engine it was like run out of gas, so it didnt accelerate, so i was like what the heck... i just pull more gas and it was like i took gas out of the care, the meter didnt go up immediately, so i was like it was gas or water? ...
so i approached to the pump and look it over again, to make sure it was GAS... not diesel or anything else, then i went to another pump and fill it up 10 dollars more, so it should be 3/4 of tank already but meter didnt show anything at al... so i tried to turn on again the engine and no luck, it was like trying even with the gas pedal on the top and nothing...
So i assume that was the GAS pump or filter or whatever... my repair shop it was closed today at least they received my bimmer,, so on monday they will check it out...
What do u think guys? ...
A bad fuel pump, clogged fuel filter, or failing CPS are just a few things which could cause those symptoms....
The road goes ever onward....
(R.I.P. Jever)
Old 11-19-2011, 12:24 PM
XtrlRulz XtrlRulz is offline
Mein Auto: BMW 2002 325XI
CPS ? Explain that one, the other 2 i got it... and i think its a bad fuel pump or the filter...
Old 11-19-2011, 02:34 PM
Fast Bob's Avatar
Keeping it surreal
We have this little thing here called *the SEARCH function*....you should learn how to use it, you`ll be amazed at all the information stored there....
(Crank Position Sensor)
(R.I.P. Jever)
Old 11-19-2011, 02:36 PM
Thanks for the answer... I just didnt mind to use it... Just keep that comment to you.
Old 11-21-2011, 08:25 PM
Dear bimmers fan, i want to ask you ... my Fuel pump just failed on me, the bmw dealer is offering me the fuel pump for 263 dollars, so i guess plus tax... so i would want to ask, it is a good deal ? or expensive ? thanks.
Old 11-22-2011, 09:15 PM
And yes was the Pump Fuel, i replace it today cost me 261 with taxes... and 100 of hand work... all done... now the car runs better and feels better... even i think im saving more gas.. =)
Old 03-27-2012, 07:56 PM
Congrats on the new ride !
Rather than jumping right on that mod train, you might want to save your money for things which will keep your BMW on the road (i.e., cooling system rebuild, CVV, VANOS seals, LCABs, brakes, etc.).
Bob, right now im jumping to do over Cooling System, When you mentioned it i guess you refer to : Water Pump, Water Expansion Tank and The hoses, right ? I want to fix those because i noticed some leak.
Also, thinking on Flush the Radiator, what do you think for the Cooling system, will it get everything done ? Thanks!
Old 03-27-2012, 09:59 PM
Fast Bob's Avatar
Keeping it surreal
There are complete cooling system rebuild kits which are very reasonably-priced....check with www.oembimmerparts.com, I think they might have the best price.
This is probably the best thing you can do....think of it as "Life Insurance For Your Car".
(R.I.P. Jever)
Old 03-28-2012, 12:27 PM
Thank you very much BOB, because i've been noticing that my coolant is getting low, but if i park my car on my garage point down , looking outside you know (reverse ) there is a little decline so there is LESSer coolant loss than if i park it pointing toward the garage... so i guess there is a leak around the expansion tank, i will look into it on saturday, but i've been thinking on change everything bc of the recently post over the forum... mine is 182K miles, so i think is time... what do you think ?
Old 03-28-2012, 12:37 PM
Fast Bob's Avatar
Keeping it surreal
At *that* mileage, you should be going on your THIRD cooling system by now....
(R.I.P. Jever)
Old 03-28-2012, 01:58 PM
Hahaha, i just bought the car, remember ? Im just getting ready to start doing all the "Refresh" "CLeaning" stuff with the car
Old 03-28-2012, 04:28 PM
Gryphon's Avatar
Gryphon Gryphon is online now
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
The cooling system is a great load off your mind once it's done. The forums have made me extra paranoid about failure. Did the ZHP now I just need some warm weather for the Xi. I got my kit from Max at OEM Bimmer parts. There's an extra hose that doesn't come with most refresh kits that I would advise changing.
http://www.bimmerfest.com/forums/sho...941&highlight=
The brass bleeder screw is another cheap/nice option for a few bucks more. If you haven't already done so replace both belt pulleys and belts.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 03-28-2012, 04:44 PM
I dont get the Brass bleeder screw beside is iron material compare to the one that the car has already,, any fuction beside the looking ? ...
The Belt Pulleys and belts are the next thing to do... But i prefer to go with the Cooling system and the oil /filter change for now.
Not enough money to do it everything, btw, how much is suposse to ask me the mechanic for the Cooling system work? Any idea? Thanks
Old 03-28-2012, 05:22 PM
Fast Bob's Avatar
Keeping it surreal
The standard bleeder screw *is plastic*, and has a reputation for breaking off. Get the brass one. Also, it`s foolish to NOT do the belts and pulleys now, especially since you`re PAYING for the labor (why pay twice for the same job ???) Do it while everything is already apart.
Did you ever pull a wrench before? This is not that hard of a DIY job, even for a beginner....
(R.I.P. Jever)
Old 03-28-2012, 05:39 PM
So do you think i could get all the parts and also adding the Pulleys and belts and i can do it by myself ?
Old 03-28-2012, 06:49 PM
Fast Bob's Avatar
Keeping it surreal
The question is, "Do YOU think you can do it ?"
How`s your mechanical aptitude/ experience ?
(R.I.P. Jever)
Old 03-28-2012, 06:51 PM
Hehehe, that's a good question ... i will check some DIY and i will decide , But thanks
Im getting those part for the change by the end of april...
