Old 03-28-2012, 08:54 PM
sheldonzane64 sheldonzane64 is offline
Mein Auto: 2011 550i, 2006 325i
550 M-Sport Goodyear Excellence Tire Problems
I am well aware of the X cars M sport 19" LS2 problems. I have a 2011 550 M Sport with Goodyear Excellence Tires. After 18 months and 7000 miles I discovered side bubbles on both front tires. Anyone else experience the same thing?
Old 03-29-2012, 06:54 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
Bubbles can happen on low profile tires no matter the construction. I had them happen on my Conti DWS's, which are not run flat tires (same size as yours).
nature of the beast with that little rubber.
2011 535i
Sophisto Grau / Oyster - Black Nappa, Anthracite Wood Gone but not forgotten.
Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss.
Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians
Old 03-29-2012, 06:55 AM
Die Wolfe's Avatar
Die Wolfe Die Wolfe is offline
Mein Auto: '12 535i Msport/'13 X5M
You purchased a wheel and tire warranty, right? That should square that away...
2013 BMW X5///M
2012 BMW 535i M Sport
Old 03-29-2012, 09:08 AM
Goodyear will pro-rate and replace but I am thinking of switching to Michelin Non RFT. Any comments of running all four the same size as compared to staggered?
Old 03-29-2012, 10:29 AM
Needsdecaf's Avatar
Mein Auto: 2007 MDX
Debating this myself. The problem is a lack of traction with the 245 rear tires. I experience some slip in my 535...I would imagine that on your car the 245's would not be enough to contain 150 ft-lbs more.....
2011 535i
Old 03-29-2012, 10:51 AM
Needsdecaf;
You bring up a good point as even with the staggered setup there is slight slippage. Thanks.
Old 03-29-2012, 11:09 AM
Needsdecaf's Avatar
Mein Auto: 2007 MDX
Thank Dunderhi.
2011 535i
Old 03-29-2012, 07:59 PM
alewifebp's Avatar
alewifebp alewifebp is offline
Mein Auto: 2014 550i
There is indeed some slip. It's very easy to break away the rear, and therefore difficult to launch it properly. I switched to conventional Michelin Pilot Sport A/S Plus, same size as stock, staggered, on standard sport rims. I've even had problems with these tires with a pothole I hit. However, even that experience was much improved over the RFT. With the RFT hitting a pothole at a much lower speed, I experienced a loss in pressure and had to limp home. When I hit a pothole in the Michelins at around 60-70 MPH, the tire stayed together and I was able to ride on it for a while. It experienced a dreaded bubble, but the only difference in driving I experienced was a lot of vibration. I had purchased tire insurance as was able to get it replaced. Now I think the rim is bent, since I still get some vibration. I'm waiting until the pothole season clears up before I get it straightened.
ED on 7/18/2014: 2014 550i, Space Gray, Mocha. M Sport, Cold Weather, DAP, Executive, Lighting
PCD on 9/6/2011: 2011 550i, DSB, black/oyster. Prem 2, Conv, Ventilated, HUD, Sport, DHP, SAT
