I have been told that I need a head gasket, there are no visible signs other than exhaust gasses entering into the coolant system. Im debating weather to replace the gasket and skim the head or replace the engine. Neither are pretty options. The car drives great, no power loss and sounds great so I was wondering would it be worth using a sealer and seeing how long I can get out of it before forking out the big bucks.
has anyone ever used this stuff? |
Make sure it is not a CVV (Crankcase Ventilaton Valve) failure and putting undue pressure in the cranckcase causing the blow by...might be too late.
Perhaps you could change the CVV and associated hoses resolve your pressure issue in the crankcase and thereby resolve your leak...maybe a little stop leak at that point...once you fix the root cause. Head Gaskets don't blow on these things unless you overheat or run on a broken CVV for too many miles. my experience is that if you have a leak on these things: Valve cover gasket, Oil Filter Housing gasket, Oil Pan gasket etc. you need to ask yourself a question, " how long has it been since I've replaced the CVV"?, if it is over 60K, then replace the CVV first and then fix the leak....just what I am starting to notice now that I maintain three E-46's. I know there are ways of testing for CVV failure, and you should do that, but I think they start to fail intermittently, causing the pressure fluctuation / oil leaks before they test bad or cause oil to blow every which way during hard failure. Last edited by QAfred; 03-20-2012 at 06:26 PM. |
Have you done a compression test yet? How many cylinders are affected? Last edited by ckleung100; 03-20-2012 at 07:49 PM. |
Try the sealer. Some new car manufacturers now use it. It's rolling the dice but MUCH cheaper and easier than replacing the head gasket or engine. Good luck and let us know your results.
Don't be gormless; get some gorm! ![/I][/FONT] |
Before you do anything else, go and get a second opinion.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
havent done any compression test, but I was there when he did the chemical test on the coolant and it can be seen that exhaust casses are in the radidtor system. its a Diesel so it went green. and it can be seen bubbling. Im giving this steelseal a go, when your talking 700quid for a new gasket whats 30quid?? its worth a shot and il let yous know how it goes.
Don't use sealer. There is no such thing as mechanic in a can. It could plug up your radiator or your heater core, or both. Then you will have real problems. If the car has not been overheated, have the head gasket replaced, and do it the right way. Get a compression and leakdown test first though to verify that the head gasket is indeed faulty. Combustion gas in the coolant is a good indicator though. You might also want to check torque on the head bolts first. Diesels run a very high compression ratio.
Too late SJBimmer its been done, il know in the morning wheather you can buy a mechanic in a can or not haha, ive no quams about doing the job right, I just cant afford to do it right now. so in a couple of weeks il get it sorted. might flush the Rad tho, just incase, but apperantly it will only react with metal at high temp, they are going to tell you that anyway I suppose.
thanks for the posts and il let you know how it goes. |
Rite lads, im not jumping the gun but the Steel seal has certainaly stoped the warning light from coming on and seems to be doing the trick, il have to wait a few days to be sure, but worst comes to worst and il be doing the head gasket.
No, the worst case is now your block is full of that stop leak crap and will lead to an early death of your engine. "miracle fluids" usually do more harm than good. I have seen it first hand. Think about it, you just put METAL in your cooling system that forms a seal where your leak was. What is to stop it from blocking critical passages and other parts?
I know what your saying but if its a chemical reaction then it requires the correct condations, so it wont harden everywhere, only at the point of interest. It isnt metal, it just forms a ceramic material. I might drain the cooling system in a few days and see what comes out.
what do you suggest then? flush the cooling system and remove the head? I havent trusted the bottle, there are pleany of poeple that it worked for and ive spoken to a few mechanics that say it cant do much hurt.
Ive used the seaIer on another car i used the new hitech water onIy mixture it worked 5 months sofar if yu need to use the seaIer i wouId onIy use the water type seaIer but beware your waterpump wiII start to Ieak due to bearing faiIure from the seaIer. But rapIacing head gaskets arent hard as you think b ut a cracked head is worser
And I speak from more experience than most of you. My name is Rob43, & I normally post over at E46Fanatics.
About 3 years ago I bought a $12,000 race motor for my SCCA E36 BMW 325I race car. This motor made great legal WHP in the class I race in, but early on in the life of this new motor, it developed a crack somewhere in it & would quickly overheat. When I pressure tested the cooling system to about 15-20PSI, it would quickly bleed that pressure out. To say the least I was really pissed. The owner of the race shop that built my Bimmer suggested I try the Moroso "ceramic" engine sealer, he had success with it once before. So with several more important races coming up, I had a choice. Spend $15 for the ceramic sealer or have another $12,000 race motor built, guess which one I opted for ? That's right, the $15 ceramic sealer, after about a 30 minute install of this sealer guess what, all of the sudden my cooling system was holding 20PSI indefinitely. This race motor ran for more than a year with the ceramic sealer in it until I tore it down for a freshen up. The sealer worked perfectly under the harshest environment possible, there was no sign of any extra sealer anywhere in my race motor. Plain & simple, it was a complete, win win product for me. So yes, I believe it works. Good luck, Rob
Rob #43 ITS/ITR/STU, BMW 325I, STU LAP RECORD SUMMIT POINT WV 1:24:229 S.C.C.A. http://www.vimeo.com/8486878 (Dyno Video) ........add a sh!tload of cowbell. |
Welcome to Bimmerfest.
And a race motor and a street motor are quite different. I'd be willing to bet the race motor doesn't see the miles a street motor does. |
