F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
How to load iTunes music on hard drive
I have an 550xi that I just received last night and I would like to transfer my iTunes music collection to its hard drive. I know that I have to do this via the USB connection in the glove box. Does the import process require the music files to be in a specific directory on the memory stick? Does it adhere to the iTunes subdirectory structure - Artist\Album\Song?
Can I create a Playlist in iTunes, export it to the memory stick & import it? I didn't see anything in the manual about this. Thanks Last edited by jjscott; 03-30-2012 at 11:08 AM. |
Your best bet is to just drag-and-drop folders in the file structure that you want to see on your car, onto a USB stick.
So I have like 40 folders on an 8GB stick, all of which are the band's name. In each folder are more folders, with the Album name. In each of those Album folders are MP3 files. I spent probably three hours manually arranging this, but it's worth it to have the files listed correctly. |
Sync it to an iPod and then plug the iPod into the glovebox USB port, then import
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
Will it work? |
Last I knew that wouldn't work. Needed a flash/thumb drive. |
So long as the metadata attached to the MP3s in those files includes album art (load them into any MP3 playing software to check), then yes, it'll stick.
Just drag the iTunes folder to your hard drive. This can take a while if you have a lot of items. When the transfer is complete, your iTunes Library will have been successfully copied to your hard drive.
Suggest this thread which has much information on using music options in the F10
http://www.bimmerfest.com/forums/sho...939&highlight=
2011 535i - Imperial Blue Metallic / Venetian Beige Dakota Leather / Light Wood Trim - Premium 1&2 - Smartphone integration |
Ok, I've played with this a little bit this morning and have a few questions - big surprise.
As a test, I copied four songs from iTunes library to a memory stick. I placed the songs in directory named "Rock" on the memory stick. Ran the import process and they loaded fine. My Music Collection option has a folder named "USB 1" and under this folder is "Rock" with my music. Back on my laptop, I deleted the four songs under the "Rock" directory. I then added a complete album to the memory stick under the "Rock" directory. I ran the load process in the car again and I now have a "USB 1" & USB 2" folder under "Music Collection". Both have a "Rock" folder. "USB 1" has the four sounds I initially added & "USB 2" has the album that I added during the second import. How do I organize the music once it's loaded on the hard drive? How would I move the four songs from "USB 1" to "Rock" folder under "USB 2"? Will the system continue to add USB folders for each import that I execute? |
I think you can only delete. You need to make the full folder structure on the USB Stick and load it in and delete old ones.
IPhone was not recognized - could not load into Radio HD
Has this worked for anyone - plugged the iPhone into the usb in the front glove box - did not seem to get recognized or load the music.
Thanks,
Long Island 11554 Driving 2011 535xi Saphire Black on Black, Nav, P1, P2 premium, cold weather package, rear shades 2004 525i Silver - Retired |
It's not supported. Neither is an external hard drive or a iPod. See page 208 in the on-line manual.
This will only work if the iPod was originally set up using iTunes on Windows. Mac users are out of luck.
Is this correct? One would think that I should only have to add NEW songs to the USB stick provided they are added to the cooresponding folder (Rock, Jazz, R&B, etc) on the cars hard drive. |
+1. You can only import a new, total collection, and delete the old one. You can edit the name, for example, mine is "IPOD 1".
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm |
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm Last edited by markl53; 04-01-2012 at 10:43 AM. |
Thanks |
I'm being extremely picky here, but for a "gold star", how do you switch between upper & lower case when changing the name?
), but I don't see a way to get lower case. There is a position on the letter "dial" to switch to numbers and symbols, but not lower case that I have found.
Gold Star - Denied! |
