E36 (1991 - 1999)
Old 04-01-2012, 04:38 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Well this can't be good
Yep, another one of those threads. Need to lay out a plan.
1) Coolant Flush
2) Coolant Flush + Stop Leak
3) HG replacement (good time to get a thicker gasket...?)
4) Head rework
5) Head replacement
I'm hoping the problem is fixed before step 3, and definitely before 4/5.
What do you guys think?
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 04-01-2012, 04:48 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
I think its fairly obvious from the photo (unless your using some sort of thick yellow coolant I've never seen) that you have oil and coolant mixing. Most likely head gasket, if your unlucky perhaps cracked head. After you have confirmed that you need to pull the head, have it pressure checked, if it passes have the head re-surfaced and replace the head gasket.
Old 04-01-2012, 05:06 PM
petriej's Avatar
That is what I was afraid of. Should I even bother with steps 1 and 2?
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 05:21 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
looks like a blown HG, how much boost are you at?
Turbo lag is actually a headstart to make it fair
Old 04-01-2012, 05:48 PM
petriej's Avatar
6-8psi
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 05:51 PM
Mr Gusta's Avatar
Fireballs inc.
hmmm seems weird... what blower are you on?
Old 04-01-2012, 05:54 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Mein Auto: '96 328iC, '04 325Ci
DO NOT EXECUTE STEP 2!!! The stop leak crap is indiscriminate in that it will happily try to fill or plug any gap or small passage it can. It rarely solves any issue more than temporarily and then you'll have a hell of a time getting it flushed out of your system.
'96 328iC "Marie"
Old 04-01-2012, 05:59 PM
petriej's Avatar
VF S/C. Not sure which one, and I don't want to go out and check.
Roger that.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 06:00 PM
Mr Gusta's Avatar
Fireballs inc.
if its a kit that flows more air at 6psi than a smaller kit makes at 11 the milshake makes sense
Old 04-01-2012, 07:04 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
any driveability issues?? overheating??
i always suggest confirming a with one of these...http://www.blockchek.com/
they all work the same, and are available from napa, and most likely other parts stores and online.
df
Old 04-01-2012, 08:48 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Damn Jared, sorry man. It looks like you'll be pulling the head... Perfect time to get a more durable head gasket and throw in some ARP head studs.
1998 BMW 328is
1966 Pontiac GTO
Old 04-01-2012, 09:48 PM
petriej's Avatar
df
Nope and Nope. I'm crossing my fingers I caught it in time to not have a warped or cracked head. I'll check out the kit. I had a couple of other suggestions to check for exhaust gases in the coolant, but I'm pretty sure it is oil. Definitely not using any of that waterless coolant of similar color or anything similar.
I know a thing or two about wrenching, but I've never done anything as complicated as a head gasket repair. Should I bother even trying it on my own? I have time and patience. Could be a good learning experience...
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 10:00 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
If you have time and patience, go for it. You'll definitely learn a lot about your car...more than most. It's an involved job, but well within DIY status. There are many DIY write-ups on how to go about it.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 04-02-2012, 12:10 AM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Never even knew you had FI lol
Hope its nothing TOO serious
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 04-02-2012, 12:37 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Oops.....all this time I thought it was Jason. My bad.
And I didn't realize it was blown either. Sweet!
Sorry to see that picture, how sad that must have been.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 04-02-2012, 08:24 AM
petriej's Avatar
Yep. I was trying to keep it 'secret' for Bimmerfest, but oh well. Now my goal is to have her back up and running in time for the Bay Area caravan, if we're still doing that...
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 09:11 AM
B1MM3R's Avatar
B1MM3R B1MM3R is online now
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
Sorry to hear.,
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 04-02-2012, 09:30 AM
Jok15's Avatar
Jok15 Jok15 is offline
1997 328i
Mein Auto: 1992 325i
There's a bay area caravan? Wah? I saw no such post anywhere :0
And sorry for the bad news :s
1997 Bmw 328i Vert - SOLD 3/25/2012
1992 Bmw 325i - ****ed 4/2/2012
Old 04-02-2012, 09:31 AM
petriej's Avatar
So if anyone local is bored, I'm accepting helpers for this job. I pay with food and drink (adult beverages if appropriate)
Right now I'm assembling literature. I already have the bentley manual, and I think the Pelican DIY article will be my main approach. My roommate has already expressed interest in helping. I'm trying to stay positive about this, but I know it's going to be expensive and frustrating.
I think the guys at MotorSpeed West will be my fallback, but I don't want to piss them off by breaking something. We'll see I guess.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 10:26 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Dude id totally be down if you weren't a billion miles away and if I actually knew what I'm doing lol.. Never did a head gasket, currently helping out a friend replace his as practice (his blew twice).. how long do you think the car will be out of commission for? I'm sure you're going to try to get her up n running in a hurry lol
-Usama
Old 04-02-2012, 10:32 AM
petriej's Avatar
Well, I forgot I'm going to PR for 2 weeks in May, getting back right before Bimmerfest, so it looks like I have just over 1 month to get this all done. If I have to bring my X5 down to Pasadena, I won't be able to park with any of you guys
Vallejo to East San Jose is no more than an hour and a half... Maybe on a weekend? Probably not this weekend, seeing as it's Easter. I know it is going to be a long process, so I'll try to get stuff off the car during the week. Hoping to have the head off by the 14th. May need to buy some special tools it looks like.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 10:35 AM
B1MM3R's Avatar
Jesse Moon Bayne
So they park all models together? like e36's together and e46's etc? J/W b/c I think me in the e36 and the misses in the x5 are driving to bimmerfest east.
Jesse
Part out.
E30 87 325e
Old 04-02-2012, 10:38 AM
petriej's Avatar
I've never been, but from what pics I've seen there are two sections. Organized parking, and just regular FCFS parking for spectators and such.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 10:45 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Hmm I might be able to swoop by next weekend and offer the little help that I can lol. I mean, I've taken heads off cars before, but they were usually on scrap motors where I didn't care if I broke something in the process. And I know, been to SJ a lot back in the e36 days lol I was just teasing you
And they don't really separate you..they do manage parking so as long as you roll in as a pack, then you all will be parked next to each other. After an hour there are usually open spots around where you can move your car if you did happen to park far away .. But I still don't know if I'm going or not this year
-Usama
Old 04-02-2012, 10:52 AM
buellxb buellxb is offline
Mein Auto: 1997 328i
Hey man I just got this same diagnosis 2 days ago! Im in the same boat. Ordering parts today!
