The "ZHP" Wagon is ON!!!! - Page 3 - Bimmerfest - BMW Forums
Old 03-03-2012, 10:38 AM
v33_n0d3's Avatar
v33_n0d3 v33_n0d3 is offline
Black Mage
Mein Auto: 2001 325i Sedan
Nice project ffej. I'll be sure to keep checking up on this one. Looks like it'll be an interesting adventure. Good luck and have fun with it!
Old 03-07-2012, 12:12 PM
ffej's Avatar
ffej ffej is offline
Tightrope walking
Mein Auto: Jackwagon!
Just heard from the shipping company. It's supposed to arrive this evening!!!!
Building a ZHP wagon... click the pic!!!
Because BMW wouldn't do it for me
For Sale - HUGE part out of 2005 ZHP sedan
Originally Posted by KrisL View Post
My input is that ffej knows what he's talking about .
Old 03-07-2012, 01:43 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & ST 335i
Hell yeah!. Can't wait!
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
BMW 2006 M3 - stock - SOLD
Old 03-07-2012, 07:07 PM
ffej's Avatar
Tightrope walking
Well, that fracking bites! The AC compressor was torn off the engine block. Nice sized hole I can stick my thumb in. Now I get to find a new block and rebuild the whole motor. Whee!!!!!
No wonder it was such a bargain
So should I get a plain block and rebuild the motor or get a new motor entirely?
Old 03-08-2012, 04:16 AM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Ouch, sorry to hear that. I say rebuild the motor with a new block if everything looks good once you start pulling it apart.
I wonder what that ZHP ran into, obvouisly it had pokey branches...
Old 03-08-2012, 05:06 AM
ffej's Avatar
Tightrope walking
I'm pretty sure it was hit while parked. I can't imagine a frontal impact like that not setting the airbags of any other way...
I'm pricing out bare blocks and going to see what more I'll have to take on with the job.
Old 03-08-2012, 06:51 AM
///M3lissa's Avatar
///M3lissa ///M3lissa is offline
\m/ (>.<) \m/
Mein Auto: Duh!
Think of what a great learning experience this is going to be
Old 03-08-2012, 07:19 AM
ffej's Avatar
Tightrope walking
Can't argue w you there. I'm mostly bummed that it's going to take linger than I originally thought.
Old 03-08-2012, 09:12 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
That sucks...I feel your pain!
PT
___________________________________
Old 03-09-2012, 04:49 AM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
It seems unlikely those systems would be different. They are the same generation, same software, same basic layout. All the stuff on the outside of the motor is the same too as far as the electronic sensors are concerned. Shouldn't everything just plug right into the existing harness in the wagon? Especially if the wagon is a stickshift, I can't think of anything that would be different from a stickshift RWD 2.5L and a stickshift RWD 3.0L with a set of cams in in it. Swapping over the ECU should take care of the engine software and nothing else is changing right?
Im not particularly well versed on the ins and outs of OBD-II so I'm just spitballing, but it seems logical.
There were quite a few software (and some hardware) changes between 2001 and 2002, and unfortunately everything other than the DME is stuck with the factory software. As far as starting and running the car, most of the changes shouldn't cause any issues. It's diagnosing the car where some issues might arise. If his car is going to have the ZHP's cluster, EWS, and LSZ modules by the end of the project, then his car will identify itself as a ZHP. In my experience, the diagnostics and coding programs error out and quit if they detect that a module is running older software than intended for the car.
My recommendation would be to send the ZHP's DME and the wagon's EWS to RPM Motorsport, and have them sync the EWS tables and change the VIN of the DME to the wagon's. That way he could keep all of his original identifying modules (it won't be an issue that his car identifies itself as a 325 wagon while the DME is for a 330; the DME's software versions and uptates are determined independently of everything else). If he wants the red needles and the 6800 RPM redline, I would say he's best off just physically swapping the gauge faces and the needles.
DSC may or may not pose an issue. Although both cars use the MK60, I know that the software on the module changed a decent bit between 2001 and 2002. It might not be enough of a difference to confuse the DME, but at the same time it could be. Worst case scenario, he should be able grab the module from the ZHP without causing any issues; wiring should be the same.
I have no afiliation with RPM Motorsport btw. They're just the only company I'm aware of that can change the EWS tables on used DMEs.
Old 03-09-2012, 04:56 AM
BLT's Avatar
BLT BLT is offline
Mein Auto: 330i, Mazda6, R90/6 R60/5
Might not be as bad as you think, I have seen amazing things that a good machine shop can to to repair this type of damage....
Unless you want to start from scratch.
Drama queens don't wear panties.
Old 03-09-2012, 05:10 AM
ffej's Avatar
Tightrope walking
Originally Posted by TerraPhantm View Post
...RPM Motorsport btw. They're just the only company I'm aware of that can change the EWS tables on used DMEs.
Thanks. I'll definitely check into that!
Old 03-09-2012, 05:12 AM
ffej's Avatar
Tightrope walking
You know me, I like to do things the hard way.
I'll call you later...definitely want to hear more.
Old 03-09-2012, 03:32 PM
ffej's Avatar
Tightrope walking
So...far from letting a little set back slow me down, I've swapped out the steering wheel, door trim and shifter today. It's amazing how good the ZHP steering wheel feels. And the difference in throw in the shifter is enormous. I also removed the front brakes from the ZHP and will probably do that job this weekend. Maybe. Maybe I'll do the exhaust.
Old 03-10-2012, 11:56 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I highly suggest doing the rears as well. Yes, it requires removing the ZHP trailing arms and half shafts but when I put ZHP front brakes on my 323 it did little to help braking. It wasn't until I added the rears it really made a difference you could feel. I was told by some people that adding just the bigger front calipers makes the brake bias get out of whack. Not sure I agree, but hopefully this info is helpful.
So, how do the B and C pillars look in that car?
Old 03-11-2012, 06:24 AM
Gryphon's Avatar
Gryphon Gryphon is offline
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
I don't remember did you have the Alcantara or perf. leather wheel? It would be amazing if you could get an Alcantara interior in the wagon, but I'm pretty sure the rear seat back differs from the sedan(think the rear bottom is compatible) so you'd probably have to custom the back....maybe Coby could help you replacing leather with Alcantara.
It hasn't been said yet so it needs to be now....
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 03-23-2012, 07:57 AM
smolck's Avatar
ROLL TIDE!
The cone has been silent for some time. ffej, what is your progress?
Old 03-23-2012, 10:14 AM
ffej's Avatar
Tightrope walking
Slower than I'd hoped for. I've got driveshaft and diff out, working on rear subframe and suspension. Pulling interior bits at the same time. BTW, I've got both sets of B&C pillars out now.
The big hold up is that our BMW CCA chapter is putting on an HPDE on March 31. As the Tejas Chapter's Chief Driving Instructor, I've got a teenie little bit of responsibility for making sure it runs smoothly
And another recent update. The hole in the block is repairable, according to several knowledgeable folks that I know. Have a welding shop recommendation and will be pulling the motor the weekend after the HPDE
Old 03-23-2012, 11:47 AM
ffej's Avatar
Tightrope walking
Happy Cams
Old 03-23-2012, 08:34 PM
Makes sense. The e46 already has a bias that's too far forward. Increasing the rotor size and piston diameter will shift it even farther up. Restoring the balance via rear brakes would probably make the car feel a lot better at the limits
Old 04-04-2012, 07:38 AM
BLT's Avatar
BLT BLT is offline
Ok, your big race event weekend is over. What's the status on your progress?
Old 04-04-2012, 07:44 AM
ffej's Avatar
Tightrope walking
Slowly but surely...
Old 04-04-2012, 07:59 AM
BLT's Avatar
BLT BLT is offline
Looks like the original suspension is still in place.
Old 04-04-2012, 08:21 AM
Scott ZHP's Avatar
We want the Lion!
Photo of hole, please.
Old 04-04-2012, 08:42 AM
BLT's Avatar
BLT BLT is offline
This isn't "that" type of a forum.
