Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 01-04-2012, 05:38 PM
mark_m5's Avatar
mark_m5 mark_m5 is online now
Overly Intellectual
Mein Auto: 2002 M5, 2001 996 Turbo
Supercharger for $179?
http://www.superchargertuning.com/pa...nts/show/id/18
It's basically an electric fan that spools up to 20k RPM... in place of your stock air cleaner.
Should I get 2 for my M5?
Our electric supercharger is designed for enthusiasts looking for additional power but are not ready to buy an expensive turbo kit or supercharger kit which can void their vehicles warranty, cost upwards of $5000 and require additional maintenance. These things you do not need to worry about with our charger system. It may require small modifications to mount the charger on your air intake line, but it can always be reversed.
What is included with this purchase?
  • 900+ Watt Motor
  • Safely generates up to 5 PSI of boost
  • Laser Cut 10 Blade Turbine with Rigid metal
  • Spools at 20,000 RPMs+
  • Maximum Boost in less than 1/10 of a second
  • 2" – 3.5" Rubber Couplers
  • High-Flow Air Filter Unique Design *Optional
  • Step-by-step Installation Guide in Manual
  • Metal Securing Clamps
Seems like I could save $70K over the cost of a DINAN S3
The GTE electric supercharger is not your average boat blower or fan you may have seen others sell. It uses high grade, high speed motor structures designed and tested in Germany and Japan for the ultimate air pressure. The motor spins to over 20,000 rpm within a few milliseconds. All necessary parts are included to install on any air intake setup. Our kits are designed to efficiently and safely for air into your engine. The supercharger activates only when your floor the vehicle. The reason is the charger is designed to operate for no longer than 1 minute continuously because of its high velocity. This is not a problem, because if you ran your vehicle for 1 minute floored, you would be running over 200MPH.
Install on vehicles such as:
· Vehicle with Factory Air Box
· Vehicle with aftermarket air intake setups
· Vehicle with dual air intake setups *Requires Two Superchargers
Gain up to 40-60HP! The GTE Electric Supercharger™ is based on years of technology development in electric superchargers. Using your vehicles electrical system safely, the GTE can add substantial amount of air flow into your engine. More air pressure in your engine, the more horsepower you will make. Unlike turbo systems, which have a lag before producing horsepower, our electric supercharger gives you immediate response.
Other superchargers and turbo kits require extensive engine modifications. They also add extra weight to your vehicle. Our electric supercharger weights in less than 5 lbs. They also require serious engine software modifications. Our product can work on factory computer settings or even with our performance chip modifications for even better performance.
Here is what customers have to say
.."I installed the charger on my civic 2000 within 1 hour. The hardest part was running the wire inside the vehicle so the switch can acitivate the charger when I floored the car. I also had the option to mount the switch on the throttle body place, but thought it would be better under the pedal. I immediatly noticed power gain when I floored the car. I lost almost 1 second on my quarter mile drag test…."
Mark
Grammar: The difference between "knowing your sh*t" and "knowing you're sh*t."
"A world that is 'idiot proof' is a world that is only fit for idiots." - Racer X / 6'er
Old 01-09-2012, 01:21 PM
beewang's Avatar
beewang beewang is offline
Bo-ma-win!
Location: Eugene, OREGON, Home to the Rose Bowl Champion
Send a message via Yahoo to beewang
Mein Auto: S62 E39
That is AWESOME!! Please get it and let us know.
Thnx
Old 01-09-2012, 03:08 PM
mark_m5's Avatar
Overly Intellectual
Thnx
I'm thinking maybe I could get a little computer fan from Fry's instead, and save $150...
I showed this to my mechanic and we got a good laugh out of it.
When the fan's not running, it'll act like having a potato stuck in the intake. It has 2 positions: ON,OFF. So it's not variable to adjust to RPM like a "real" S/C. It'll lean out your motor until the computer compensates. And you can't run it for extended periods of time or it'll overheat (per their video)
I think I'll let someone else be the guinea pig and see what happens...
Mark
Old 02-20-2012, 05:59 PM
llHERMESll llHERMESll is offline
Mein Auto: 92 Nissan PU
I have spent a lot of my life turbocharging cars, trucks, planes, and boats. This is junk and will do nothing except for cause you problems.
Old 02-22-2012, 11:18 AM
mark_m5's Avatar
Overly Intellectual
Understood Hermes
Mark
Old 02-25-2012, 07:14 PM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
You get what you pay for...
Old 04-04-2012, 01:40 PM
e30ultimate e30ultimate is offline
Mein Auto: 5spd
really......
Old 10-16-2012, 11:07 AM
cpatti cpatti is offline
Mein Auto: 1998 bmw m3
looking to turbo or supercharge my 98 m3 which is the better of the two for the motor.
Old 10-16-2012, 02:44 PM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
Good god. Those things are still around? I thought they died along with fart cans.
Old 12-11-2012, 05:17 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
These are almost as big of a scam as the "performance chips" that you splice into your MAF sensor wires.
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 12-20-2012, 06:01 PM
ahmadr ahmadr is offline
Mein Auto: F30 (N20, 7/12)
This is a joke of a scam.
For starters, compressing lots of air, requires lots and lots of energy. We're speaking about several HP at the very least, which at 12V would mean hundreds of amps. The power required to compress all that air can't possibly be obtained through those wires.
This is an example of a real electric supercharger:
http://autospeed.com.au/cms/title_Is...9/article.html
Note that it requires 350 amps, i.e. 4.2 KW. And that's for a mild 6psi boost on a small 1.2l engine.
BTW, Google is also your friend
http://google.com/search?q=electric+supercharger+scam
Old 12-20-2012, 06:14 PM
Not in this case!
Old 02-21-2013, 06:09 AM
Dannykazzy Dannykazzy is offline
Mein Auto: 1998 BMW m3
My brother being a stubborn individual bought this for his car and the worst 200 bucks he spend the biggest shut you can get rather put gas in for 200 bucks
Old 03-11-2013, 02:10 PM
mark_m5's Avatar
Overly Intellectual
Well, at least he did a public service for us by proving it didn't work!
Mark
Old 03-11-2013, 08:04 PM
SuperTerp SuperTerp is offline
Mein Auto: m4now M5M3 550 760 335RIP
Does anyone have the install guide I just got mine and am trying to figure out how to remove these crappy twin turbos. This should be a real upgrade compared to the twins.
Old 03-30-2013, 07:38 AM
damnboy37 damnboy37 is offline
Mein Auto: 99M3,95M3
You want cheap power mod? Get a m50 manifold
99 M3 300rwhp 6psi
95 M3
Old 04-08-2013, 04:38 PM
TheBlackGT's Avatar
TheBlackGT TheBlackGT is offline
That Guy w/ the Modded GT
Mein Auto: BMW 550i GT LCI
_
Say Goodbye to the Old GT. Say Hello to my New LCI.
Different. Bold. Unconventional.
Follow me on Instagram at: www.instagram.com/TheBlackGT
CCA Member: 477510
Old 04-13-2013, 12:30 PM
theta theta is offline
Mein Auto: MINI R60
I always love seeing these things on eBay. The insane part is that people actually buy them (and then use them)... Poor saps...
Old 06-01-2013, 12:10 AM
Jimmy540i.com's Avatar
Jimmy540i.com Jimmy540i.com is offline
That Reckless BMW Driver
Send a message via AIM to Jimmy540i.com
Mein Auto: BMW/Ferrari/Ducati/Lambo
Don't think so buddy. A real supercharger should look like this:
or this:
or these:
Old 09-26-2013, 06:11 PM
JM35 JM35 is offline
AutobahnBMWParts.com
Mein Auto: 2008 535i Sport Package
When it comes to cars and modifications, you truly get what you pay for. If this were as effective as a Dinan, everbody would be running it.
If i have any advice, do it right the first time; theres no such thing as cheap power.
Old 10-10-2013, 03:50 AM
SteveinBelAir's Avatar
SteveinBelAir SteveinBelAir is offline
Cockney Curmudgeon
Mein Auto: 2012 X5 50i MSport
I love the 'filter optional' bit.
Makes you wonder what would happen to your engine once that tin fan blade breaks up.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport, JB Stage 1, 0-60 4.64 secs. Woot!
See me for Industrial Electronic Repair.
Old 03-29-2015, 12:13 AM
mark_m5's Avatar
Overly Intellectual
Dyno test results for the exact product I asked (jokingly) about in the OP...
Mark
Old 03-29-2015, 01:28 AM
u3b3rg33k u3b3rg33k is offline
Mein Auto: e30, e60, R1100S
e30: '87 325i: MAF+WAR chip, long tube STAHL headers, 5MT swap, 4.27 torsen
e60: '08 550i M-sport, 6MT, ARC, Active Steering, 19" wheel delete
R1100S - oilhead FTW
Originally Posted by MeNoo View Post
Although I have nothing scientific to say, I can confidently say that it works.
Originally Posted by Burning2nd View Post
If you want to use the fuhrers snowmobile you gotta have das tires
