Old 04-04-2012, 05:02 PM
paulie710 paulie710 is offline
Mein Auto: 750il
Unable To Bleed Cooling System
Recently i changed the radiator etc on my 99 750 V12 bled it by trurning the key on...hearter on low .opened bleeder on resiovor and filled radiator kept filling it until it was full and almost all bubbles out from the bleeder...closed up bleeder /cap . and took it for a ride ..did this several times over the couse of a week i still have an eractic temp gauge while driving .It will shoot to almost pinned then back down to normal......
The funny thing is i can let this car idle for over and hour and the temp wont budge past normal......but after a few miles of driving the gauge will go from normal to pinned the back again several times!!! this is making me nuts !!! Any help would be gratly appreciated
ps Listed below are the parts that i recently changed
Altenator
Thermostat
both coolant senders
upper hose
clutch fan w/fan and shroud
Old 04-08-2012, 10:32 PM
Brad DeLoye Brad DeLoye is offline
Mein Auto: 528i, is300 f150
sounds like u need to replace temp sensor.
Old 04-09-2012, 04:09 AM
Mein Auto: 750il
I already replaced the temp sensor
Old 04-21-2012, 08:05 PM
NCMIC NCMIC is offline
Mein Auto: 1998 BMW 740il
Are you sure of the rotation direction when you placed the belt back on?
Sent from my DROID3 using Bimmer App
HTML code is Off
