Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 04-06-2012, 05:26 AM
Rett Rett is offline
Mein Auto: 1987 convertible 325i
Convertible Cover Support Shocks
Ok, I took a look at the diagram at;
http://www.realoem.com/bmw/showparts...46&hg=54&fg=10
and I can't find the shocks, let alone how to get them off. For the the hood and trunk shock there is a simple snap washer (probably the wrong name), but not for on the convertible cover shocks.
First, how do you get them off, and
Second, what's the trick to compress them long enough to get the new one on?
Old 04-06-2012, 09:03 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
part number 4 is the shock. part number 5 is the "clamp", locate the items you can clearly see and follow them to the struts.
im sure someone on here knows what type of "clamp" that really is holding it on.
you should be able to put 12 half of the strut on and push the other down(or up) into place.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-06-2012, 10:29 AM
Thanks,
In looking at it, it may come off at the bottom first. I'll get to the house and look. However, I've had trouble compressing the shocks. Must be a whimp!
convertible, cover, support shock
