E30 (1982 - 1993)
Old 04-09-2012, 06:21 AM
RevthisE30 RevthisE30 is offline
Mein Auto: 1986 e30
Not the fuel pump
So My 86 ES will turn over and over just fine but won't start. seems to not be getting fuel. I couldn't here the fuel pump priming so i replace it and still nothing, can't hear the new pump prime either. Thinking possible relay or something. I am open to any and all LOGICAL imput. PLEASE help.
No one ever attains success by simply doing what is reqired of them.
Old 04-09-2012, 07:01 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
Disconnect the fuel line up front and stick it in an empty water bottle. Crank the motor for 2 seconds (the bottle should be almost full) I would replace the fuel pump relay and main relay first. they are right beside the airbox in a seperate little black holder.
The main relay has 5 pins the horn relay and fuel pump relay both have 4 and you can try swapping them to see if your fuel pump works.
Those are the only relays in that little holder
(ps the M/// logo on ur car makes me want to puke a little)
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 04-09-2012, 08:21 AM
danielw05 danielw05 is offline
Send a message via AIM to danielw05 Send a message via MSN to danielw05 Send a message via Yahoo to danielw05
Mein Auto: 1990 325i
have you replaced the fuel filter recently?
Old 04-09-2012, 09:36 AM
Mein Auto: 1986 e30
brand new fuel filter. Thank you, that is the best advice i've heard yet.
Old 04-14-2012, 09:35 AM
Mein Auto: 1986 e30
WWWWWWWWWWWTTTTTTTTTTTTTTTTTTTTTTFFFFFFFFFFFFFFFFF FFFFFFFFFF?????????????????????????????!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I replaced both fuel pumps, both relays, the filter and i am still not getting any fuel to the motor. I can hear both the fuel pumps, but when i turn the key to prime them i get nothing until i start turning the motor over.
Old 04-14-2012, 01:28 PM
downhiller's Avatar
livin large
thats bmw for you. fuel pumps do not prime on these cars.
Old 04-15-2012, 02:19 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
lol check all your fuel lines. and if they are good maybe just needs to pump fuel so turn it over until it pumps fuel all the way to your rail..
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 04-16-2012, 08:20 AM
Try&CatchMy325's Avatar
Try&CatchMy325 Try&CatchMy325 is offline
E30's,Work,Eat,Sleep
Mein Auto: 1997 328i
Test light wires and see if you have amps there. Dvom is the next best thing. See if there is enough amps and volts getting there.
1987 325e
2002 325ci
1999 Aprilia Rs50 (80cc Kit)
Old 04-17-2012, 12:26 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
I do not know the 86 ES but most E30s do not have the fuel pump running until the engine turns over...it is a safety issue.
As stated above...check that you get fuel pumped into a container near the engine.
I know on my 318i M40 it is very easy to get the two fuel pipes crossed over at the throttle body...one pipe is the fuel return to the tank while the other pumps fuel from the tank.
