Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - Current)
The 5 Series Gran Turismo -- now available in the USA as a 535i, 550i and 550i xDrive model.
Old 04-04-2012, 03:47 PM
afmiller afmiller is offline
Mein Auto: M Roadster 535xi GT
Question mobility Kits
Have summer conventional performance tires on 2011 535xiGT, with BMW mobility kit in trunk. Have heard conflicting info as to whether use of sealant in mobility kit will damage TPM sensors. New TPMS sensors are quite expensive I understand. Would appreciate any feedback/experience with using the sealant in a flat tire emergency situation. Did you have to replace the TPM sensor? With a simple puncture, did the sealant otherwise damage the conventional tire? Thanks for your time and feedback.
Old 04-04-2012, 04:06 PM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT; i3 BEV
It's likely that the sealant will plug up not only the hole but the sensor as well. When I bought my winter tires, the second set of sensors for the new wheels cost about $240, if I remember correctly, from Tirerack, or $60 each. Don't know what the dealer may charge, but those from TireRack registered with the computer's pickups and have worked fine.
If you're lucky, you can just use the compressor to pump it back up without the sealant and drive to a repair shop. only if it is leaking too fast or you can't afford the time would you need the sealant. If not, they want $40 for a new cannister of the sealant, and that flat may end up costing you at least $100 if you also need a new sensor, not counting the original price of the mobility kit. There's no guarantee the sealer will seal the hole or if it can be properly repaired later, but that's true of any tire. BMW specifically says not for use on RFT's, but that's not your issue.
Old 04-04-2012, 08:06 PM
starryeyed starryeyed is offline
What's Not to Love??
Mein Auto: 2012 535xi GT MSport
And forget the sealant if you have a tear in the sidewall.....been there, done that.
Old 04-06-2012, 07:41 PM
gmblack3 gmblack3 is offline
Paint polishing expert
Mein Auto: 2011 335is
I'll be going this route after I install 312s and Michelin PS A/S.
Sent from my PG86100 using Bimmer App
Bryan Burnworth
14 Tesla S85 Model S
Previous BMWs
12 535i GT DSMB/Cinnamon Welt 1/31/2012
11 335is SGM
99 740il-sold 52k-157k
94 540ia-sold 98k-155k
93 740il-sold 92k-147k
Old 04-07-2012, 04:33 PM
Wardman Wardman is offline
Mein Auto: 2015 X5 35d
Nice move - you will appreciate the ride (IMO) even more. Continental makes a mobility kit too, FWIW.
Old 04-09-2012, 05:01 PM
1STBimmer 1STBimmer is offline
Mein Auto: 550i GT/X5 35d
Just bought it for the X5 along with 4 Conti DWS. Getting them installed today, eager to drive the X (It's been a while... she's been relegated to 2nd place since the GT arrived). If I like how it rides I'll probably end up getting them for the GT as well and saving the GoodYears for lease turn-in.
HTML code is Off
